Old 16-07-10, 19:09   #1
rizea.vlad
rizea.vlad's Avatar
Default Probleme prima pornire
Dimineata, prima pornire a zile, nu porneste la prima cheie, la a doua no problem , la fel si la restu. daca tine insistemt , porneste dupa 10-15 sec, ce poate fi? Masina va ajunge in august, la service, pentru verificarea periodica a distributiei recent schimbate, si atunci vom pomeni si de problema asta, dar pana atunci, nu pot sa dorm noapte din cauza asta. masina e un golf 4 3 usi, din 2002, 1.4 16v, masina o are de 3 luni, si are 110.000km, la 106.000 adusa in tara, pana atunci rulata in germania, cu catre de service si revizii la timp!
"These things bring you to reality as to how fragile you are; at the same moment you are doing something that nobody else is able to do. The same moment that you are seen as the best, the fastest and somebody that cannot be touched, you are enormously fragile."
"Being second is to be the first of the ones who lose." -Ayrton Senna
rizea.vlad is offline   Reply With Quote
