View Poll Results: Mercedes vs. Audi vs. BMW
Mercedes E 55 AMG 10 19.61%
Audi RS6 16 31.37%
BMW E39 M5 25 49.02%
Voters: 51. You may not vote on this poll
Old 05-07-07, 11:43   #1
Cristy65
Cristy65's Avatar
Default Mercedes vs. Audi vs. BMW
3 masini de la cele 3 producatori importanti:Audi RS6,Mercedes E 55 AMG si BMW E39 M5
Mercedes E 55 amg:
Configuration AMG 5.4 Liter Supercharged V8
Valvetrain SOHC 3 Valves / Cylinder
Displacement 5439 cc / 331.9 cu
Power 355 kW / 476.1 bhp at 6100 rpm
Torque 700 Nm / 516.3 ft lbs at 2650 rpm
Bore 97 mm / 3.8 in
Stroke 92 mm / 3.6 in
Compression Ratio 9:1
Bhp / Liter 87.52 bhp
Redline 6500 rpm
Gear Type 5 Speed Automatic w/ Speedshift
Top Speed 249.9 kph / 155.3 mph
0 - 62 mph 4.7 seconds
Powertrain Layout Front Engine / RWD
Audi RS6
Configuration 4.2 Liter Biturbo V8
Valvetrain DOHC 5 Valves / Cylinder
Displacement 4172 cc / 254.6 cu
Power 335.6 kW / 450.0 bhp at 5700 rpm
Torque 560 Nm / 413.1 ft lbs at 1950 rpm
Bore 84.5 mm / 3.3 in
Stroke 93 mm / 3.7 in
Compression Ratio 9.3:1
Bhp / Liter 107.86 bhp
Gear Type 5 Speed Tiptronic
0 - 62 mph 4.9 seconds
Powertrain Layout Front Engine / Full-Time 4WD
BMW E39 M5
Configuration 4.9 Liter V8
Valvetrain DOHC 4 Valves / Cylinder
Displacement 4941 cc / 301.5 cu
Power 298.3 kW / 400.0 bhp at 6600 rpm
Torque 500 Nm / 368.8 ft lbs at 3800 rpm
Bore 94 mm / 3.7 in
Stroke 89 mm / 3.5 in
Compression Ratio 11:1
Bhp / Liter 80.96 bhp
Redline 7000 rpm
Gear Type 6 Speed Manual
0 - 62 mph 4.8 seconds
ID:	298424   Click image for larger version
ID:	298425   Click image for larger version
ID:	298427   Click image for larger version
ID:	298428   Click image for larger version
ID:	298430   Click image for larger version
ID:	298431   Click image for larger version
ID:	298433   Click image for larger version
ID:	298434   Click image for larger version
Cristy65 is offline   Reply With Quote
Old 05-07-07, 11:48   #2
Cristy65
Cristy65's Avatar
Default Re: Mercedes vs. Audi vs. BMW
si cei de la top gear au ales ...
https://www.youtube.com/watch?v=rnYD5...elated&search=
Old 05-07-07, 13:05   #3
Patrulei
Toyota Driver
Patrulei's Avatar
[SEAT]
[Toyota]
am ales rs6 mi se pare k se duce m`ai mult decat m5 si e55):P
Patrulei is offline   Reply With Quote
Old 05-07-07, 13:57   #4
CJ-01-WOB
Observator 4tuning
CJ-01-WOB's Avatar
[Nissan]
[Mitsubishi]
[Toyota]
ce vrei sa compari la masinile astea ? parerea fiecaruia despre ele ?
CJ-01-WOB is offline   Reply With Quote
Old 05-07-07, 13:59   #5
Cristy65
Cristy65's Avatar
cam asa ceva.
Old 11-07-07, 00:12   #6
Cristy65
Cristy65's Avatar
ce va place mai mult la una si nu va place la cealalta?? plusuri si minusuri
Old 15-07-07, 19:53   #7
Y O B
Y O B's Avatar
Aleg Rs 6 pt ca sunt fan declarat al marcii Audi, dar nu pot sa nu remarc faptul ca si M5 este frumos.
Y O B is offline   Reply With Quote
Old 15-07-07, 22:56   #8
Cristy65
Cristy65's Avatar
m5 este f frumos,intr-adevar,dar per total,in opinia mea,RS6 e peste celelalte.
Old 16-07-07, 00:09   #9
andrei.badea
andrei.badea's Avatar
Am ales M5. E cea mai echilibrata masina, cea mai aratoasa, si se pare ca are si cel mai bun ABS (Jeremy Clarkson spunea ca ABS-u de pe masinile BMW actioneaza exact atunci cant trebuie niciodata prea devreme sau prea tarziu) Si cel mai bun sistem electronic de stabilitate (lucu afirmat de Tiff Neddle, unul din prezentatorii emisiunii 5th gear)
Audi si Mercedes in schimb au cateva mici defecte.
Audi, desi are 50 cp in plus fata de bmw, 30% din puterea totala o pierde datorita tractiunii integrala. Cineva afirma pe forum k numai diferentialul quatro cantareste 100kg.
Mercedes fara TC ar fi extrem de greu de controlat, si cum e tipic Mercedes, astia pun putere si cuplu cu nemilita a.I. sunt nevoiti ori sa limiteze electronic, ori sa intareasca cutiile de viteze si sa puna o gramada de electronice pe masini sa poata fi cat de cat conduse.
andrei.badea is offline   Reply With Quote
Old 16-07-07, 13:06   #10
The_Mask
The_Mask's Avatar
Iar bati campii aiurea!
The_Mask is offline   Reply With Quote
Old 16-07-07, 13:16   #11
!41!
Banned
[Honda]
bmw!!! mercedes nu mi a placut niciodata iar audi sant toate la fel din anii 90 un vw mai de lux ...oricum fata de oricare prefer japonezele
!41! is offline   Reply With Quote
Old 28-07-07, 16:41   #12
JunKer_hP
Old School Cars
JunKer_hP's Avatar
bmw ramne bmw ..defat cine vrea lux ia mercedes cine vrea sport ia bmw ..
JunKer_hP is offline   Reply With Quote
Old 28-07-07, 16:54   #13
Cristy65
Cristy65's Avatar
si cu audi cum ramane? el pe unde este? lux,sport? oricum rs6 este peste m5
Old 28-07-07, 17:15   #14
bebeko
Peugeot Driver
bebeko's Avatar
Audi forever ! Poate totusi mai bine un S8 ...
bebeko is offline   Reply With Quote
Old 29-07-07, 12:22   #15
TURBOSS
TURBOSS's Avatar
1 > bmw - avand + al top speedului+ istoria bogata in mot sportive
2 > mercedes +lux-confort mai ridicat ! daca il bagam in comparatie pe brabus nr.1 !
3 > audi - o combinatie a celor 2 dar neegalata pana in prezent si nu cred ca v-a fii VREODATA !
acesta v-a fii topul mereu ! INTREBATI MOTORISTI ADEVARATI SI OR SA VA RASPUNDA !
TURBOSS is offline   Reply With Quote
