salut, a pus cineva instalatie electrica motor m50b25 e34 automatic la un swap e30.precizez ca pe e 30 nu mai este cutia automata.nu porneste,nici macar nu da curent la pompa de benzina.de pe instalatia electrica s-a anulat tot ce tine de cutia automatica si firul maro cu negru s-a lipit la releul alb la un fir rosu cu alb.
(The best wiring harness to use is out of a manual 93-94 325I due to its simplicity, although it is not that hard to modify a wiring harness from an automatic car or a car with traction control and EWS. The process is as simple as laying the harness out on a table with a diagram in front of you and eliminating anything that is not necessary. If you ended up with a harness out of an automatic car simply cut all of the wires out of the engine harness that belong to the automatic transmission computer. Automatic transmission computer is wired directly to the engine computer harness; the only wire that needs to be modified is a “brown/black wire pin 26 transmission ECU” need to be connected to any “red/white wire on the main relay”)
