Mai pentru un incepator asa...ca nu am carnetu decat de o luna si masina de cateva zile
E vorba de un Ford Fiesta din '92 care este chel de sistem audio si din cate am inteles in usile din fata intra boxe de maxim 13 cm. De fapt am si deschis usa si am observat ca la una din ele lipseste inelul de fixare al boxei pe usa....acesta vine o data cu boxa in pachet sau trebuia sa fie al masinii? (fostul propietar a avut ceva pus dar le-a dat jos, au ramas doar cablurile trase)
Am prospectat piata si am gasit nishte scule Kenwood la preturi decente. Mentionez ca nu vreau sa sune foarte puternic, ci destul de clar...
Voi ce parere aveti de ele? Ce mi-ati recomanda in aceeasi bani ( 160 de euro playeru, in jur de 50 bxele si fata si spate) ?
Player: Kenwood KDC-W5031
(cateva caracteristici, le-am pus pe cele care mis e par cele mai importante)
- 4 x 50 watt maximum output power by MOSFET Power IC
- 2 RCA preouts, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
- MP3 en WMA Playback
- CD-R/RW compatible
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- Dual changer control capability (CH1/CH2 & AUX)
Boxe fata : KFC-1389ie
- 3 Way, 3 Speaker speaker system
- 13 cm Pearl Mica Cone with rubber surround
- 25 mm P.E.I. Balnaced Dome Tweeter
- 9 mm P.E.I. Dome Tweeter
- Image Enhancer technology
- Peak input power 150W
Boxe spate : KFC-6989ie
- 4 Way, 4 speaker system
- 6\" x 9” Pearl-mica injection P.P. cone with urethane surrounds
- 50 mm PEI Balanced Midrange
- 20 mm Balanced Dome Tweeter
- 20 mm Dome Super Tweeter
- Image Enhancer Technology
- Peak input power 320 W
- Rated input power 80 W
- Sensitivity 93 dB
- Frequency response 28 Hz - 30 kHz
- Crossover frequency 4k Hz, 12kHz
- Mouting depth woofer 78 mm
- Speaker Impedance 4 ohm
- Magnet weight 340 gr
- Total weight 1420 gr
Ma scuzati daca este prea multa informatie deodata dar nu am vrut sa va fac sa va uitati pe net dupa ele....
