Va salut! cer si eu cateva pareri despre doua pachete de bass daca se poate, este vorba de:
1)
http://www.************/produse/Subw...B30_Bass_Pack/
si
2)
http://www.**************/promotii/m...bass-pack.html
a) legat de amplificator cel de la magnat are 1x150 iar cel mac are 1x240 ce parere aveti, care este mai bun?
b) sealed sau bass-reflex?
multumesc!
Subwoofer Mac Audio MPX Box 112
subwoofer de 30cm in incinta bass-reflex
putere nominala - 250W RMS
putere maxima - 800W
raspuns in frecventa - 24-500Hz
sensibilitate - 90dB
impedanta - 4ohmi
Amplificator Mac Audio MPX 2500
amplificator auto 2 canale
putere:
4 ohmi, stereo: 2 x 80W RMS
2 ohmi, stereo: 2 x 120W RMS
4 ohmi, in punte: 1 x 240W RMS
raspuns in frecventa: 5 - 50000 Hz (-3 dB)
THD < 0,05% (1 kHz)
SNR > 100 dB
filtre LP si HP variabile 40-300 Hz
bass boost variabil 0-12 dB
dimensiuni: 239 x 59 x 226 mm
Subwoofer Magnat Edition B30
subwoofer de tip sealed cu difuzor de 30cm
putere: 250W RMS (800W max)
raspuns in frecventa: 25-250 Hz
SPL: 91 dB
impedanta 4 ohmi
greutate: 11kg
dimensiuni: 430 x 390 x 355/ 265 mm
Amplificator Magnat Edition Two
amplificator stereo, 2 canale
putere:
4 ohmi, stereo: 2 x 55 W RMS
4 ohmi, in punte: 1 x 150 W RMS
2 ohmi, stereo: 2 x 75 W RMS
stabila la 2 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
bass boost variabil 0 - 12 dB la 45 Hz
filtru low pass variabil 40 - 300 Hz (12 dB)
filtru high pass variabil 40 - 300 Hz (12 dB)
selector mod de functionare 2/1 canale
circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
