Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > VOLKSWAGEN > Alte discutii VW
Old 23-02-09, 16:33   #1
CATALINBRAT
CATALINBRAT's Avatar
Thumbs up macarale electrice gama "VAG"
REPARATII "MACARALE GEAMURI ELECTRICE SI MANUALE"VW.GOLF 3,4,5 ,BORA, AUDI A2,A3,A4,A6,POLO,LUPO,SEAT LEON,TOLEDO,IBIZA,PASSAT.. SKODA,OCTAVIA ,FABIA ,ETC.........OPEL ....
Daca aveti intrebari in legatura cu geamurile electrice, va pot ajuta "daca se poate " .. window's men.........
ID:	805704   Click image for larger version
Name:	kit reparatie golf 4.jpg
ID:	805705   Click image for larger version
ID:	805707   Click image for larger version
Name:	macara golf 5 sau getta.jpg
ID:	805708   Click image for larger version
Name:	poze macara vw.jpg
Name:	clema geam octavia,golf 4bora,seat (1).jpg
ID:	805847   Click image for larger version
Name:	clema geam a4.jpg
CATALINBRAT is offline   Reply With Quote
Old 23-02-09, 17:35   #2
simplu
Default Re: macarale electrice gama "VAG"
Salut - am o intrebare referitoare la golf 3:
Am schimbat macaraua pe stanga (masina e in 2 usi) cu una noua cumparata de la volksparts si acum nu stiu cum sa reglez cat urca/coboara geamul...problema e ca atunci cand ii dau din buton sa ridice geamul il scoate cam 4 cm mai mult decat ar fi normal...
simplu is offline   Reply With Quote
Old 23-02-09, 18:13   #3
CATALINBRAT
Salut! suna-ma si-ti explic ce se intampla 0723744929..sau 0744304658
Old 23-02-09, 18:19   #4
CATALINBRAT
Thumbs up Re: macarale electrice gama "VAG"
Salut! stiu care este problema la macaraua ta ........
Salut! suna-ma si-ti explic ce se intampla 0723744929..sau 0744304658 ([email protected] )
Old 23-02-09, 19:00   #5
CATALINBRAT
In principiu inainte sa schimbati o macara fie electrica sau manuala,nu mai da-ti fuga la xxx magazine sa cumparati macara "noua" pt. ca este mai proasta ca cea veche,garantez ..(AM PORTBAGAJUL PLIN DE MACARALE NOI AFTERMARKET CARE NU MERG ) in 2 cuvinte (AFTERMARKET).
Asa ca daca aveti probleme intrebati-ma si o rezolvam .. Bafta ..
Old 14-06-09, 22:03   #6
serban_pc
serban_pc's Avatar
Mi-a cazut geamul astazi la o skoda octavia tour pe stanga spate .
O rezolvam? Cu cat si cand?
Merci!
Da-mi un PM daca poti ...
serban_pc is offline   Reply With Quote
Old 17-06-09, 12:38   #7
CATALINBRAT
salut! da se rezolva problema cu macaraua de pe masina ta cu conditia sa o ai si sa nu arunci piesele vechi de pe ea ... Suna-ma si o rezolvam ,,,
Old 25-06-09, 02:18   #8
dragos_rsp
dragos_rsp's Avatar
salut, am nevoie si eu cablurile de la macara, ma poti ajuta? pt un golf 4 in 2 usi.
dragos_rsp is offline   Reply With Quote
Old 26-06-09, 17:39   #9
CATALINBRAT
Salut! da se rezolva dar cu conditia sa-mi trimiti macaraua si ti-le montez eu altfel nu pot sa-ti dau garantie. Daca esti din Bucuresti este ok ... daca nu prin curierat . Pretul este 150 lei .. Suna-ma si vb .0769354517
Bafta!!!
Old 28-06-09, 12:41   #10
Bengy_BLS
Bengy_BLS's Avatar
2 macarale de golf 3 ? ca stiu ca nu difera de la 2 la 4 usi , am un prieten care si-a pus de 4 pe 2 usi . Daca ai macarale , da-mi si mie un pm , eventual dau si un kitt de geamuri electrice universale de la FK +diferenta , asta daca te ajuta cu ceva , daca nu .... oricum astept Pm , merci mult de tot !
Bengy_BLS is offline   Reply With Quote
Old 29-06-09, 23:39   #11
CATALINBRAT
Salut! nu mai deocamdata dar spune-mi in ce stare se afla ale tale, ce problema au?
Old 29-06-09, 23:58   #12
Bengy_BLS
Bengy_BLS's Avatar
ale mele-s bune , dar am kitt dinala universal montat pe ele si cam ridica greu , mai fac figuri din cand in cad dar nu ma plang , totusi vroiam originale , doar macaralelele deoarece instalatia o am. Si asa orientativ , cam cu cat se vinde asa ceva , nu de alta , dar sa stiu pe viitor , poate gasesc , si nu vreau sa imi iau tzeapa la bani. Multumesc anticipat de sprijin
Old 30-06-09, 00:17   #13
CATALINBRAT
pretul oscileaza ,de la 200 la 300 lei electrice chiar si 100 de euro plec in Germania saptamana viitoare daca iti gasesc ceva te caut si-ti spun pretul...
Old 03-07-09, 22:42   #14
cmasaiu
Banned
salut am si eu o problema mi a cazut geamu stanga fata la un vw bora am desfacut sa ridic geamu si am constatat ca au crapat pasticel ede la ghidaje cum putem rezolva gasesc plastice seaparate sau trebuie sa iau kitu complet de macara .
cmasaiu is offline   Reply With Quote
Old 04-07-09, 00:16   #15
CATALINBRAT
Salut! stiu ce a crapat la tine dar problema cea mai dureroasa este ca s-au stricat si cablurile si rola . Variante ot sa-ti trimit cleme noi de plastic 90 lei sau sa-ti trimit alt panou asamblat cu macara originala sh cu garantie 1 an . 150 lei,cu o singura conditie sa-mi trimiti panoul vechi la schimb ... Suna-ma si vb. 0769354517. Bafta..
