Old 13-12-09, 11:36   #1
v1p3r_21
Smile Sfat . Doua subwoofere in paralel?
Am un amplificator MAGNAT edition two limited
amplificator stereo, 2 canale
putere:
4 ohmi, stereo: 2 x 75 W RMS
4 ohmi, in punte: 1 x 220 W RMS
2 ohmi, stereo: 2 x 110 W RMS
stabila la 2 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
bass boost variabil 0 - 12 dB la 45 Hz
filtru low pass variabil 40 - 300 Hz (12 dB)
filtru high pass variabil 40 - 300 Hz (12 dB)
selector mod de functionare 2/1 canale
circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
SI 2 x subwoofer JBL 250 rms , 1000 max TUB .
subwoofer bass reflex, diametru 30 cm
putere: 250 W RMS (1000W max)
SPL (2,83V/1 m): 90 dB
raspuns in frecventa: 35 - 200 Hz
impedanta: 4 Ohm
dimensiuni: 346 x 660 mm
Pot lega la acest amplificator cele doua subwoofere????? Astept un raspuns . Multumesc!
v1p3r_21 is offline   Reply With Quote
Old 13-12-09, 12:01   #2
animalutz
animalutz's Avatar
[Street Gambler]
Default Re: Sfat . Doua subwoofere in paralel?
Da, poti sa le legi, daca vrei sa faca partz partz. Abia daca amplificatorul ala duce unul din minunatele alea tuburi, daramite doua.
animalutz is offline   Reply With Quote
Old 06-01-10, 02:37   #3
Stage1
Stage1's Avatar
Ai nevoie de minim 400 w sinus, deci da, alt amplificator.
