Old 14-09-05, 22:00   #1
alexh
alexh's Avatar
Default Linie Kenwood, cateva sfaturi...
Mai pentru un incepator asa...ca nu am carnetu decat de o luna si masina de cateva zile .
E vorba de un Ford Fiesta din '92 care este chel de sistem audio si din cate am inteles in usile din fata intra boxe de maxim 13 cm. De fapt am si deschis usa si am observat ca la una din ele lipseste inelul de fixare al boxei pe usa....acesta vine o data cu boxa in pachet sau trebuia sa fie al masinii? (fostul propietar a avut ceva pus dar le-a dat jos, au ramas doar cablurile trase)
Am prospectat piata si am gasit nishte scule Kenwood la preturi decente. Mentionez ca nu vreau sa sune foarte puternic, ci destul de clar...
Voi ce parere aveti de ele? Ce mi-ati recomanda in aceeasi bani ( 160 de euro playeru, in jur de 50 bxele si fata si spate) ?
Player: Kenwood KDC-W5031
(cateva caracteristici, le-am pus pe cele care mis e par cele mai importante)
- 4 x 50 watt maximum output power by MOSFET Power IC
- 2 RCA preouts, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
- MP3 en WMA Playback
- CD-R/RW compatible
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- Dual changer control capability (CH1/CH2 & AUX)
Boxe fata : KFC-1389ie
- 3 Way, 3 Speaker speaker system
- 13 cm Pearl Mica Cone with rubber surround
- 25 mm P.E.I. Balnaced Dome Tweeter
- 9 mm P.E.I. Dome Tweeter
- Image Enhancer technology
- Peak input power 150W
Boxe spate : KFC-6989ie
- 4 Way, 4 speaker system
- 6\" x 9” Pearl-mica injection P.P. cone with urethane surrounds
- 50 mm PEI Balanced Midrange
- 20 mm Balanced Dome Tweeter
- 20 mm Dome Super Tweeter
- Image Enhancer Technology
- Peak input power 320 W
- Rated input power 80 W
- Sensitivity 93 dB
- Frequency response 28 Hz - 30 kHz
- Crossover frequency 4k Hz, 12kHz
- Mouting depth woofer 78 mm
- Speaker Impedance 4 ohm
- Magnet weight 340 gr
- Total weight 1420 gr
Ma scuzati daca este prea multa informatie deodata dar nu am vrut sa va fac sa va uitati pe net dupa ele....
ID:	41761   Click image for larger version
ID:	41762   Click image for larger version
alexh is offline   Reply With Quote
Old 14-09-05, 22:06   #2
sfigmo
sfigmo's Avatar
[TIME SQUAD]
parerea mea e ca pornesti gresit din start punand coaxiale pe fata...componentele suna altfel...mult mai bine...baga mana putin mai adanc in buzunar si ia o pereche de difuri cu tweetere separate...bafta
Uischi...I'll never forget you...
sfigmo is offline   Reply With Quote
Old 21-09-05, 20:47   #3
alexh
alexh's Avatar
Multumesc mult pt raspuns, din pacate insa nu am mai multi bani acum probabil ca va trebui sa apelez la ajutor extern Oricum , cu boxele mai vad, mai sondez piata.
A aparut insa o noua varianta in ceea ce priveste CD/Mp3 - playerul si anume Kenwood KDC-W4031. Un model ceva mai slabut ce-i drept, cu mai putine dotari si mai ieftin dar inca acceptabil.
Spre comparatie cu Kenwoodul din primul post (care avea 2), acesta are doar o iesire preamplificata. Ma puteti lamuri si pe mine ce se poate face cu aceasta iesire? La ce foloseste si cum se conecteaza? Sunt incepator dupa cum v-am zis, sper sa nu va agasez cu intrebarile stupide.
Ah si inca o intrebare....am cautat pe net si am gasit ca acest HU ar avea puterea reala (RMS) de 4*30...este plauzibil? Se poate ? Stiu ca in orice caz nu e de 4*50 cat zic ei dar cat sa fie?
Old 21-09-05, 21:56   #4
GYM
Eu nu as merge pe Kenwood, si te sfatuiesc si pe tine acelasi lucru....faci cum vrei Alege intre Clarion, Alpine si Pioneer
Old 22-09-05, 02:26   #5
NILS_BUCURESTI
Midnight Racers Member
NILS_BUCURESTI's Avatar
[Midnight Racers]
Eu am avut Alpine iar acum am Pioneer si recomand aceste marci dar asta nu insemna ca doar ele exicsta pe lumea asta.De Kenwood in schimb nu prea am auzit cuvinte de lauda ,din cate am auzit si eu de pe la lume care a lucrat cu ei in trecut era ceva de capul lor in urma cu multi ani dar se pare ca au si ei probleme acum.De ascultat am ascultat un model la un prieten si nu pot zice ca se batea nici pentru primele locuri dar nici pt ultimele.Oricum sunt sigur ca daca ,,, cauti si pe la altii poti gasi ceva mai bun tot cam in aceeasi bani.Bine ,acum daca ti a cazut tie cu tronc marca/modelul asta asta e (stiu cum e :P )ideea e sa te faca sa te simti bine
Eu nu stiu unde ai gastit tu modelele astea dar daca le ai gasit cumva in Vitan pe partea dreapta primul chiosc dupa ce intrii...SINCER FUGI DE AIA !!! Sunt cei mai TEPARI din targ :P
BAFTA !
NILS_BUCURESTI is offline   Reply With Quote
Old 08-10-05, 23:58   #6
alexh
alexh's Avatar
Salut, scuze de intarziere...
Stai linistit ca nu il iau din Vitan, ci din afara tarii , sper sa nu imi fi luat tzeapa cu el, ca deja l-am luat (e vorba de KDC-w4031).
Acum am o alta problema...
Am cumparat pe fata nishte boxe Clarion ( http://www.clarion-eu.com/be-fr/Ence...c92ceba.0.html ) care nu-s cine stie ....sunt cam slabutze pe partea de bass dar am pus in spate nishte 6*9 care compenseaza detul de bine (cel putin pt posibilitatile mele in acet moment).
Problema e ca dupa ce am facut toata instalatia am constatat un fasiat suspect in difuzorul stanga fata....chiar si cu volumul la minim....stiti de la ce ar putea fi?
Pt boxele din fata, am folosit cablurile care existau pe masina din fabrica ....trebuia cumva sa le folosesc pe cele care au venit cu boxele?In spate asa am facut si nu am probleme...
Multumesc
Old 09-10-05, 01:55   #7
NILS_BUCURESTI
[Midnight Racers]
E posobil ca fasaitul sa fie de la vreo interferenta cu instalatia masinii Intreabal pa SAXO sau ReLLaXX pt a te lamuri,eu nu iti pot sune nimic cu certitudine
BAFTA !
Old 09-10-05, 23:54   #8
saxo
saxo's Avatar
Atita timp cit nu ai folosit amplificator,e foarte ciudat fisiitul intr-un singur difuzor...Fa-ti timp intr-o zi si treci pe la noi sa vedem ce-i p'acolo. ( NU costa bani )
Quality first !
Old 29-10-05, 12:47   #9
alexh
alexh's Avatar
L-am rezolvat, era de la un fir, l-am schimbat si acum totul e bine.
Multumesc de oferta saxo, dar dupa cum am mai spus, nu sunt in Ro momentan
