Salut tuturor , am un subwoofer dar s-a stricat difuzorul as vrea sa imi spune-ti daca pot pune alt difuzor in acceasi incinta !
Specificatii Subwoofer stricat :
Sal XC PRO 12 :
SAL PRO XC -12 300W subwoofer
Bandpass subwoofer chrome finish baskets ,
polypropylene,
300 mm in diameter subwoofer -30 cm - 12 inch !
plexiglass and black trim cover,
chrome reflex tubes ,
chrome banana / screw terminals .
Music load of 300W !
Frequency response : 25-150 Hz
Sensitivity: 91 dB
Recommended active crossover breakpoint 120 Hz
Reflex tube diameter 2x90mm
External dimensions ( seed, Depth wind . . . ) : 400x390x410 mm
Magnet Weight : 50 Oz
Weight: 16 kg
iar difuzorul este acesta -
http://www.compari.ro/boxe-auto-c361...s4-p139167606/
Subwoofer 30 cm, Putere 1400W, nom 400 W, 95 Db, 20-250 Hz 4 ohm
Specificatii Tehnice
Subwoofer Auto
Diametru 12 inch (30 cm)
Putere Maxima 1400 W
Putere Nominala (RMS) 400 W
Impedanta 1 x 4 ohmi
Raspuns Frecventa 20 Hz to 250 kHz
Sensibilitate 95 dB/W/m
Santoprene Rubber
Con din Polipropilena
Excursie Difuzor Xmax 8,9mm
Sasiu Aluminiu
Vas 49,5 litri
Adancime instalare 153 mm
Imi puteti spune daca se potriveste ? sau ce difuzor as putea pune in acea incinta ! sau daca se merita ?!
Multumesc !
