salutare,
Sa imi prezint si eu pt inceput sistemul. Masina este un golf2 din 91. Din muzica stoc, am mai pastrat tweeterele in rest montat urmatoarele:
*HU-JVC kd-g331
*Fata-componente sistem pe 10cm de la JVC.
*Spate-coaxiale de la LG(numai sa umple golul de acolo
*Amp-Audio system Mseries-mx 120.2
2-Channel High Power Class-AB amplifier with SMD technology
MOS-FET PWM Power Supply
Stable into 2 ohm stereo per channel and 4 ohm bridged mode
Variable switchable Low Pass Filter from 50 to 300 Hz
Variable switchable High Pass Filter from 25 to 175 Hz
Variable switchable Band Pass Filter from 25 to 175 Hz (HPF) and from 45 to 300 Hz (LPF)
Bass Boost: variable from 0 to 6 dB and from 35 to 90 Hz
Input Sensitivity: variable 200 mV maximum to 8 V minimum
ulti- ay rotection ircuitry: overhead, over ourrent, short circuitry and speaker DC protection
Operating Voltage : DC 10 ~ 16 V power input
Massiv heavy aluminium-heatsink with fan cooling
Wired Remote Controller (Optional
*sub- Audio system radion 12 plus(400w)- in incinta bass-relfex(trebuie sa o mochetez)
La partea conectica si curent stau cam prost: cabluri de 10mm, urmeaza un minim 35mm, baterie 55 Ah, urmeaza un 75-80Ah, un alt alternator si un condensator
in configuratia de mai sus, fara cond, cabluri de 10 mm si baterie pe terminate, la o masuratoare dB a iesit 135
