19-02-09, 06:30
Sfaturi Ford Taunus '78-83
Salutare baieti ,am si eu o problema:
as vrea sa-mi cumpar un ford taunus din modelul 78-83 si sa-l tunez de la zero.in primul rand as vrea sa-i umblu sub capota si sa-i schimb motorul cu ceva mult mai puternic sa zicem un motor de BMW 750i (299 HP).m-am gandit ca fiind tot tractiune spate se va potrivi.nu ma prea pricep la mecanica asa ca astept sfaturi si indrumari despre ceea ce ar trebui sa fac.
Astept pasionatii de Muscle Car sa posteze.
20-02-09, 16:59
Re: Sfaturi Ford Taunus '78-83
Mai intai de toate trebuie sa te hotarasati ce anume vrei Ford sau BMW.
Pt a pune un motor de BMW pe taunus o sa trebuiasca sa faci la modificari de te plictisesti+bani cheluiti aiurea si nu vei ajunge la un rezultat satisfacator.
Daca iti place Taunus (70-74 MK1 / 76-79 MK2 / 80-82 MK3) cel mai mare motor (pt Europa) a fost de 2.3 108 cai. Poti pune un motor de 2,9 V6 pe Sierra, Scorpio, Granada...dar va trebui sa te gandesti bine la ce buget ai ...pt ca trebuie sa-i modifici franele.
Ford Power
21-02-09, 19:22
si motorul de 2,9 cat de puternic e ? ca pe mine asta ma intereseaza.si nu am zis ca vreau bmw neaparat da vreau ceva asemanator de puternic.ceva sugestii.
21-02-09, 20:25
Member of: [Moderators] [AfterDark Racing] [DAEWOO] [FORD] [BMW]
Cam asta ar fi povestea:
The BOA and BOB V6
The BOA and BOB engines engines were found in the Granada and Scorpio Ultima. The BOA came first, it was based on the 12V V6 used in the Sierra and Capri and other models and was converted to twin overhead cam and no longer utilised pushrods. It also was bored out to 3.0 litres producing around 180 bhp (130 kW). Then when the new version of the Scorpio came out the BOB series was released, power was increased to 205 bhp (153 kW) and the engine was converted to a cam belt instead of a cam chain. These two engines were always mated to an automatic gearbox but with them being popular in the custom car scene they have been mated to the 4x4 manual transmion and the rear wheel drive manual transmission from the Ford Sierra XR4 and XR4x4. These engines are well known for their high torque and intoxicating exhaust note. There are also companies that offer twin and single turbo conversions and other modifications to increase power to usually around 400 bhp (300 kW).
21-02-09, 22:13
bun si daca fac rost de un motor de Scorpio de 207 CP pot sa-l pun pe Taunus? o sa fie mai usor? si ce tractiune are?
22-02-09, 08:34
E mai greu sa faci rost de un motor de Scorpio de 207 cp......dar poti cauta....sau poti lua un 2,9 V6 si sa il mai "pui la treaba un pic".
Taunus are tractiune spate.
23-02-09, 17:57
nu mi-ai rasp la intrebare daca o sa am un motor de scorpio de 207 cai o sa mearga sa-l pun pe Taunus sau 'o sa fac o gramada de modificari' cum mi-ai zis la motorul de BMW? si ce tractiune are scorpio la el ma refeream. un 2,9 V6 ce putere are si pe ce masina se gaseste?
23-02-09, 21:05
Va trebui (pe langa frane) sa modifici suportii motorului.
2,9 V6 are 150 de cai si 230 NM (cu un dif' de pe Taunus 2,3) vei scoate cca 8 sec de la 0-100.
Taunus, Sierra, Granada, Scorpio au tractiune spate.
Motorul 2,9 se gaseste pe Sierra, Granada si Scorpio
05-03-09, 22:53
altcineva, un sfat un comment nimic?
29-03-09, 15:30
Member of: [PARTICIPANT CURSE] [CSR] [Opel] [Old School Cars] [FORD]
Eu am pus pe taunusul meu un motor 2.9 V6 Cosworth, 195 cai, de pe Scorpio.
Inainte am avut motor V6 de 2L, asa ca motorul nou a mers la fix pe suporti fara nici o modificare.
Motorul asta il poti supraalimenta cu compresor mecanic, pretul fiind in jur de 3000 euroi si scoti in jur de 300-350 cai.
29-03-09, 18:17
atat are masina ta acum 300-350 cai? sau 195?
montezi un motor de ford de pe un sierra de 2000, 8 valve ,2 axe cu came ,128 cai si monezi o rampa de carburatoare si o sa ramai profund impresionat cat de bine poate merge motorul.investitie de circa 1000 euro
