Old 16-09-06, 15:17   #1
Swat-Cat
Swat-Cat's Avatar
[SEAT]
Default cele mai tipatoare tweetere
ce recomandatii... roadstar care se gaseste in obor e exclus
eu as miza pe twetere de JBL....ce parereri aveti
Old 16-09-06, 15:32   #2
steaua23
steaua23's Avatar
[Colectionar Machete]
Default Re: cele mai tipatoare tweetere
sa auzi alpine-ul ... sa vezi acolo ce tweetere are
Old 17-09-06, 03:14   #3
tico_rs
Speed Daemons Member
tico_rs's Avatar
[Speed Daemons]
pioneer?
tico_rs is offline   Reply With Quote
Old 17-09-06, 19:38   #4
saxo
saxo's Avatar
Daca vrei cele mai tipatoare, iti dau eu niste drivere motorola
http://www.adelcom.net/MOTOROLA_ksn1188a.htm
Old 18-09-06, 11:49   #5
Swat-Cat
Swat-Cat's Avatar
[SEAT]
ooohhh..ai si hornu (palnia)??? cu cat le dai )))
Old 18-09-06, 12:29   #6
saxo
saxo's Avatar
Evident ca am, vorbim pe PM.
Old 18-09-06, 12:45   #7
fuscobal
Tweeter motorola a' lu Relu cu bass-boost pe el la 60Hz ca mai jos se arde !
fuscobal is offline   Reply With Quote
Old 18-09-06, 13:07   #8
Ground Zero
Guest
Ground Zero's Avatar
Referitor la solicitarea ta, adica sensibilitate mare... iti recomand din noua gama... Ground Zero Competition Line
urmatoarele produse:
- High Power titanium tweeter 60 W, 95 dB, 3 ohm, 2000-22000 Hz
125,44Ron
- High Power horn tweeter 100 W, 104 dB, 3 ohm, 3500-20000 Hz
58,80Ron
- High Power compression tweeter 100 W, 107 dB, 8 ohm, 4000-20000 Hz
211,68Ron
- High Power horn tweeter 100 W, 106 dB, 3 ohm, 3000-20000 Hz
137,20
Preturile includ TVA si sunt pentru 1 buc.
ID:	152386   Click image for larger version
Name:	GZCt 0500b.jpg
ID:	152387   Click image for larger version
Name:	GZCT 2200b.jpg
ID:	152389   Click image for larger version
Name:	GZCT 2500x.jpg
ID:	152390   Click image for larger version
Name:	GZCT 3500b.jpg
ID:	152392   Click image for larger version
ID:	152393   Click image for larger version
Ground Zero is offline   Reply With Quote
Old 24-09-06, 12:36   #9
Swat-Cat
Swat-Cat's Avatar
[SEAT]
da si mie un link despre tweetere...
si zi daca ai dif-uri gen portavoce/goarna /... si sa fie rezistent la apa
Old 25-09-06, 22:50   #10
Swat-Cat
Swat-Cat's Avatar
[SEAT]
hello???.....
Old 25-09-06, 23:23   #11
Ground Zero
Guest
Dear Sir,
Please note that our message ws just an informative one.
For further details please contact us using the folowing address: info@*************
Being involved also in EMMA Romania, and being this year member in the EMMA Judge Team at the EUROFINALS in Bern, right now I am in Munchen in my way back home, also with the three romanian cars that were competing.
So, because you have dificulties as I noticed in comunicating in a decent way, I am sugesting you to contact us on our e-mail. You will get an answer from Audio Plus in the shortest time.
