Old 22-04-06, 15:25   #1
CataNOS
CataNOS's Avatar
Default sfatuiti-ma in legatura cu sist audio
Hello audiofililor
Vroiam sa-mi iau tel da` pana la urma m-am gandit k e mai bine sa investesc intr-un amplif si woofer pt masina. Bugetul e de 10-12 mil.
Eu m-am gandit la urmatoarele componente:
Amplif:
- DLS CLASSIC CA23
amplificator 2/1 canale
putere nominala:
4 ohm: 2 x 135W
4 ohm in punte: 1 x 400W
2 ohm: 2 x 200W
raspuns in frecventa: 10 Hz - 35 kHz
S/N ratio > 100 dB
filtru trece-sus variabil 15 - 150 Hz
filtru trece-jos variabil 50 - 500 Hz
Bass boost variabil 25 - 80 Hz, 0-18 dB
dimensiuni: 67 x 295 x 250 mm (2,63 x 11,6 x 9,84 inch)
- Mac Audio MP 8000
amplificator pe 2 canale
putere RMS (4 ohm) DIN 45 324, 14,4V
stereo: 2 x 150 W
in punte: 1 x 400 W
putere maxima: 2 x 400 W (1 x 1000 W)
stabil in 2 ohmi (2 x 500 W RMS)
filtru trece-jos variabil 50 - 250Hz (12dB)
filtru trece-sus variabil 40 - 500 Hz (12dB)
bass boost variabil 0 ... 12 dB la 45 Hz
selector mod functionare 2/1 canale
circuit de protectie la scurtcircuit
LED verde / rosu de avertizare
dimensiuni: 358 x 59 x 226 mm
- Magnat The Rock 1000
amplificator 2 canale
putere
4 ohmi, stereo: 2 x 165W RMS
4 ohmi, in punte: 1 x 540W RMS
2 ohmi, stereo: 2 x 260W RMS
putere maxima 1 x 1000W
raspuns in frecventa 5 Hz - 50 kHz (-3dB)
impedanta iesire 2-8 Ohm
bass boost variabil 0 - 12 dB la 45 Hz
filtre low pass si high pass variabile 40 - 300 Hz (12 dB)
- Mac Audio Z2200
stereo: 2 x 200 W
in punte: 1 x 600 W
stabil in 2 ohmi (2 x 300 W RMS)
dimensiuni: 395 x 54 x 293 mm
CataNOS is offline   Reply With Quote
Old 22-04-06, 15:28   #2
CataNOS
CataNOS's Avatar
Default Re: sfatuiti-ma in legatura cu sist audio
Woofer:
- JBL GTO 1200T
Tip subwoofer: GT4-12, Bass-Reflex
Putere RMS: 250W
Putere maxima: 1000W
Raspuns in frecventa: 26Hz - 300Hz
Impedanta: 4 ohms
Sensibilitate (2.83V/1m): 94dB
Dimensiuni (Diam. XL): 550 x 330mm
- Infinity Kappa 120.3se
difuzor subwoofer 300mm
putere RMS: 300W (1200W max)
raspuns in frecventa: 18 - 150Hz (±3dB)
sensibilitate: 94dB
impedanta: 4ohm
inaltime difuzor: 167mm
diametru decupare: 278mm
- Infinity Kappa Perfect 12.1
putere RMS: 350W
putere maxima: 1400W
sensibilitate: 96dB (in car)
raspuns in frecventa: 18 - 150Hz (±1,5dB)
impedanta: 4 ohm
inaltime difuzor: 165mm
Fs: 23.32 Hz
Qts: 0.44
cursa membrana: 28mm
volum recomandat incinta: 83,28 litrii
Levc@1kHz: 3.05 mH
- Mac Audio Maximus 3000
diametru 30 cm
putere: 500W RMS / 1000W max
raspuns in frecventa: 20 - 500 Hz
impedanta: 2x4 ohmi (2/8 ohmi)
SPL: 87 dB
Fs: 19 Hz
Vas: 142 l
Qts: 0..41
Qes: 0..43
Qms: 1.2.7
Xmax: 16 mm
Old 22-04-06, 15:30   #3
CataNOS
CataNOS's Avatar
si la toate astea un kit dietz de 20 mm
cablu alimentare rosu - 5 m (20 mm2)
cablu masa albastru - 1 m (20 mm2)
cabluri RCA + remote - 5 m
papucii necesari
siguranta 60 A
Vreau sa imi ziceti ce woofer si amplif ar merge cel mai bine, sau poate aveti o idee mai buna, dar tot in banii astia sa fie. Ulterior o sa iau si un Dynamat trunk kit, dar deocamdata e bun asa. Trebuie sa pun si condensator cumva? Infinity-urile vin fara incinta, aveti idee unde pot gasi incinte facute special pentru ele?
Multumesc pentru sfaturi
Old 22-04-06, 15:44   #4
CataNOS
CataNOS's Avatar
am uitat sa zic, eu unu prefer mac audio maximus 3000 ca woofer si magnat the rock 1000 ca amplif. ce ziceti? Tre sa imi fac abonament la iaurt pt eventualele pb cu stomacul? )
Old 22-04-06, 18:37   #5
vpower16v
mergi cu DLS ca amplif si woofer infinity Kappa Perfect 12.1 o sa fie super , dar la incinta te ai gandit???
Old 22-04-06, 18:57   #6
CataNOS
CataNOS's Avatar
pai incinta din MDF cat mai gros. Nush, ma uitam acu p specificatii si pe preturi si ma intrebam daca Mac Audio Z2200 de 600W RMS in 4 ohmi nu se merita impreuna cu Mac Audio Maximus 3000..
uite site-ul cu specificatii:
woofer: http://www.mac-audio.de/produkte/pro...327033&lang=EN
amplif: http://www.mac-audio.de/produkte/pro...ser=43&lang=EN
Fiind de la aceeasi firma ma gandesc ca se "pupa" mai bine.. ce zici?
Mai iau si un kit dietz de 20 mm si aia e.
What do ya say?
Old 22-04-06, 19:23   #7
CataNOS
CataNOS's Avatar
vpower, acu am vazut situl din semnatura ta, o sa fac cutia la tine daca e, esti din buc nu? la mac-audio ziceau astia ca ii trebuie cutie de 140 l, nu e pb, o fac pentru o masina cu care nu am de gand sa car chestii. Zi-mi preturi la cutii te rog k p site nu am gasit nik.. Mersi
Old 22-04-06, 20:22   #8
vpower16v
asa pai eu sincer nu as merge cu mac...mie imi plac dls urile , caliatea e mai buna......dar zii si tu la c preturi le ai gasit k poate gasim ceva mai bun mai sunt hertz,ga,jl,jbl etc ...iar treaba cu aceeasi firma sa se pupe bine....e discutabila....kitul ala dietz d 20mm ar fi ff bun...iar incinta o faci unde crezi tu mai bine sunt din buc (preturi p pm) iar 140l aia nu sunt cei necesari unei incinte ci sunt un parametru (vas) care duce la determinarea volumului necesar , litrajul banuiesc k este in manual k p site nu l scrie si nu stau sa fac calcule acum paste fericit tuturor!
gen muzical cautat : manele
Old 22-04-06, 20:37   #9
CataNOS
CataNOS's Avatar
Ampliful 590 ron, Subul - 570 ron, deci 12 mil in total cu tot cu kit
Cutia o voi face ulterior, masina o bag in service pt k nu am mai mutat-o de 3 luni din fata casei ) si am de lucru si la ea.
Oricum, sunt pus p ampliful ala k scoate f bine la banii astia, cat despre woofer... nush ce sa zic, imi pare bun, are structura fagure, magnet de neodymium...
Daca ar fi sa se faca o comparatie intre mac si infinity, adica astea doua woofere pe care le-am enumerat mai sus, care credeti ca suna mai bine. Eu vreau un bass profund si tare, de-ala care sa ma surzeasca pana la 30 de ani Stiu k infinity e mult mai bun ca marca decat mac, dar wooferul asta de 500 w chiar pare ca stie ceva.. Daca are doua bobine merge ampliful Z2200 pe el?
Inca o chestie, sludge de-ala insonorizant gasesc pe undeva? daca da, la ce pret?
Saru`mana pentru raspunsuri.
Paste Fericit
Old 22-04-06, 22:06   #10
decibels
decibels's Avatar
Salut CataNOS. Se pare ca ti s-a pus pata pe Mac ..ce sa zic, am citit despre DLS si am gasit multe plusuri pt ei (numa pe forum cat s-a vorbit..), plus ca la DLS CLASSIC CA23 ai "Bass boost variabil 25 - 80 Hz, 0-18 dB" ceea ce mi se pare grozav (mult bas pe sub), celelalte amplfuri neavand boostul pana in 18db sa nu mai zic de frecventa de 25hz ...ceva ce eu personal rar am intalnit. Oricum multa bafta la realizarea sistemului si Sarbatori fericite!
decibels is offline   Reply With Quote
Old 22-04-06, 22:19   #11
CataNOS
CataNOS's Avatar
Multumesc decibels! Sarbatori Fericite si tie!
Mi s-a pus pata pe ampliful Mac audio, la subwoofer ma mai gandesc, dar oricum din cate am citit prin prezentari, par chiar bune.. Stiu ca DLS e super marca, da` din experienta am invatat ca nu intotdeauna marca inseamna si calitate, poate de-aia si insist sa aflu pareri despre Mac..
Ok, deci ramane sa aleg intre Mac+Mac sau DLS+Infinity....
Old 23-04-06, 00:16   #12
decibels
decibels's Avatar
Ai absoluta dreptate, totusi cel mai bun lucru pe care poti sa-l faci inainte de a cumpara ceva, este de a asculta si a face comparatie intre scule, iar prin metoda asta te vei decide mult mai usor la ce anume vrei sa cumperi..ce iti place ca se aude cel mai potrivit gustului tau, degeaba fiecare zice cate un brand care ii place lui...tu alegi. Oricum sfaturile sunt binevenite..sunt sigur plus ca multi de aici stiu suficient sa ne indrume pe noi care suntem putin nesiguri in alegeri. Numai bine!
Old 23-04-06, 00:18   #13
CataNOS
CataNOS's Avatar
Sunt absolut sigur ca sunt multi cunoscatori, de aceea am si intrebat Multumesc pentru sfaturi
Old 23-04-06, 00:24   #14
decibels
decibels's Avatar
Acuma mi-am amintit..am avut ocazia sa ascult un infinity kappa pe compresie (lada originala infinity) cu amp tot infinity, si sincer nu mi s-a parut ceva SUPER... ma refer la putere; la fidelitate nu stiu.. Ti-am spus, asculta si compara-le intre ele, e cea mai buna solutie.
Old 23-04-06, 01:04   #15
CataNOS
CataNOS's Avatar
voi incerca sa le ascult pe fiecare in parte.. Oricum, am ascultat un mac audio low-level, de 200 w RMS, si se auzea destul de bine. Ma gandesc ca modelul de 500 w e mult mult mai evoluat decat asta. Magnetul de neodymium am auzit k e ff puternic. Off... e f greu sa alegi.
