Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > SKODA > Zona tehnica Skoda
Zona tehnica Skoda Zona tehnica, secrete, tips&tricks Skoda
Old 30-04-08, 12:59   #1
eddycdk
Skoda Driver
eddycdk's Avatar
[Colectionar Machete]
Default meniurile climatronicului Octavia II
aici am sa prezint meniurile si cum se procedeaza ca sa intri in ele!
eddycdk is offline   Reply With Quote
Old 30-04-08, 13:04   #2
eddycdk
Skoda Driver
eddycdk's Avatar
Default Re: meniurile climatronicului Octavia II
pt a intra in meniurile climatronicului trebuiesc apasate in acelasi tp tasta dezaburire geamuri interior (cea dreptunghiulara din dreapta sus) si tasta econ!
apoi din rotita stanga a climatronicului se invarte de ea si in display-ul de deasupra ei apar meniurile scrise cu cifre mari si in dreapta lor (cifrelor) submeniurile scrise cu cifre mici
in display-ul din dreapta rotitei drepte apar parametrii
pt viteza se selecteaza meniul 19!
revenirea la normal se face apasand in acelasi tp tasta auto si econ!
mai jos meniurile si submeniurile:
Main channel: 0 - System data
0 Number program
1 Left ERL
2 Skillful ERL
3 Point of job accensione/avvio
4 I recirculate automatic rifle (motor)/I recirculate automatic rifle Bit
5 Heating from active detention
6 Air Quality (7 = fresh air)
7 Deriving
8 Acronym country
9 Sensor zone head
Main channel: 1 - UIF
0 Inner temperature (°C)
1 Surface Temperature (°C) (I think it means external)
2 Temperature piastrine in platinum (°C)
3 Corrector piastrine in platinum (°C)
4 Uif-Sonnenint
5 Corrector radiation (°C)
6 dynamic corrector (°C)
7 OrrettoreC I recirculate (°C)
8 thermal corrector (°C)
9 Compensation ignition (°C)
Main channel: 2 - Sensor radiation SX
0 Radiation not delayed (W/m2)
1 Corrector radiation for regolator temperature (W/m2)
2 Corrector radiation for impeller (W/m2)
3 Value TO
Main Channel: 3 - Sensor radiation DX
3 Value TO
Main Channel: 4 - External Temperature
0 External temperature (°C)
1 Temp. External line CAN (°C)
2 Temperature inhaled air climate (°C)
Main Channel: 5 - Theoretical temperature SX
0 Theoretical Temp. air in escape SX (°C)
1 Theoretical difference between temp. and temp. effective (°C)
2 Value regulation the sx. (½% )
3 Pi-Stell-Max (½%)
4 Defrost SX
Main channel: 6 - Found temperature SX
0 Temp. Found SX (°C)
1 Temp. Feet SX (°C)
2 Temp. Facade SX (°C)
Main channel: 7 - Theoretical temperature DX
0 Theoretical Temp. air in escape DX (°C)
1 Theoretical difference between temp. and temp. effective DX (°C)
2 Values of regulation regolator (½% )
3 Pi-Stell-Max (½% )
4 Defrost
Main channel: 8 - Found temperature DX
0 Found Temp. air in escape DX (°C)
1 Temp. Feet (°C)
2 Temp. Facade (°C)
Main channel:9 - Theoretical temperature evaporator
0 Theoretical temperature evaporator (°C)
1 Theoretical difference between temp. and temp. effective evaporator (°C)
2 Values of regulation evaporator (5mA/Dig)
3 Modality Regolator evaporator (you see under)
Main channel: 10 - Effective temperature evaporator
0 Effective temperature evaporator (°C)
1 Pressure coolant climate (bar)
2 Medium temperature coolant climate (°C)
Main channel:11 - Climate control compressor
0 Power theoretical electrical worker
1 Power effective electrical worker
2 Power electrical worker max
3 Kompressor PWM (0... 200) (Dig)
4 Power electrical worker offset compressor
5 Values power electrical worker
6 Code disinserito compressor (you see system)
Main channel:12 - Climate control impeller
0 Theoretical tension of the electric impeller (V)
1 Manual regulation
2 Code anomaly
3 Reduction impeller (V)
4 Impeller offset (0.1V)
Main channel: 13 - Temperature bocchette air SX
0 Formattato theoretical value (%)
1 Real theoretical value temp. Bocchette sx.(Dig)
2 Confirmation el. temp. Bocchette sx (Dig.)
3 The maximum limit temp. Bocchette sx. (Dig)
4 Limit min. temp. Bocchette sx. (Dig)
Main channel: 14 - Temperature bocchette air DX
1 Real theoretical value temp. Bocchette dx (Dig)
2 Confirmation el. temp. Bocchette dx (Dig)
3 The maximum limit temp. Bocchette dx (Dig)
4 Limit min. temp. Bocchette dx. (Dig)
Main channel: 15 - Piedi/centrale temperature bocchetta
1 Real theoretical value temp. Bocchetta centers them (Dig)
2 Confirmation el. temp. bocchetta centers them (Dig)
3 The maximum limit temp. bocchetta centers them (Dig)
4 Limit min. temp. bocchetta centers them (Dig)
Main channel:16 - Defrost Shovel
1 Theoretical value real Defrost shovel (Dig)
2 Confirmation el. Defrost shovel (Dig)
3 Limit maximum Defrost shovel (Dig)
4 Limit min. Defrost shovel (Dig)
Main channel: 17 - Shovel I recirculate inner
1 Theoretical value real shovel I recirculate (Dig)
2 Confirmation el. shovel I recirculate (Dig)
3 Limit maximum shovel I recirculate (Dig)
4 Limit min. shovel I recirculate (Dig)
Main channel: 18 - Shovel cold air
1 Theoretical value real Shovel cold air (Dig)
2 Confirmation el. Shovel cold air (Dig)
3 Limit maximum Shovel cold air (Dig)
4 Limit min. Shovel cold air (Dig)
Main channel: 19 - Data Motor
0 Vehicle velocity (km/h)
1 Vehicle velocity (Mph)
2 Motor temperature (°C)
3 Engine speed (RPM)
4 Air con compressor speed (RPM)
Main channel: 20 - Data sent by CAN
0 Additional heating (upon request) (1 = on)
1 Confirmation el. PTC (1 = on)
2 Power el. effective PTC
3 % air demanded from radiating climate (%)
4 Relationship % of radiating peak air (%)
5 No performance demanded to the disp. of heating (1=no performance heating)
Main channel: 21 - Ripartitore of air Climate
0 Defrost (%)
1 Facade (%)
2 Feet (%)
3 Bocchetta areazione (%)
4 I recirculate fresh air/cleaned up (+ bocchetta...) (%)
5 Appraisal sensor (%)
Main channel: 22 - Data timer
0 Period of pause (min)
1 Motor operating time (sec)
2 Operating time with inserted key (Sec)
Main channel: 23 - Special channel
0 Sensor inner lighting system (Dig)
1 Air quality sensor
Main channel:24 - Version software
0 Development state
1 Software version
2 Type SW
3 Keep Frozen (0/1 = Values of refrigeration come maintained ad.eccezione.della Diagnosis )
4 Version K Matrix
5 EEP- Testflags
6 It codifies Vag (2)
Main channel: 25 - Test channels
1 - 9
Main channel: 26 - Parameters for surveys on crystals
0 Delay (sec)
1 Passo/udm (digit)
2 The minimal limit (digit)
3 Limit max. (digit)
4 Passo/udm on HellaKit
Main channel: 26 - Bocchetta direct areazione
1 Theoretical value real Bocchetta direct areazione (Dig.)
2 Confirmation el. Bocchetta direct areazione (Dig.)
3 Limit max. Bocchetta direct areazione (Dig.)
4 Limit min. Bocchetta direct areazione (Dig.)
Main channel: 28 - Umidita
0 Theoretical Umidita (%)
1 Relative Umidita on temperature UIF (%)
2 Temp. Crystals WSS (°C)
3 Temperature condensation point (°C)
4 Difference temperature of the melting point (°C)
Main channel: 29 - Crude values umidita
0 Temp. Crystals, corrected (°C)
1 Temp. Crystals, not corrected (°C)
2 Sensor umidita (%)
3 Temperature sensor (°C)
4 Temperature condensation point (test measure) (°C)
5 Code anomaly
Main channel: 30 - Values indicated to you umidita
0 Value sensor termofilo (Dig.)
1 Temperature rif. termofilo (Dig.)
2 Periodic duration umidita (10 (to the power of -4) sec)
3 Temp. Reference umidita (Dig.)
4 Umidita Rel. on the sensor (%)
5 Temperature sensor umidita (°C)
6 Temperature crystals (not corrected)
2013 creamy white i30 / OEM+ style
Old 30-04-08, 13:05   #3
cristy1979
ms dar nu le gasesc
apropo
f tari machetele frate
esti mare
cristy1979 is offline   Reply With Quote
Old 30-04-08, 13:06   #4
eddycdk
Skoda Driver
eddycdk's Avatar
Originally Posted by cristy1979 View Post
ms dar nu le gasesc
apropo
esti mare
cu placere!
ms si eu
incerca sa urmezi instructiunile si sigur le vei gasi...daca ai nelamuriri...intreaba-ma!
Old 30-04-08, 13:11   #5
cristy1979
multumesc frumos
Old 01-05-08, 10:41   #6
skoda boy
skoda boy's Avatar
Mersi mult...mi-ai fost de mare ajutor
skoda boy is offline   Reply With Quote
Old 01-05-08, 12:50   #7
eddycdk
Skoda Driver
eddycdk's Avatar
ma bucur ca v-ati descurcat!!!
Old 04-05-08, 17:33   #8
vioami
Pentru octavia 1 ceva nou in afara de ce s-a scris ai...?
vioami is offline   Reply With Quote
Old 04-05-08, 17:51   #9
skoda boy
skoda boy's Avatar
Am gasit ceva dar nu stiu daca climatronicul de la O1 este la fel ca cel de pe passat.. https://youtube.com/watch?v=pHpFZIVQwBU
Old 05-05-08, 12:18   #10
eddycdk
Skoda Driver
eddycdk's Avatar
@ skoda boy: da este la fel
@vioami: s-ar putea sa gasesti pe www.vwforum.ro
stiu ca am citit ceva aici...
Old 05-05-08, 13:11   #11
vioami
Multam mult...!
Old 05-05-08, 20:35   #12
eddycdk
Skoda Driver
eddycdk's Avatar
ai gasit ceva?
Old 05-05-08, 23:16   #13
vioami
Nu am cautat inca dar am vazut filmuletul de pe youtube. Sper sa reusesc. Multam mult skoda boy.
Old 12-05-08, 10:30   #14
vioami
Am reusit sa intru. Multam. Atunci cand intri in meniul climatronicului trebuie ca climatronicul sa fie pe OFF si merge.
Old 12-05-08, 10:31   #15
vioami
In registru 16 imi da o diferenta de 5 km pe ora intre bord si klimatronic.(pe bord cu 5 km/ora mai mult)
