Old 02-08-06, 12:48   #1
danuuu
danuuu's Avatar
Default ce parere aveti de jbl?
ce parere aveti de?sunt in plop tare la de astea!sunt bune cat de cat?
http://www.************/produse/Subwoofer/JBL/GTO_1204BR/
http://www.************/produse/Amplif.../JBL/GTO_75.4/
ID:	133288   Click image for larger version
danuuu is offline   Reply With Quote
Old 02-08-06, 14:27   #2
steaua23
steaua23's Avatar
[Colectionar Machete]
Default Re: ce parere aveti de jbl?
gto e seria cea mai slaba de la jbl. nu te lua numai dupa aspect.
eu in 11 mil as alege altceva ...
Old 02-08-06, 14:50   #3
danuuu
danuuu's Avatar
cam ce?da-mi o idee te rog!
Old 02-08-06, 15:01   #4
BAD_MF
BAD_MF's Avatar
Pai daca gto e cea mai slaba de csi ce mai zici?
BAD_MF is offline   Reply With Quote
Old 02-08-06, 18:25   #5
bogdnici
bogdnici's Avatar
seria power de la jbl
amplifu nu merge cu woof deci woof are asa ...rms--300W, iar amplif are 104 rms x 4 ch , sfatul meu daca vrei woof asta ia celputin amplifu GTO 301.1 MINIM ,are 204 rms 1 ch.....
S M
bogdnici is offline   Reply With Quote
Old 02-08-06, 18:27   #6
bogdnici
bogdnici's Avatar
sau gto 601.1 ----424 rms 1 ch 4 ohm
Old 03-08-06, 07:19   #7
danuuu
danuuu's Avatar
totusi cred ca pana la urma merg pe infiniti!dupa sfatul mai multor colegi de pe forum cred ca aleg infiniti!
http://www.************/produse/Subwoo...ity/REF_1200B/
si statie
1.http://www.************/produse/Amplif...ity/REF_7541A/
sau
2.http://www.************/produse/Amplif...nity/REF_611A/
Old 03-08-06, 09:53   #8
tico_rs
Speed Daemons Member
tico_rs's Avatar
[Speed Daemons]
in plus difuzorul ala e cel mai recomandat pt sealed si el e in reflex... statia nu e chiar asa slaba, eu am auzit un gto intr-un sealed mult mai mic decat recomandarea jbl, pe un gto2000 si suna f tare, dar pachetul e cam scump, iar 1202 se aude cel mai bine in alta incinta...
daca singura scula de care dispui e un ciocan tinzi sa vezi orice problema ca pe un cui...
Speed daemon...
tico_rs is offline   Reply With Quote
Old 03-08-06, 10:34   #9
danuuu
danuuu's Avatar
merg pana la urma pe infinit(subwooferul este deja ales)!
deci intreabarea mea este!
doar ca ma mai intereseaza statia potrivita pt subwoofer!
Old 04-08-06, 12:23   #10
tico_rs
tico_rs's Avatar
[Speed Daemons]
ampul ala nu e asa de rau, ti-am spus eu l-am auzit pe 200 w rms si suna f bine, nu se simtea lipsa de putere, iar asta are app 300 rms...
Old 05-08-06, 05:43   #11
blak
Banned
blak's Avatar
Bogdnici esti tare man!
Tu recomanzi amplificatorul JBL GTO301.1 care are doar 204W RMS@4ohm...
cand subwoofer-ul are impedanta 4ohm....
O statie mai slaba decat cea care a fost aleasa de danuuuu.... de putere mai mica ) si pe 2 canale...
Eu sincer as merge tot pe cea cu 4 canale in locul lui .... nu as lua 301.1 , plus ca mai are loc pe amplificator si pentru boxe si nu in ultimul rand e mai puternic....JBL GTO 75.4
Bafta!
Old 05-08-06, 08:53   #12
bogdnici
bogdnici's Avatar
75.4 are 104w rms x 4 ch dinamic power in 2 ohm 163 w
gto 301.1 are204w rms x 1 ch 4 ohm, 294 w rms x 1 ch in 2 ohm dinamic power 320w in 2 ohm
gto 301.1 este ceva mai apropiata de valoarea subw 300W RMS dar cea mai potrivita este gto 601.1, 424w rms 1ch in 4 ohm
Old 05-08-06, 08:58   #13
bogdnici
bogdnici's Avatar
daca amplifu este mult prea mic pt woofer stii ce se intampla nu?
ref 611A da bine , acuma fiecare alege ce ii place ))
Old 05-08-06, 09:21   #14
bogdnici
bogdnici's Avatar
GTI A 3000 ce zici de ea?
fati rost de un catalog nou
Old 05-08-06, 09:59   #15
GYM
Ia uite-te te rog cat are 75.4 in punte...mai analizeaza o data si ai sa vezi ca e mai slaba 301.1
