Old 28-11-08, 12:06   #1
VFFtuning
VFFtuning's Avatar
Default PROBLEME TWETER ENERGY...byHERTZ
SALUTARE.......AM SI EU O PROBLEMA...UNUL DINTRE TWETERELE DE LA SISTEMUL PE COMPONENTE HERTZ ENERGY GAJAIE BARRRRRRAIE CUM VRETI SA II SPUNEM LA ANUMITE SUNETE MEDII...(VOCE ETC )...MENTIONEZ CA SISTEMUL ESTE CONECTAT LA UN AMPLIF MAGNAT X CITE 560 PARCA PE 4 CANALE DE 70W RMS PE CANAL(ASA ZIC CEI DE LA MAGNAT...EU NU CRED.. )IM MODUL 3 CANALE....2 PE FATA CARE AMPLIFICA MID BASII SI INALTELE CU FILTRELE SETULUI......SI 1 SPATE PUNTE PTR SUB.....CEVA IMPRESII....CHIAR ASA PROASTE SUNT HERTZURILE????
LIBERTATE PENTRU ULTRASI!!!!
VFFtuning is offline   Reply With Quote
Old 28-11-08, 12:59   #2
AlexBanu
AlexBanu's Avatar
Default Re: PROBLEME TWETER ENERGY...byHERTZ
Man cred ca exagerezi..au fost montate de tine sau la un service specializat?
Old 28-11-08, 15:01   #3
Maske
Maske's Avatar
hertzurile nu sunt proaste...mai repede cred ca reglajele de la ampif nu sunt facute cum trebuie!
Maske is offline   Reply With Quote
Old 28-11-08, 18:14   #4
VFFtuning
VFFtuning's Avatar
ASA MA GANDEAM SI EU..... CA EXAGEREZ DAR ESTE PE BUNE......DIF Le Am MONTAT LA UN SERVICE autorizat...DAR ERAU PUSE PE UNITATE DIRECT...APOI AM MONTAT EU STATIA.....INCA DE LA INCEPUT AM SESIZAT O MICA BARAIALA PE TWETERUL DIN DREAPTA DAR NU AM DAT IMPORTANTA MA GANDEAM CA ESTE DIN MP3 PROST TRASE......DAR PARCA USOR USOR A LUAT AMPLOARE.......LA VOLUM MAI MARE SA ZIC UN 75% la suta din putere.......la unele frecvente medii...barrrrrrrrie.....poate s au bulit filtrele....nu stiu ce sa zic....
ID:	712981   Click image for larger version
ID:	712982   Click image for larger version
Old 28-11-08, 18:28   #5
AlexBanu
AlexBanu's Avatar
E clar ca le-ai reglat cum tb....=)) bafta
Old 28-11-08, 18:36   #6
VFFtuning
VFFtuning's Avatar
multumesc...oricum sunt montate pe masina de serviciu.....am vrut ceva mai bun.....
Dar pe viitor as vrea sa iau niste dif ptr masina mea....ma gandeam la helix r6 competition sau hertz hi energy......cine le cunoaste..poate imi da cineva idei, sfaturi.....
Old 28-11-08, 18:40   #7
AlexBanu
AlexBanu's Avatar
Daca o sa le montezi singur e clar ca peste ceva vreme or sa fie si alea chiar atat de proaste!!! Parerea mea e ca daca nu te pricepi nu te baga. Mai bine dai un ban unora care fac asta zilnic si totodata pot raspunde ei pentru greseli insa nu mai acuza o firma ca este proasta atat timp cat nu ai experinta necesara..
Old 28-11-08, 18:51   #8
VFFtuning
VFFtuning's Avatar
man...nu sunt chiar nestiutor.....am invatat si eu sa leg o unitate pe masina un amplif...niste boxe un sub.....nu sunt expert dar stiu cum sa ascult muzica.....nu distorsiuni....din cauza asta am optat ptr hertz...nu am zis ca hertz este o firma proasta din contra o consideram printre cele mai bune....dar am fost surprins.......asta este asa s a nimerit.....doar am intrebat si eu daca au avut probleme si altiii......
Old 16-01-09, 11:55   #9
Maske
Maske's Avatar
banuiesc ca ai garantie la ele!!!
Old 21-01-09, 17:23   #10
VFFtuning
VFFtuning's Avatar
nu am!!!!
Old 09-04-09, 11:19   #11
VFFtuning
VFFtuning's Avatar
salutare din episodul ''tweterul cu probleme'' revin cu noi dezvaluiri senzationale.......se spune ca cel mai destept cedeaza asa ca azi dimineata l am gasit '' cazut la datorie'' se pare ca nu a mai suportat perversiunile acustico decimbele din partea mea si...a aparut gaura neagra.....pozele vorbesc......mentionez ca nu le am atis niiodata membrana si nu le am scos grila de protectie......inca mai functioneaza si parca s a mai atenuat barrrraitul......ce ziceti senzational???? poate avea scapari pe la filtre????? ce la facut sa ajunga in halul asta????
ID:	866280   Click image for larger version
ID:	866281   Click image for larger version
Old 09-04-09, 12:35   #12
Maske
Maske's Avatar
cumparati modelul nou...sunt din matase
Old 09-04-09, 21:36   #13
margineanu ovidiu
margineanu ovidiu's Avatar
este un proverb care zice ca impotriva surzimii nu este tratament,eu si multi altii am dat in seria energy si cu peste 150w si nu au avut nimic,merg si azi dupa 2ani si ceva la al treilea utilizator chiar,parerea mea este ca din cauza distorsiilor ce le baga amplificatorul tau in ele(care tie ti se pareau un gajait,si totusi i-ai dat in gura mai departe in loc sa mergi sa ceri o parere a unui specialist,care nu cred ca te costa nimic)ai reusit sa topesti calota aceea,nu ai pus niciodata mana pe ele sa le vezi cat de fierbinti erau?ca fapt divers am avut acelasi amplificator cam doi ani legat in aceeasi configuratie ca si tine si dupa 2-3luni am ars inaltele si mediile la ambele difuzoare,erau coaxiale de 20cm pe 3 cai,si am primit acelasi raspuns pe care ti-l dau si eu in inceputul postului,incet am luat un amplificator mai bun,am invatat pe pielea mea sa reglez corespunzator un amplif(ca si eu am zis ca nu e mare lucru pana au aparut problemele).am platit si eu aceasta scoala scump dar asta e,omul cat traieste invata.daca nu ma insel acel tweeter este mort ,nu cred ca se mai poate face ceva cu el,cat despre filtru el mai opreste din distorsii,dar nu e nici el perfect.....oricum nu in gama asta.cam atat despre parerea mea....
TEAM SQNLL
DIY Mobile Audio
7ch active,audison&soundstream&u dimension
scanspeak D2904/7100,15M ,21W/8554-00,jl12w7,d511r,h701,400bt,2xhollywood spv20,2xspv45
margineanu ovidiu is offline   Reply With Quote
Old 10-04-09, 12:03   #14
VFFtuning
VFFtuning's Avatar
OVIDIU MULTUMESC PENTRU SFATURI CARE PENTRU MINE SUNT BINEVENITE.....NU SUNT GENUL CARE MA SUPAR DACA SUNT CRITICAT.....DIN GRESELI SE INVATA CUM ZICI TU.....AM SI UN AMPLIF AUDISON SRX 2 CARE IL TIN PE BARA DEOCAMDATA....AM VAZUT CA SE INCALZEAU CATEODATA.....CULME INCA FUNCTIONEAZA TWETERUL NU SE STIE PANA CAND SI CU SIGURANTA NU LA PARAMETRII LUI.......DECI TU ZICI CA STATIA AR PUTEA FI VINOVATA PE LANGA MINE, ORICUM STIU CA NU ESTE ASA PUTERNICA DAR CRED CA ESTE DESTUL DE PROASTA SA BAGE DISTORSIUNI CARE SA DISTRUGA DIFUZOARELE.....ORICUM MERGEAM CU INALTELE LA ZERO DIN UNITATE SI DIN AMPLIF ERAU TAIATE JOASELE DE HPF PE FATA DAR MEDIILE ERAU LA +3 SI AM CAM DAT IN ELE CU VOLUM MARISOR DAR PAN A LA LIMITA DISTORSIUNILOR PTR URECHEA MEA BINEINTELES
Old 10-04-09, 18:37   #15
saxo
saxo's Avatar
NU mai scrie cu majuscule !
