View Poll Results: Care este alegerea ta?
Peugout 306 GTI 149 31.50%
Fiat Bravo HGT 61 12.90%
Golf 4 GTI 263 55.60%
Voters: 473. You may not vote on this poll
Old 25-10-06, 17:36   #1
BASU
BASU's Avatar
Default Peugeot 306 GTI vs Fiat Bravo HGT vs Golf 4 GTI
Peugout 306 GTI
Aerodynamics
Drag coefficient 0.320
Manufacturer Peugeot
Type S-4
DOHC
16 valves total
4 valves per cylinder
Displacement 1998 cc
Compression ratio 10.80:1
Fuel system SFi
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output 167.0 bhp (124.5 kW)@6500 rpm
Max. torque 197.0 Nm (145 lbft)@5500 rpm
Performance
0-100km/h 7.90s
0-Quarter-mile 16.40s
0-Kilometre 29.20s
Top speed 209 km/h (130 mph)
Power-to-weight 137.56 bhp/ton
Weight 1214 kg
Weight distribution (Front) 64.00 %
Fiat Bravo HGT
Manufacturer Fiat
Type S-5
DOHC
20 valves total
Compression ratio 10.70:1
Fuel system SMPFi
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output 152.0 bhp (113.3 kW)@65000 rpm
Max. torque 186.0 Nm (137 lbft)@3750 rpm
performance
0-100km/h 8.00s
0-Quarter-mile
0-Kilometre 29.00s
Top speed 213 km/h (132 mph)
Power-to-weight 127.73 bhp/ton
Volkswage Golf 4 GTI
Engine
Engine code AUM
Engine type Otto, Front transversal
Number of cylinders 4, In-line
Engine capacity 1781 cm3
Number of valves 20 DOHC
Fuel Petrol, Injection by cylinder
Supercharging Turbo + Intercooler
Compression ratio 9,3
Max Power 150cp 110 kW@5700 rpm
Max torque 210 Nm@1750 rpm
weight 1279 kg
Performance
Top speed 216 km/h
Acceleration 0-100 km/h 8,5 s
Filmul Top Gear Pug 306gti vs fiat HGT vs Golf GTI
ID:	166984   Click image for larger version
ID:	166985   Click image for larger version
ID:	166987   Click image for larger version
ID:	166988   Click image for larger version
ID:	166990   Click image for larger version
ID:	166991   Click image for larger version
'06 Skoda Octavia 2 vRS 2.0TFSI 250CP++ >ex '04 Renault Megane Sedan 1.9DCI Privilege >ex '04 Smart Fortwo 0.7 Turbo
'02 Renault Laguna 2 GrandTour 1.9dCi >ex '79 Dacia 1300 Old School
'99 Daewoo Nubira 1 1.6 16v Automata + GPL >ex '12 First Bike Curier >ex '10 Moto Bike 48cc
BASU is offline   Reply With Quote
Old 25-10-06, 18:13   #2
nadir
Default Re: Peugout 306 GTI vs Fiat Bravo HGT vs Golf 4 GTI
fara sa clipesc am ales golful
lol este vrb de 1,8T the best engine ever ! sa fim seriosi
nadir is offline   Reply With Quote
Old 25-10-06, 18:23   #3
BASU
BASU's Avatar
nu stiu daca motorul 1.8T este cel mai bun... dar este cel mai usor tunabil
dar in configuratia de 150cp ramane in ruma pe langa cei 2 rivali aspirati
Old 25-10-06, 18:30   #4
3SGE
3SGE's Avatar
aleg 306 GTI, pt ca are o cunostinta un 306 LE MANS si am vazut cum merge, deci prin urmare cred ca si 306 GTI trage aproape la fel. Cat despre Fiat HGT nu sunt deloc impresionat.
3SGE is offline   Reply With Quote
Old 25-10-06, 18:58   #5
fuzzy
Dacia Driver
fuzzy's Avatar
aleg Fiat, dar nu pentru performante ci pentru look...performantele nu sunt de neglijat dar nu ma uit la o secunda sau doua pana la suta... desi cuplul golfului imi cam face cu ochiul
fuzzy is offline   Reply With Quote
Old 25-10-06, 20:08   #6
GTI
GTI's Avatar
As alege Pug 306 GTI pt ca Peugeot are experienta in sportul cu motor (nu ma refer aici fata de cei doi rivali) si are cateva legende ale raliurilor si rally-raid-urilor.
Golf 4 GTI e slabutz stock insa se poate obtine destul de multa putere ieftin (chip tuning-ul creste puterea la 192CP) si individualizarea atat exterioara cat si interioara e minima.
Fiat Bravo HGT are un design placut si motor cu un sound foarte placut fiind in 5 cilindrii.Are si curba de cuplu buna.
"Nothing in life is more exhilirating as to being shot at without result - W.Churchill"
GTI is offline   Reply With Quote
Old 25-10-06, 20:51   #7
Eugen_TL
Renault Driver
Eugen_TL's Avatar
asa cum se punea problema si in filmuletz ...pt ce il vrei ! daca vrei sa te plimbi cu mia multi..sa mergi la piata plm alegi GOLF ( imi da si senzatia ca e mai masina decat celelalte doua...) fiatu doar ca design imi place ...iar peugeotul e super simpatic,ador masinutza asta,iar la liniutza si FUN a castigat ... deci daca as vrea o masina sa fie si practica as alege GOLFU daca as vrea o masina doar pt mine mai mica 2 usi PEUGEOTUL.. concluzie: intre astea doua cam grea alegere... totusi ALEG GOLFU
Megane 2 my edition
https://forum.4tuning.ro/110-masina-m...ml#post5673253
Eugen_TL is offline   Reply With Quote
Old 26-10-06, 00:26   #8
tfsi
tfsi's Avatar
peugeotul e foarte reusit,sportiv,accesibil.golf 4 gti e marea dezamagire...dintre toate gtiurile create de ei...iar fiatul nu s-a prea vandut si nu a prea ieshit in evidenta,a fost si lansat intr-o perioada in care fiatul nu avea o imagine prea buna.castigator e peugeotul
Colin Forever!
tfsi is offline   Reply With Quote
Old 26-10-06, 02:43   #9
teddy
teddy's Avatar
aleg 306. singurul ei dezavantaj este ca arata ca o masina de 15 ani vechime.
golful nu il aleg pentru simplu fapt ca a fost una din cele mai mari dezamagiri si rateuri date de Volkswagen.
teddy is offline   Reply With Quote
Old 26-10-06, 09:00   #10
bogdan_wrc
Audi Driver
bogdan_wrc's Avatar
golf. 1.8T ..de 180. si cel de 150. nu numai pt motor, dar si pt feeling. vezi ca in poze nu e pusa corecta imaginea. si asta tot GTI e, cel de 25 de ani
pe locul II vine 306. S16, mai exact
ID:	167253   Click image for larger version
Objects in the mirror tend to disappear
It will never have enough power until I can spin the wheels at the end of the straightaway in high gear
bogdan_wrc is offline   Reply With Quote
Old 26-10-06, 12:51   #11
alin
alin's Avatar
am ales FIAT-ul, pentru design...
alin is offline   Reply With Quote
Old 26-10-06, 13:42   #12
baghy83
306.stock e cel mai puternic.si nu are toata lumea
baghy83 is offline   Reply With Quote
Old 26-10-06, 13:42   #13
GTI
GTI's Avatar
bogdan_wrc,varianta aniversara de 25 de ani GTI e rara,iar varianta de 150CP e slaba.La ce te referi cand spui feeling?
Old 26-10-06, 13:49   #14
bogdan_wrc
Audi Driver
bogdan_wrc's Avatar
la condus. la bord. la cum stai in el. adevarta ca cel de 150 de slab. dar GTI inseamna si ala de 180, nu? si nu e chiar rara! vezi pe mobile.de cate sunt cea de 25 de ani e rara, dar cea de 180 nu inseamna doar cea de 25..get my hint ?
bordul de 306 e urat cu spume, iar la fiat (nu stiu cum e exact la HGT) plactisul e cam calitate slaba. parerea mea.
Old 26-10-06, 15:17   #15
sortex
sortex's Avatar
peugeot dupa mine cred ca e cel mai usor
sortex is offline   Reply With Quote
