Go Back   Forum 4Tuning > Comunitati 4tuning locale > Comunitati locale si internationale 4Tuning > Alba Iulia
Old 26-08-07, 20:30   #1
hoinar
hoinar's Avatar
[Honda]
Default Baia Mare 26 august 2007
am fost, am vazut, a fost super!!! pacat de ploaie... o organizare foarte buna, masini frumoase, liniutze... la drift nu am mai stat... vin si pozele minteni...
un prim filmuletz l-am uploadat aici https://forum.4tuning.ro/showthread.p...=1#post1065371
CHALLENGE TURNS AVERAGE INTO GREAT
1. '93 CRX DelSol 1.6 VTEC ESI 125 CP
2. '08 Civic 5D Sport 1.8 VTEC 140 CP
hoinar is offline   Reply With Quote
Old 26-08-07, 22:05   #2
hoinar
hoinar's Avatar
[Honda]
Default Re: Baia Mare 26 august 2007
alt filmuletz...
Old 27-08-07, 12:58   #3
bogdan100
[Honda]
la cum imi merge netu akm,nu pot sa descarc filmele...pozele le pui cand vi de la servici?
bogdan100 is offline   Reply With Quote
Old 27-08-07, 20:07   #4
hoinar
hoinar's Avatar
[Honda]
iaca si primele poze de la show... enjoy
ID:	330866   Click image for larger version
ID:	330867   Click image for larger version
ID:	330872   Click image for larger version
ID:	330873   Click image for larger version
ID:	330875   Click image for larger version
ID:	330876   Click image for larger version
Old 27-08-07, 20:25   #5
hoinar
hoinar's Avatar
[Honda]
inca o tura de poze
ID:	330879   Click image for larger version
ID:	330880   Click image for larger version
ID:	330882   Click image for larger version
ID:	330884   Click image for larger version
ID:	330887   Click image for larger version
ID:	330888   Click image for larger version
ID:	330890   Click image for larger version
ID:	330891   Click image for larger version
Old 27-08-07, 20:44   #6
hoinar
hoinar's Avatar
[Honda]
si inca una
ID:	330942   Click image for larger version
ID:	330943   Click image for larger version
ID:	330945   Click image for larger version
ID:	330946   Click image for larger version
ID:	330949   Click image for larger version
ID:	330950   Click image for larger version
ID:	330952   Click image for larger version
ID:	330953   Click image for larger version
Old 27-08-07, 20:47   #7
hoinar
hoinar's Avatar
[Honda]
cred ca imaginile vorbesc de la sine... a fost un show super...
cine vrea restul de poze si filmuletele, le pot pune pe un cd sau imi dati un stick de minim 1 giga.
Old 28-08-07, 12:12   #8
raul_bogdan_2005
raul_bogdan_2005's Avatar
salut poti sa intri te rog pe ID de yahoo: raul_bogdan_2005 sa vb despre cd
Toate cele bune.
raul_bogdan_2005 is offline   Reply With Quote
Old 02-09-07, 19:02   #9
Bogyciu
Bogyciu's Avatar
Poze cu Loganul de la Pro Street ai? Pune sa vedem si noi care nu am ajuns pana acolo...
Old 04-09-07, 00:14   #10
Bilutz
Bilutz's Avatar
ehehe...la loganu ala modificat de maramures...bara din fatza seamana cu cea de pe seria 3 compact e46 cu kit M......
Bilutz is offline   Reply With Quote
Old 24-03-09, 10:36   #11
vwxy711
Thumbs down Grind WOW Gold with Priest
Without doubt, Priest is not the best wow gold grinders around, but given the right spec and if you know where to grind, you can fare off pretty well. As a Priest, even a shadow Priest, you would have to struggle to earn your money and repair costs from instances and raids forced many priests to buy wow gold, simply because it was the only way to keep them going in the game.Fortunately, The Burning Crusade brought a lot of grinding advantages for Priests and despite the fact that you'll still be pulling your hair out if you try to grind world of warcraft gold with a holy spec, at least the discipline and shadow specs work quite nicely in particular the latter when it comes to grinding.When you're off to grind wow gold with your Priest, put on the best damage gear you have but don't cut down on your stats too hard if you have a choice. There's an exception though. As usual, spirit is the most important stat for Priest but for wow gold grinders, in fact it is not that important since you are stacked up on Mage water or inner water. Just as spirit, intellect and stamina are quite important as well, since intellect will determine the depth of your mana pool and your critical hit chance whereas stamina will give you a higher health pool that can keep you alive in some intense grinding situations. The equation is like this when grinding for wow gold as a Priest: spell damage, intellect, stamina, spirit. Why intellect over stamina? Because a Priest's life is his mana pool and whereas you can survive with low HP but a lot of mana, you won't be able to do so if you have full HP but no mana.Mobs have a higher resistance to shadow, but there are several good grinding spots have mobs which make Priest less good at grinding gold from those places when compared to other classes. Those are good areas for Priest like Zangarmarsh. Let's take a look at it. Although motes of life are not as expensive as motes of fire, air or mana, they're very easy to get in the Dead Mire, since the mobs there are low level and are not very dangerous. We found it best to AOE grind with a Power Infusion + Holy Nova discipline/holy spec, but gathering them up and DoTing should work. This is definitely one of the easiest sources of World of Warcraft gold you'll get as a Priest.http://www.mmorpgvip.com/news/Grind-...th-Priest.html
vwxy711 is offline   Reply With Quote
