Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > OPEL > Zona tehnica Opel
Zona tehnica Opel Zona tehnica, secrete, tips&tricks Opel
Old 06-02-06, 20:18   #1
rocovectra
rocovectra's Avatar
Default HELP OPEL VECTRA A
AM DOUO PROBLEME MOMENTAN : 1-AM MOTOR 2000 GT SI NU STIU DACA ESTE NORMAL SA CONSUME 15-16 L ,2 VREUA SA-I SCHIMB KIT AMBREIAJ SI NU STIU UNDE-L GASESC MAI IEFTIN SI DACA STIE CINEVA CE DIMENSIUNI ARE PT. CA UNI ZIC 215 ALTI 220 DIMENSIUNE PT DISC
VIATA TREBUIE TRAITA LA MAXIM P.S. DOAR O DATA TRECI PRIN EA
rocovectra is offline   Reply With Quote
Old 09-02-06, 22:44   #2
rocovectra
rocovectra's Avatar
AM REZOLVAT CU KITUL ERA 215
Old 11-02-06, 15:43   #3
turbojack
turbojack's Avatar
Default Re:
dar cu consumul?
Depinde cum conduci.Daca o tii doar in 4-6000 de ture asa iti va consuma pe veci,desi e putin cam mult si asa.2000 GT este deja un motor vechi asa ca sigur are destui km in spate.Inainte de a baga surubelnita pe la reglaje,scoate injectoarele si vezi cum pulverizeaza.Shpritz sau ceata.Acolo e diferenta de consum.Verifica si filtrul de aer.
Old 13-02-06, 00:15   #4
Bestie
Bestie's Avatar
motorul 8v sau 16v?
Bestie is offline   Reply With Quote
Old 28-02-06, 16:10   #5
TSC-Us
TSC-Us's Avatar
[SUBARU]
SI LA 6000 DE TURE NU AR TREBUII SA CONSUME ASA!
SIGUR ARE F MULTE PROBLEME!SI ARE KM F MULTI!
AI PROBLEME SERIOASE,NU GLUMA!
AM SI EU VECTRA DAR...CONSUMA...CA IN PRIMA ZI
AM VRUT SA O TUNEZ DAR...O VAND SI-MI I-AU BERTONE SAU GTS!
TSC-Us is offline   Reply With Quote
Old 09-03-06, 15:41   #6
D_M_X
D_M_X's Avatar
Default Re: HELP OPEL VECTRA A
motorul este 8 valve....verifica injectoarele si curatele, dupa aceea daca consuma la fel vezi debimetru de aer....in general asta face talente.Nu este normal sa ai consumul asta decat daca mergi numai in 6000....consumul tau trebuie sa fie pe undeva pe la 10-12% In rest nu mai stiu unde sa te uiti....poate mai stie cineva
D_M_X is offline   Reply With Quote
Old 28-04-07, 19:33   #7
georgeopel
georgeopel's Avatar
[Toyota]
problema la 2000 este debitmetrul de aer sau daca nu uitate la senzorul de temp.
georgeopel is offline   Reply With Quote
