Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Dezmembrari si Piese SH
Old 04-07-13, 07:36   #1
dezmembrariconstanta
Default Dezmembrez Opel Astra G 1.4i, 1.6i, 1.8i, 1.7 DT si DTI, 2.0 DTI hatchback si caravan
Dezmembrez Opel Astra G 1.4i, 1.6i, 1.8i, 1.7 DTI (Isuzu) si 1.7 DT (GM), 2.0 DTI an fabricatie 1998 - 2005, caroserie hatchback si caravan. 1.4i 16V 66kw (90cp) tip X14XE, 1.6i 16V 74kw (100cp) tip X16XEL, 1.8i 16V 85kw (115cp) tip X18XE1, 1.7 DT (model GM) 50kw (68cp) tip X17DTL, 1.7 DTI (model ISUZU) 55kw (75cp) tip Y17DT, 2.0 DTI 60kw (82cp) tip X20DTL. cu ABS, cutie de viteze 5+1 trepte, aer conditionat A/C, geamuri electrice, oglinzi electrice, trapa electrica, 4 X Airbag, comenzi volan, computer de bord, proiectoare, radio CD kenwood, bare portbagaj, jante tabla cu cauciucuri iarna 195/65 R15 4si 5 prezoane, jante aliaj oem R15 si R16.
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capotaportbagaj/haion, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa injectie, pompa benzina, ECU, calculator pompa injectie EDU, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompaservo directie, brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbagsofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
dezmembrariconstanta is offline   Reply With Quote
