Ford Fiesta 1996, 1.4 16V - probleme turatii
buna. este vorba despre un ford fiesta din 1996, 1.4 16V !
am o problema ce a aparut dupa ce am schimbat motorul. mai exact se tureaza singura, sta in 1500 cu motorul cald iar in mers cand calc ambreajul nu coboara la relanti, ramane turat. ideea e ca dupa ce opresc (0 km la ora) coboara foarte incet inapoi la 900 de turatii.
Mentionez ca cateodata merge totul ok, in sensul ca la pornire sta la 900, iar in mers revine la relanti.
Am curatat valva de relanti, iar clapeta de aceleratie nu ramane blocata!
ma poate ajuta cineva??
Multumesc.
Rule 1: Always win.
Rule 2: Never lose.
Rule 3: Never back down.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” (Ayrton Senna)
