Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 21-04-14, 17:10   #1
AlexSmL
Default Golf Mk4
Va salut!Masina in cauza e un Golf Mk4 2001 1.9tdi
Va prezint sistemul audio cu scopul de a mai invata cate ceva si de a primi sfaturi ce imi vor folosi
Sistemul in formula actuala (nicidecum finala) este alcatuit din
Alternator 120A +baterie 85Ah
HU - Clarion 778
Tweeter - Micro-Precision 3.28
Midbass - Spl Dynamics HF 6.1 ( http://www.spldynamics.fi/products/s.../hf-6_1-e.html )
Amplificator Tweetere - u-Dimension EL-A52
Amplificator Midbassi - Helix Dark Blue 2
Cabluri audio Spl Dynamics 4mm
Cabluri RCA Home-made Proel
Cabluri Alimentare 70mm 00awg
Distribuitor 0awg Dietz
Sigurante ANL Spl Dynamics
Insonorizant STP, burete , fonomin
Inele MDF
ID:	2974659   Click image for larger version
ID:	2974660   Click image for larger version
ID:	2974662   Click image for larger version
ID:	2974663   Click image for larger version
AlexSmL is offline   Reply With Quote
Old 21-04-14, 17:18   #2
AlexSmL
Default Re: Golf Mk4
cateva poze
ID:	2974667   Click image for larger version
ID:	2974668   Click image for larger version
ID:	2974670   Click image for larger version
ID:	2974671   Click image for larger version
ID:	2974673   Click image for larger version
ID:	2974674   Click image for larger version
Old 21-04-14, 17:25   #3
AlexSmL
poze din instalare
ID:	2974677   Click image for larger version
ID:	2974678   Click image for larger version
ID:	2974680   Click image for larger version
ID:	2974681   Click image for larger version
ID:	2974683   Click image for larger version
ID:	2974684   Click image for larger version
Old 21-04-14, 17:31   #4
AlexSmL
Poze din instalare 2
ID:	2974687   Click image for larger version
ID:	2974688   Click image for larger version
ID:	2974690   Click image for larger version
ID:	2974691   Click image for larger version
ID:	2974693   Click image for larger version
ID:	2974694   Click image for larger version
ID:	2974696   Click image for larger version
ID:	2974697   Click image for larger version
ID:	2974699   Click image for larger version
ID:	2974700   Click image for larger version
Old 21-04-14, 19:38   #5
Dragster
Dragster's Avatar
[Racing Syndicate]
[Honda]
Foarte frumos pana aici, imi place ca insonorizantul e intins bine cel putin asta deduc din poze!! Sfatul meu este sa tai partea de metal din spatele inelelor de MDF. Sa fie pe cat posibil gaura la fel de deschisa pe tot parcurul inelelor de MDF…..
Sant curios pana unde vei duce proiectul si ce vei alege in continuare ca si componente
Dragster is offline   Reply With Quote
Old 21-04-14, 22:50   #6
AlexSmL
Mersi mult, in realitate tabla din interiorul inelelor nu este asa de pronunta cum pare in poze...posibil si din cauza insonorizantului pus in acea zona...oricum o sa i au in considerare sfatul tau
Old 22-04-14, 08:19   #7
pigoo
pigoo's Avatar
pune si celelalte noutati cu amplifuri
pigoo is offline   Reply With Quote
Old 24-04-14, 22:08   #8
valitataye
valitataye's Avatar
[SEAT]
Frumos lucrat!!
valitataye is offline   Reply With Quote
Old 25-04-14, 08:14   #9
geoX
geoX's Avatar
O mica intrebare am si eu.
Cum suna SPL Dynamics HF6.1 ? Au un sunet cat de cat echilibrat si cald? Sau sunt mai tipatoare?
Ma bate gandul sa-mi iau un set, dar nu am avut ocazia sa le ascult si nici nu am gasit vreun posesor sa-mi spuna .
geoX is offline   Reply With Quote
Old 25-04-14, 11:41   #10
AlexSmL
Mersi valitataye
geoX HF-urile se descurca binisor pe multe genuri de muzica, chiar nu sunt tipatoare, coboara bine, au kick...eu le tin taiate jos la 63Hz.
Ca dezavantaje...au nevoie de peste 100w rms (le am testat pe mai multe amplificatore si am observat diferente)...eu le dau momentan 70w rms.
Le lipseste ceea ce au midbassi cu membrana de carton presat(tratat) adica detaliile vocii.(nu ma refer la orice midbass cu membrana de carton)
Daca esti un pasionat al SQului ar fi bine sa le asculti inainte sa vezi daca se preteaza gusturilor tale.
Eu ascult muzica mai "nebuna" dnb, dupstep etc...deci HFurile se descurca pentru gusturile mele.
Old 20-05-14, 21:45   #11
AlexSmL
Salutare,am o problema de ceva vreme cu HU Clarion
Se manifesta printr un mic pacanit in difuzoare si subwoofer la schimbarea melodiilor si a folderelor.
Cunoaste cineva problema?
Old 17-09-14, 18:59   #12
catalinionut229
catalinionut229's Avatar
de la rca-uri cred eu altceva nu cred ca ar putea fi .. am avut si eu problema asta, dar de cand mi-am luat player pioneer si rca -uri facute manual din cablu cordial nu mai am astfel de manifestari
catalinionut229 is offline   Reply With Quote
Old 18-09-14, 00:40   #13
AlexSmL
Salut catalinionut229...nu are legatura cu RCA urile, deoarece se manifesta si inainte sa am sistem amplificat , rca uri etc.
Si daca tot se pune praful pe topicul asta...pun cateva poze
ID:	3029704   Click image for larger version
ID:	3029705   Click image for larger version
ID:	3029707   Click image for larger version
ID:	3029708   Click image for larger version
ID:	3029710   Click image for larger version
ID:	3029711   Click image for larger version
ID:	3029713   Click image for larger version
