Old 30-01-13, 18:51   #1
Teo_730
Default Subwoofer & Amplificator
Salut! As vrea sa imi cumpar un amplificator si un subwoofer si am in vedere doua produse. Vreau sa va cer parerea daca acestea doua s-ar "potrivi".
Subwoofer MAC AUDIO MX TUBE 30
Diametrul difuzorului 30 cm
Putere RMS: 240 Watt
Putere maxima: 480 Watt
Impedanta: 4 Ohmi
frecventa de raspuns:20 - 200 Hz
Amplificator Sony Xplod 350w Xm Zr602
Maximum Output Power: 2 Ch x 110W at 4ohm
Maximum Output Power: 1 Ch x 350W at 4ohm
Maximum Output Power: 2 Ch x 150W at 2 ohm
Rated Output Power: 2 Ch x 60W at 4 ohm(1.0% THD)
Rated Output Power: 1 Ch x 130W at 4 ohm (0.1% THD)
Teo_730 is offline   Reply With Quote
Old 31-01-13, 16:02   #2
PUIU 82
PUIU 82's Avatar
Default Re: Subwoofer & Amplificator
Cauta alt amplificator......asta e prea slab pt subwooferul tau.
Ideal ar fi un monobloc,dar merge si un 2 canale in punte......
Oricum cauta ceva care sa aiba minim puterea subului,ideal mai mare.
Bafta!
Dacia SupeRnova B-26-HFC.
FORZA RAPID!
PUIU 82 is offline   Reply With Quote
Old 02-02-13, 22:17   #3
fazekasnfs
fazekasnfs's Avatar
trebe un amplif care stie
Putere RMS: 240 Watt pe 4 ohm
sau 250
fazekasnfs is offline   Reply With Quote
