CTdez va ofera piese auto second hand la mai bune preturi de pe piata cu cele mai promte servicii din bransa.
Oferim curierat rapid in toata tara, comanda va ajunge la dvs a 2-a zi dupa ce a fost plasata.
Ne puteti contacta oricand telefonic sau prin email.
tel:
0765495934
Piese auto second hand din dezmembrari Opel Astra G (1998 - 2009 / generatia a 2-a) 1.4i, 1.6i, 1.8i 1.7 DT (model GM), 1.7 DTi (model ISUZU), 1.7 CDTi si 2.0 DTi
Motorizari disponibile:
- 1.4i 16V (benzina), putere: 90cp / 66kw, tip motor: X14XE;
- 1.6i 8V (benzina), putere: 75cp / 55kw, tip motor: X16SZR;
- 1.6i 16V (benzina), putere: 100cp / 74kw, tip motor: X16XEL;
- 1.8i 16V (benzina), putere: 115cp / 85kw, tip motor: X18XE1;
- 1.7 DT “Motor GM” (diesel), putere: 68cp / 50kw, tip motor: X17DTL;
- 1.7 DTi “Motor Isuzu” (diesel), putere: 75cp / 55kw, tip motor: Y17DT;
- 1.7 CDTi (diesel), putere: 80cp / 59kw, tip motor: Z17DTL;
- 2.0 DTi (diesel), putere: 82cp / 60kw, tip motor: X20DTL;
- 2.0 DTi (diesel), putere: 101cp / 74kw, tip motor: Y20DTH;
Caroserie:
- Hatchback (5-door hatchback)
- Caravan (5-door estate)
Dotari:
- ABS, cutie de viteze 5+1 trepte, aer conditionat A/C, geamuri electrice, oglinzi electrice, trapa electrica, 4 X Airbag, comenzi volan, computer de bord, proiectoare, radio CD kenwood, bare portbagaj, jante tabla cu cauciucuri iarna 195/65 R15 4si 5 prezoane, jante aliaj oem R15 si R16.
Piese in stoc:
Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi;
Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere;
Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela;
Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta;
Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei;
Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager;
Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera;
Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara;
Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum;
Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate;
