Old 31-05-11, 13:16   #1
Golf1
Golf1's Avatar
Default incnta pentru Focal PolyKevlar 38 KX SPL
ce incinta recomandati unui difuzor Focal PolyKevlar 38 KX SPL ?
daca ma poate ajuta cineva si cu ceva dimensiuni as fi recunoscator, multumesc!
asta este tot ce am gasit pe net despre difuzor:
Poly-K 38-KX SPL
38cm Gehäusesubwoofer
38cm Subwoofer für Bassreflexgehäuse.
77mm Schwingspule
Multimagnetsystem (12 x 72mm Magnete).
Maximale Belastbarkeit: 1000Watt
Nennbelastbarkeit: 500Watt.
Wirkungsgrad: 98 dB (2,8V/1m)
Frequenzgang: 30Hz - 1kHz (je nach Gehäuse).
empfohlenes Gehäusevolumen Bassreflex: 60 - 100 Liter
Thiele/Small
PARAMETER
Fs 45,75 Hz
Re 3,9 Ohms
Qes 0,57
Qms 15,3
Qts 0,55
Dia 32,5 cm
Mms 100,48 g
Lvc 1,1 mH
Hbob 21 mm
Hgap 10 mm
Xmax 5,5 mm
Sd 829,58 cm²
Vas 116,4 l
BL 14,01 N/A
Einbaudurchm. 357 mm
Einbautiefe 152 mm
ID:	2025405   Click image for larger version
Mitsubishi Lancer Evolution VI
- All Aluminum, 4G63 Inline-4
- Twin Scroll Turbo w/Intercooler
- DOHC, 4 Valves per Cyl
- 1997 ccm
- kompresija 8.8:1
- 208.8 kw / 280.0 ks @ 6500 rpm
- 372.85 nm
- 225/45ZR17
- Brembro Vented Discs w/4-Pot
- 1360 kg
- 240 km/h
- 5sec 0-100 km/h
Golf1 is offline   Reply With Quote
