Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 30-01-13, 13:00   #1
Sega
Sega's Avatar
Default Un Logan MCV
M-am hotarat sa imi prezint si eu sistemul audio, mai mult in scopul de ai incuraja pe cei care nu isi permit scule scumpe.
Am pornit de la un difuzor West CW-10 cu o incinta din OSB legat la un Blaupunkt EMA-260 legat de un Kenwood KDC 4024.
Am luat apoi un Magnat AD380 si un ground zero 2.250 mk2(care s-a ars in mod misterios). Dupa ceva pauza am trecut la Spl Dynamics 1500D si Alpine CDE 111RM.
Am vandut magnatul iar acum am incercat o incinta pentru 2 difuzoare de 15 destul de ieftine( BM 1506).
Configuratia actuala:
Player: Alpine CDE 111RM
Difuzoare: Sony xs-f1326se
Amp subwoofer: Spl Dynamics Ice 1500D
Subwoofer: 2 x BM 1506
Cabluri: Hollywood AWG 4
Cateva poze si filmulete de-a lungul timpului:
Blaupunkt EMA260 + West CW10
Player stock + gzta 2.250 MK2 + Magnat ad380
Player Alpine + Spl D. 1500D + Magnat ad380
Player Alpine+ Spl D. 1500D + 2 x Bm1506
ID:	2674449   Click image for larger version
ID:	2674450   Click image for larger version
ID:	2674452   Click image for larger version
Name:	magnat ad380a.jpg
ID:	2674453   Click image for larger version
ID:	2674460   Click image for larger version
ID:	2674461   Click image for larger version
ID:	2674466   Click image for larger version
ID:	2674467   Click image for larger version
ID:	2674469   Click image for larger version
ID:	2674470   Click image for larger version
ID:	2674474   Click image for larger version
ID:	2674475   Click image for larger version
Sega is offline   Reply With Quote
Old 30-01-13, 13:06   #2
Sega
Sega's Avatar
Default Re: Un Logan MCV
Urmeaza sa montez cablurile AWG 0 si un BIG 3 upgrade. Pe termen lung insonorizare, dif-uri de 16.5 cm , tweetere si amplificare pentru ele.
Aah si inca un filmulet cu tensiunea in momentul de fata:
Voltage drop
-Playerul era la volum 20/35, setarea Subwoofer 10/15, setarea Bass 3/7
Old 30-01-13, 13:17   #3
ludo_ludovic2003
ludo_ludovic2003's Avatar
salut si bine ai venit la sectiunea asta
ai o masina in care se pot face multe ... chiar multe , depinde insa la fel de multe aspecte .
depinde ce vrei sa faci cu masina !
daca mai cari oameni cu masina , daca mai ai nevoie de mai mult spatiu decat o sacosa , daca , daca si iar daca .
in primul rand , daca face plafonul intr-un mare fel , nu inseamna ca ai cine stie ce in masina ! poti face si cu un dif treaba aia poate chiar mai rau , dar nu asta este important in domeniul asta ! izoleaza masina mai bine si se va auzi mai tare inauntru .
spectaculos este cand intri in masina si iti rupe urechile nu cand treci pe strada si te injura lumea ca faci galagie . mare atentie pe partea de izolare a masinii si apoi cu restul ... chiar si daca ramai in configuratia actuala , trebuie izolata masina.
nu te supara dar asa vad eu domeniul asta .
ps. dupa ce termini de izolat masina , poti incepe la altele ... curent spre exemplu si de-abia dupa aia vorbim de detalii minore cum ar fi difuri si amplifuri
mai bine intrebi decat sa mori prost si sa mai ai si pretentia ca le stii pe toate ...
eu intreb!!! voi ????
ludo_ludovic2003 is offline   Reply With Quote
Old 30-01-13, 13:25   #4
Sega
Sega's Avatar
Nu am de ce sa ma supar. Iau cele spuse de tine ca pe ceva constructiv, nu le privesc ca pe o insulta . In afara masinii nu se aude bass mai deloc ci doar mediile si inaltele pt ca pe portierele nu au nici un pic de insonorizare . Iar plafonul este chiar deranjant se aude vibrand mai tare decat se aude subwooferul ). Nu am chiar asa bani pentru insonorizant, ma gandeam sa dau tapiteria jos si sa pun niste pasla mai groasa.
Cea mai ieftina varianta care ar fi?
Old 30-01-13, 13:38   #5
ludo_ludovic2003
cea mai ieftina varianta ar fi aluband ... pe care chiar il aprob pana la un anumit aspect , insa tu acolo ai foarte multa tabla !!! kilometri de tabla . am avut un BMW albastru la care aveam cam aceeasi problema. am rezolvat ina cu cateva bari de fier . adik... am cumparat 2 tevi rectangulare de 15 pe 15 , le-am taiat la dimensiune si apoi am luat fiecare bara si am crestat din 4cm in 4cm ca sa pot sa o modelez dupa forma plafonului . dupa aia am luat un fel de montage kit si am prins teava de plafon ( nu am sudat ca e riscant )
am pus barile astea din 12 in 12 cm ... intre ele am lipit polistiren extrudat de 2 cm .... si lipit cu acelasi silicon . dupa ce faci asa te urci in picioare pe masina ,cel putin eu la bmw ma urcam ...sa incerci sa nu cumva sa strici ceva )
aveam o intrebare .... ai reflex la incinta ? si daca da unde este orientat?
Old 30-01-13, 13:46   #6
Sega
Sega's Avatar
Are si port, suprafata 854/60 mm, lungime parca vreo 720 (in fine, e acordata la 30-31 Hz). In pozele primele poze era pusa la repezeala in masina, am pus`o singur si abia am asezat`o asa, mi-a fost greu sa o intorc singur cum trebuie .
ps: Aluband unde gasesc si la ce pret?
Old 30-01-13, 13:49   #7
ludo_ludovic2003
la orice magazin de materiale de constructii .. 3mp in jur de 250-300 lei sulul
Old 30-01-13, 14:16   #8
Sega
Sega's Avatar
Si alubandul se pune pe toata suprafata usii(de ex) sau doar in anumite zone? Imi spunea cineva ca e inutil sa imbraci toata usa, ca ar terbui sa pun doar pe mijlocul suprafetelor care flexeaza sau ceva de genu( ca sa "creasca frecventa de rezonanta"). Cum fac pana la urma?
Old 30-01-13, 14:20   #9
ludo_ludovic2003
pui pe toata usa , fiecare coltisor trebuie acoperit !!!
intra si cauta pe forumul asta la sectiunea asta si vezi cum alti colegi de forum , au izolat masinile lor... ai multe de invatat de pe forum , dar mult vei invata cu munca !!!
aici vei gasi cam tot ce iti trebuie sa faci o masina buna .... bani trebuie si multa atentie in munca depusa in proiectul vizat ,iar daca tot faci ...fa bine de prima data sa nu fi nevoit sa desfaci si sa muncesti iar !!!
Old 30-01-13, 14:36   #10
alex_bmw1992
alex_bmw1992's Avatar
Salutare domnu' si bine ai venit. Ma bucur ca ti-ai prezentat masina aici. Multa bafta la munca si cat mai multi db
Originally Posted by ludo_ludovic2003 View Post
dupa aia am luat un fel de montage kit si am prins teava de plafon...
poti detalia putin te rog, cu ce anume ai facut legatura.
got hairtrick ?
alex_bmw1992 is offline   Reply With Quote
Old 30-01-13, 15:21   #11
Bigu
Bigu's Avatar
si la 400-450 lei isi cumpara 4mp de material "dedicat" !!!
Parerea mea sa eviti alubandul! Nu o sa faci economie deloc! Ba dimpotriva...
Spor cu proiectul in continuare!
Old 30-01-13, 15:35   #12
Sega
Sega's Avatar
Multumesc pentru urari . Dar aveti idee cam ce suprafata ar avea plafonul si usile? Am gasit pe 4tuning shop niste pack-uri gen "STP Bimast Super Installer Package" si par interesante dar nu stiu cam ce suprafata ar trebui sa acopar.
Old 30-01-13, 15:50   #13
fazekasnfs
fazekasnfs's Avatar
Thumbs up Re: Un Logan MCV
Salut si bine ai venit si spor la lucru in continuare
fazekasnfs is offline   Reply With Quote
Old 30-01-13, 19:57   #14
raresvintea
Bai individule fati o insonorizare calumea si apoi daca vrei amplificare pe portiere vb! Dar evita alubandul totusi, ca la 100 lei iei 1mp2 de STP sau altceva la fel de bun si faci plafonul!
raresvintea is offline   Reply With Quote
Old 30-01-13, 21:17   #15
geoX
geoX's Avatar
Pai ia o ruleta si masoara marimile usilor si plafonului. Se insonorizeaza in general suprafetele lungi. fara ranforsare si fara colturi pentru ca alea flexeaza cel mai usor.Recomandat este sa pui pe toata suprafata zonei drepte de tabla cu toate ca usile la extremitati sunt mai rigide datorita colturilor. Eu am SilentCoat in usi si e foarte bun si e si usor mai ieftin decat STP
Dar cum ai calculat incinta aia pentru BM? Dupa ureche? Pentru ca difuzoarele alea nu vin cu nici un fel de parametru.
Si vad ca ai subwoofer cu difuzor profesional in casa. Cum se aude? Are doar kick sau suna si mai lung asa... ?
geoX is offline   Reply With Quote
