| VERSUS AUTO SUPRA vs SUBARU, Mercedes vs Bmw, pilotul x vs pilotul y. Aceasta rubrica este dedicata provocarilor,analizelor,pariurilor(virtuale bineinteles),comparatiilor. Rog moderatorii sa fie foarte duri pe acest subiect. Fara OFF-TOPIC |
28-07-06, 15:13
corvette zo6(2006) vs lambo gallardo se vs ferrari f430 vs dodge viper srt-10(2006)
corvette zo6:
price $65 800 USD
engine Cast Aluminum LS7 V8 w/Dry Sump Lubrication
position Front Longitudinal
valvetrain OHV, 2 Valves w/Cyl
fuel feed Sequential Fuel Injection
displacement 7011 cc / 427.8 cu in
bore 104.8 mm / 4.13 in
stroke 101.6 mm / 4.0 in
compression 11.0:1
power 372.9 kw / 500 bhp @ 6200 rpm
hp per litre 71.33 bhp per litre
bhp/weight 352.18 bhp per weight
torque 644.01 nm / 475 ft lbs @ 4800 rpm
redline 7000
drive wheels RWD w/Electronic Traction Control
body / frame Composite Body Panels over Hydroformed Steel Frame w/Aluminum & Magnesium Structural Components
front brakes Vented & Cross Drilled Rotors w/6 Piston Calipers, ABS
f brake size 356 mm / 14 in
rear brakes Vented & Cross Drilled Rotors w/4 Piston Calipers, ABS
r brake size 340 mm / 13.4 in
front wheels F 45.7 x 24.1 cm / 18.0 x 9.5 in
rear wheels R 48.3 x 30.5 cm / 19 x 12 in
front tire size 275/35ZR18
rear tire size 325/30ZR19
steering Rack & Pinion w/Speed Sensitive Power Assist
f suspension Wishbones w/Upper & Lower Control Arms, Transverse Composite Leaf Spring, Monotube Shock Absorbers
r suspension Wishbones w/Upper & Lower Control Arms, Transverse Composite Leaf Spring, Monotube Shock Absorbers
weight 1420 kg / 3130 lbs
wheelbase 2686 mm / 105.7 in
front track 1577 mm / 62.1 in
rear track 1542 mm / 60.7 in
length 4435 mm / 174.6 in
width 1930 mm / 76.0 in
height 1246 mm / 49.1 in
transmission Tremec M6 6-Speed Manual
gear ratios 2.97:1, 2.07:1, 1.43:1, 1.00:1, 0.71:1, 0.57:1
final drive 3.42:1
top speed 318.7 kph / 198 mph
0 - 60 mph 3.6 seconds
0 - 100 mph 8.3 seconds
0 - 1/4 mile 12 seconds
lambo galardo se:
price $166 00 USD
engine 90 Degree, Aluminum V10.
position Mid Longitudinal
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl w/Variable Intake System & Continuously Varibale Valve Timing
fuel feed Multipoint Sequential Fuel Injection
displacement 4961 cc / 302.7 cu in
bore 82.5 mm / 3.25 in
stroke 92.8 mm / 3.65 in
compression 11.0:1
power 372.9 kw / 500 bhp @ 7800 rpm
hp per litre 100.79 bhp per litre
bhp/weight 340.14 bhp per weight
torque 510 nm / 376.2 ft lbs @ 4500 rpm
redline 8100
drive wheels 4WD w/Viscous Traction System
body / frame Aluminum & Thermoplastic over Aluminum Spaceframe
front brakes Vented Discs w/Brembro 8-Piston Calipers, ABS
f brake size 365 mm / 14.4 in
rear brakes Vented Discs w/Brembro 8-Piston Calipers, ABS
r brake size 335 mm / 13.2 in
front wheels F 48.3 x 21.6 cm / 19 x 8.5 in
rear wheels R 48.3 x 27.9 cm / 19 x 11 in
front tire size Pirelli Pzero 235/35 ZR 19
rear tire size Pirelli Pzero 295/30 ZR 19
steering Rack & Pinion w/Power Assist
f suspension Double Wishbones w/Anti-Roll Bar
r suspension Double Wishbones w/Anti-Roll Bar
weight 1470 kg / 3241 lbs
wheelbase 2560 mm / 100.8 in
front track 1622 mm / 63.9 in
rear track 1592 mm / 62.7 in
length 4300 mm / 169.3 in
width 1900 mm / 74.8 in
height 1165 mm / 45.9 in
transmission 6-Speed Manual w/Optional Robotized E-Gear
top speed 309 kph / 196.0 mph
ferrari f430:
price $171 000 USD
engine V8
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl w/Variable Timing, Variable Intake Tract
fuel feed Electronic Sequential Injection
displacement 4308 cc / 262.9 cu in
bore 92 mm / 3.62 in
stroke 81 mm / 3.19 in
compression 11.3:1
power 360.2 kw / 483 bhp @ 8500 rpm
hp per litre 112.19 bhp per litre
bhp/weight 333.31 bhp per weight
torque 638 nm / 470.6 ft lbs @ 6250 rpm
redline 8500
drive wheels RWD w/E-Diff, CST
body / frame Aluminum Monocoque
front brakes Carbon-Ceramic Discs
f brake size 380 mm / 15.0 in
rear brakes Carbon-Ceramic Discs
f suspension A-Arms w/Coil Springs, Electric Adj Tube Shocks, Anti-Roll Bar
r suspension A-Arms w/Coil Springs, Electric Adj Tube Shocks, Anti-Roll Bar
weight 1450 kg / 3197 lbs
wheelbase 2600 mm / 102.4 in
front track 1669 mm / 65.7 in
rear track 1616 mm / 63.6 in
length 4512 mm / 177.6 in
width 1923 mm / 75.7 in
height 1214 mm / 47.8 in
transmission Manual or F1 Paddle Shift
gear ratios 3.29:1, 2.16:1, 1.61:1, 1.27:1, 1.03:1, 0.82:1
0 - 60 mph 3.9 seconds
0 - 1/4 mile 11.9 seconds
dodge viper srt-10:
price $83 145
engine All Aluminum, 90 Degree V10
valvetrain Pushrod Activated OHV, 2 Valves per Cyl
displacement 8275 cc / 505.0 cu in
bore 102.4 mm / 4.03 in
stroke 100.6 mm / 3.96 in
compression 9.6:1
power 372.9 kw / 500.1 bhp @ 5600 rpm
hp per litre 60.44 bhp per litre
bhp/weight 326.22 bhp per weight
torque 711.8 nm / 525.0 ft lbs @ 4200 rpm
redline 6000
body / frame SMC & RIm Panels over Tubular Steel Spaceframe
front brakes Brembro Vented Discs w/4-Pot Calipers, Power Assist
f brake size 356 mm / 14.0 in
rear brakes Brembro Vented Discs w/4-Pot Calipers, Power Assist
r brake size 356 mm / 14.0 in
front wheels F 45.7 x 25.4 cm / 18.0 x 10.0 in
rear wheels R 48.3 x 33.0 cm / 19.0 x 13.0 in
front tire size P275/35ZR18
rear tire size P345/30ZR19
f suspension A-Arms w/Coil over Shocks, Stabalizer Bar
r suspension A-Arms w/Coil over Shocks, Stabalizer Bar
weight 1565 kg / 3450 lbs
wheelbase 2510 mm / 98.8 in
front track 1469 mm / 57.8 in
rear track 1547 mm / 60.9 in
length 4459 mm / 175.6 in
width 1911 mm / 75.2 in
height 1210 mm / 47.6 in
transmission Tremec T56 6-Speed Manual
gear ratios 2.66:1, 1.78:1, 1.30:1, 1.00:1, 0.74:1, 0.50:1
final drive 3.07:1
top speed 305.8 kph / 190 mph
0 - 100 mph 9.0 seconds
0 - 1/4 mile 12.2 seconds
28-07-06, 18:19
Member of: [Moderators] [AUDI]
Re: corvette zo6(2006) vs lambo gallardo se vs ferrari f430 vs dodge viper srt-10(2006)
nu are sens aceasta comparatie....Muscle car vs Lambo sau Ferry....nu stiu eu unul nu prea vad rostul
28-07-06, 19:25
Member of: [Moderators] [Crazy Drivers]
de ce nu? performante foarte aseamnatoare la preturi foarte diferite
28-07-06, 19:33
oricati bani ai avea si vrei o maisna de aceste performante vezi si diferenta de pret ff sezizabila  cred ca algei dodge vyper srt 10  o masina incredibila cu un sound ..... cel putin monstruos... nu mai are nevoie de nici o prezentare
28-07-06, 23:27
eu nu m-as omori(sa iau una americana) si as lua ferrariu. Cea mai sigura masina dintre ele  , activezi controlul de tractiune ingenios, nu ii dai ca un nebun si ar trebui sa fii in siguranta. In cazul in care m-as confrunta cu o asemenea alegere, cred ca as lua corvetteul ca ma doare inima sa dau dublu pe o masina care merge relativ la fel. Da pentru pretul dublu primesti un Ferrari si nu un Chevrolet. Una dintre ele in orice caz
<a href="http://copycenter.alfasoft.ro">Copy Center Cluj</a>
28-07-06, 23:33
Si eu as alege ori Ferrari ori Lambo....mi se par mashini mult mai frumoase decat corvette sau viper...dolce italiana ce vrei mai mult de atat  ...desigur shi pretzul e pe masura
28-07-06, 23:34
Observator 4tuning
Member of: [Observator 4tuning] [VW] [Honda] [Street Zone]
din punctul meu de vedere z06 si srt-10 sunt sub gallardo (cu z06 s`a vazut dif de 3masini...stitzi voi unde  ) ... mai ramane ferrari f430 ... aici nu stiu ... inclin spre gallardo  ... poate pt ca am o simpatie fatza de el
Honda Civic TypeS - VW Polo 1.2 - Subaru Forester 2.5XT - Infiniti FX37S
VAND PEUGEOT 307 CC
VAND SAAB 9-3 1.8t
28-07-06, 23:45
Ferrari si-a pierdut din po****rite in ultimii ani, nush de ce. Pentru ca masinile facute de ei sunt excelente, dar probabil ca nu au o personalitate asa puternica ca si Lambourile(sczti cacofonia). Sunt mult mai discrete ferrariurile acestea noi.
29-07-06, 10:10
Tocmai de asta
21-08-06, 15:00
Diferentza de clasa si de brand dintre italience (Ferrari, Lambo) si cele doua americane este aceeasi cu diferentza dintre un costum Armani si unul facut la o croitorie din Barlad...
21-08-06, 22:34
Eu as alege Corvette-ul pentru performatele lui, stiu ca nu e o masina care are foarte multa faimaprecum Ferrari sau Lamborghini , si nici siguranta nu cred ca e foarte buna, dar totusi, are un raport extrem de bun calitate/pret, din cate am inteles punctul slab este motorul care poate sa il sece in 15 minute sau 20 nu mai stiu exact(asa am inteles de la TOPGEAR).
Asta in cazul in care as avea nevoi de performante puternice, daca e sa o folosesc la o plimbare sau pentru o calatorie , as alege f430-ul care imi place la design si care e si o masina exceptionala si ea.
Dar sa revenim la topic -=[sa aleg doar una]=- as alege corvette-ul
23-08-06, 14:50
Member of: [Competitor CNCA]
dodge viper srt-10
Daca am bani sa il iau inseamna ca imi permit sa stau toata ziua pe strada si prin benzinarii!!! Banuesc ca stiti de ce?!?! 8000 cc!!!!!!!!!!!!
Cum o fi sa accelererzi cu un asemenea motor!?
24-08-06, 23:13
corvette-u e cea mai buna decizie (e si mai ieftina un pic)
26-08-06, 17:56
corvette este o masina urata..modelul nou...viper e ceva special...super masina...ferrariul .....demential
13-10-06, 16:34
salbaticul f 430 pentru mine
