Re: Help!Am 2 intrebarii!pt Passat tdi 1.9
OIL SERVICE
Press and hold button A (cel din dreapta )
Switch ignition ON
Release button A
The letters "OEL" or "OIL" will appear in the trip recorder display
For models with digital clock turn button B to the right until "_ _ _" appears in the display
For models with analogue clock pull out button B until "_ _ _" appears in the display
INSPECTION SERVICE
Switch ignition ON
Release button A
Press and release button A
The letters "INSP" will apear in the display
For models with digital clock turn button B to the right until "_ _ _" appears on the display
legat de prima prob, cred ca daca faci o scanare poti afla mai multe.
sau incearca asta pt resetare.
1. pui contactul
2. cuvantul ""service" iti apare pe displayul unde afiseaza kilometrajul
3. Apesi butonul (A) - butonul din dreapta cum te uiti la bord
4. intorci butonul (-cel din stanga, la dreapta ca sa resetezi.
Objects in the mirror tend to disappear
It will never have enough power until I can spin the wheels at the end of the straightaway in high gear
