Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 27-12-10, 20:52   #1
v1p3r_21
Default Renault Clio Sound !
Salut !
Vechea configuratie (de vanzare):
Subwoofer CS 1204T :
* subwoofer bass reflex, diametru 30 cm
* putere: 250 W RMS (1000W max)
* SPL (2,83V/1 m): 90 dB
* raspuns in frecventa: 35 - 200 Hz
* impedanta: 4 Ohm
* dimensiuni: 346 x 660 mm
Amplificator: Magnat Edition Two Limited :
* amplificator stereo, 2 canale
* putere:
o 4 ohmi, stereo: 2 x 75 W RMS
o 4 ohmi, in punte: 1 x 220 W RMS
o 2 ohmi, stereo: 2 x 110 W RMS
* stabila la 2 ohmi
* raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
* bass boost variabil 0 - 12 dB la 45 Hz
* filtru low pass variabil 40 - 300 Hz (12 dB)
* filtru high pass variabil 40 - 300 Hz (12 dB)
* selector mod de functionare 2/1 canale
* circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
Noua configuratie :
Subwoofer : 2 x Alpine SWR-1221D
* KevlarŪ-infused pulp cone
* 1" Santoprene rubber surround
* dual 2-ohm 2" voice coils (make sure your amplifier is compatible)
* frequency response 24-1,000 Hz
* RMS power handling: 300 watts
* Peak power handling 1,000 watts
* sensitivity 87 dB
* top-mount depth 6-15/16"
* sealed box volume: 0.7-1.0 cubic feet
* ported box volume: 0.75-1.75 cubic feet
Amplificator : Kenwood KAC-9152D
# Class-D Monoblock Amplifier
# Bass Boost Level and Frequency Remote Included
# Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
# Variable Input Sensitivity: 200mV - 5V
# Phase Shift: 0° / 180°
# Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
# High- and Low-Level Inputs
# 1 Ohm Stable
# RMS Power Output:
* 500 watts x 1 chan. @ 4 ohms
* 900 watts x 1 chan. @ 2 ohm
# Preamp Outputs: 1 Pair
# Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
# Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Condensator : MNC 1 Farad
* Capacitate: 1.0 Farad
* Tensiune: 20/24 V CC
* Toleranţa: C ą 10%
* Temp. maximă de lucru: 95°C
* Afişaj roşu, semnalizare albastră sau Afişaj albastru, semnalizare albastră
Si asteapta sa fie montat zilele astea Momentan e foarte frig afara !
ID:	1797694   Click image for larger version
ID:	1797695   Click image for larger version
ID:	1797707   Click image for larger version
ID:	1797708   Click image for larger version
v1p3r_21 is offline   Reply With Quote
Old 27-12-10, 23:27   #2
valitataye
valitataye's Avatar
[SEAT]
Default Re: Renault Clio Sound !
Frumoasa configuratia la capitolul bass,dar restul componentelor care sunt?
valitataye is offline   Reply With Quote
Old 28-12-10, 08:59   #3
v1p3r_21
Default Head Unit Sony !!
Sony CDX-GT620U
* Radio-CD/MP3 player cu conector USB frontal
* compatibil: CD-R/RW, MP3, WMA, AAC, ATRAC, ID3-tag, CD-text
* putere: 4x50W (4x26W RMS)/(S-MOSFET)
* convertor DAC 24 biti
* mecanica Drive-S
* display Fluorescent cu 13 segmente
* display: negru
* afisare: alb
* iluminare taste: albastra
* culoare panou frontal: argintiu
* contrast reglabil
* dimmer reglabil
* control magazie CD
* egalizator EQ stageII cu 3 benzi
* raspuns in frecventa: 10Hz - 20KHz (+/-1dB)
* raport semnal/zgomot: 120dB
* BBE-MP Digital
* DSO II (Dynamic Soundstage Organizer)
* tuner FM cu RDS EON
* ABC (control automat al largimii de banda FM)
* BTM
* memorare 18 posturi FM
* 3 perechi de preout-uri RCA (2V)
* 1 intrare auxiliara 2xRCA pe spatele playerului
* filtru LPF pentru subwoofer
* volum reglabil subwoofer
* telecomanda IR RM-X151 inclusa
* panou frontal detasabil
* muting telefon
* conector ISO
* unghi instalare: 45 grade
* dimensiuni: 178 x 50 x 180mm
Difuzoarele sunt cele originale ale masinii care dupa parerea mea sunt ok , se aud destul de bine. Revin cu poze in curand!
Old 28-12-10, 12:11   #4
alex_bmw1992
alex_bmw1992's Avatar
frumoase scule ....ma bucur ca ti.ai prezentat si u masinuta.... multa bafta in continuare
alex_bmw1992 is offline   Reply With Quote
Old 29-12-10, 14:25   #5
v1p3r_21
Poze cu sistemul montat !
Se prezinta de doua ori mai puternic decat sistemul vechi
ID:	1800197   Click image for larger version
ID:	1800198   Click image for larger version
ID:	1800200   Click image for larger version
ID:	1800201   Click image for larger version
Old 29-12-10, 20:48   #6
NeAgA
NeAgA's Avatar
Arrow Re: Renault Clio Sound !
frumos sistem..poate bagi si un video..
bafta
NeAgA is offline   Reply With Quote
Old 31-12-10, 11:00   #7
v1p3r_21
Curand !
Old 03-01-11, 12:21   #8
v1p3r_21
Intrebare pentru cunoscatori ....
Am tinut subwoooferul cateva minute destul de tare...si am constatat ca mi-a topit carcasa unei sigurante de la amplificator. Mentionez ca amplificatorul are doua sigurante de 30 A . .... Practic ma uitam cum se scurge plasticul ala dar siguranta nu a sarit... . M-am interesat si am auzit cum ca prin cablul ce trece de la baterie la amplificator ar trebui sa am o siguranta cu 20 % mai mare decat cea a amplificatorului....iar eu am pe cablul de + o siguranta de 60 A care este egala cu suma celor doua de pe amplificator !!! Care ar fi rezolvarea pentru aceasta problema? Sa pun o siguranta mai mare pe cablul de + ???
Old 03-01-11, 15:12   #9
teddyb
Ford Driver
teddyb's Avatar
dar niste cabluri de curent mai groase te-ai gandit sa pui??de cat le ai acum??
teddyb is offline   Reply With Quote
Old 03-01-11, 20:51   #10
v1p3r_21
Au cam 15 mm diametru ... Nu sunt destul de groase ?
Old 03-01-11, 20:54   #11
teddyb
Ford Driver
teddyb's Avatar
Lasa diametru k nu se pune si plasticu,lita in el cat e?!?c scrie p cablu,AWG sau GAUGE de cat?!?
Old 03-01-11, 20:55   #12
teddyb
Ford Driver
teddyb's Avatar
Fai o foto cu cablu si sectiunea lui...
Old 03-01-11, 21:17   #13
v1p3r_21
Am pus mai multe...
ID:	1806529   Click image for larger version
ID:	1806530   Click image for larger version
ID:	1806532   Click image for larger version
ID:	1806533   Click image for larger version
Old 03-01-11, 21:40   #14
v1p3r_21
L-am intrebat pe cel de la care le-am cumparat ! Sunt de 35 mm Dietz !
Old 03-01-11, 21:44   #15
teddyb
Ford Driver
teddyb's Avatar
Ca dimensiune e bun....c baterie ai?cat iti scade voltaju cand ii dai drumu la muzik?motor oprit sau aprins cand pornesti muzik?
