vand subwoofere spl dynamics, grounzero, Mtx,Powerbass,etc la comanda cu garantie!!!!
vand subwoofere noi:Ground Zero,MTX,Spl Dynamics,Soundstream,Fi Car Audio,Powerbass,Hifonics,Crunch,Magnat,etc,etc,etc .... aproape orice model orice tip!noi la comanda cu garantiE!!!! id mess:klondealer sau nr de tel: 0746908017
Re: vand subwoofere spl dynamics,ground zero,Mtx,Powerbass,etc la comanda cu garantie
stai linistit ca nu am zis ca eu am adus am trimis doar niste poze dupa net dar nu asta conteaza!conteaza ca pot sa aduk Fi am sursa in anglia! alta intrebare?
Diametru 12 inch
Putere Maxima 700 W
Putere Nominala (RMS) 350 W
Impedanta 2 x 2 ohmi
Raspuns Frecventa 20-100 Hz
Sensibilitate 87,7 dB
Excursie Difuzor Xmax 20mm
Magnet 80 Oz
Vas 67,5 litri
Chrome Backplate
Enhanced Voice Coil Cooling
Sasiu Aluminiu
Adincime Instalare 152 mm
570 RON nou la comanda!!sau aduc orice marca orice tip de subwoofere noi!!cu garantie!!
Subwoofer Auto
Diametru 12 inch (30 cm)
Putere Maxima 2000 W
Putere Nominala (RMS) 1000 W
Raspuns Frecventa 25 Hz - 2 kHz
Sensibilitate 92 dB/W/m
Santoprene Rubber
Con din Polipropilena
Sasiu Aluminiu
Vas 52 litri
Adincime instalare 150 mm (5,91")
Greutate 7,5 kg
Magnet 100 oz
Pret 400 Ron!nou la comanda orice marca orice tip de subwoofere noi!!cu garantie!!
* RMS Power : 250W
* Max Power : 750W
* Impedance : 4Ohm
* Frequency response : 33Hz - 150Hz
* Sensitivity : 91,4dB/2,83V/1m
* Woofer diameter : 30cm (12)
* Xmax : 9,5mm
* Dimensions (HxWxD) : 37,0x38,0x41
Pret 480 RON. Nou la comanda!!sau aduc la comanda orice marca orice tip de subwoofere noi!cu garantie!!
* amplificator stereo, 2 canale
* putere:
o 4 ohmi, stereo: 2 x 55 W RMS
o 4 ohmi, in punte: 1 x 150 W RMS
o 2 ohmi, stereo: 2 x 75 W RMS
* stabila la 2 ohmi
* raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
* bass boost variabil 0 - 12 dB la 45 Hz
* filtru low pass variabil 40 - 300 Hz (12 dB)
* filtru high pass variabil 40 - 300 Hz (12 dB)
* selector mod de functionare 2/1 canale
* circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
* subwoofer de tip sealed cu difuzor de 30cm
* putere: 250W RMS (800W max)
* raspuns in frecventa: 25-250 Hz
* SPL: 91 dB
* impedanta 4 ohmi
* greutate: 11kg
* dimensiuni: 430 x 390 x 355/ 265 mm
Pret 330 RON. Nou la comanda!!sau aduc la comanda orice marca orice tip de subwoofere noi!cu garantie!!
* Mărime: 12/300 mm
* Adβncime: 150 mm
* Putere: 400/800 W
* Impedanţă: 2x4Ω
* Frecvenţă: 25Hz - 800 Hz
* Bobina mobilă: 63,8mm
* Sensibilitate: 96 dB/W/m
* Mărimea magnetului: 80 oz
Subwoofer Auto Ground Zero 350w Rms Nou La Comanda!!
Pret 450 RON. Nou la comanda!!sau aduc la comanda orice marca orice tip de subwoofere noi!cu garantie!!
* Subwoofer 12" in incinta bassreflex
* Diametru difuzor: 30cm
* Putere RMS: 350W
* Impedanta: 4 ohmi
* Bobina: 50mm
* Dimensiuni (w x d x h): 54 x 38,5 x 35 / 16 cm
