Old 24-11-12, 01:42   #1
adrian325i
Default Regulator presiune motor
Regulatorul de presiune e tot una cu supapa control presiune combustibil ?
http://autokarma.ro/Produse.aspx?Tip...%20combustibil
adrian325i is offline   Reply With Quote
Old 24-11-12, 01:49   #2
oimz.e30
oimz.e30's Avatar
Default Re: Regulator presiune motor M50
Sub capacul de plastic central este rampa de injectoare, daca il dai jos o sa vezi rampa de injectoare neagra care tine injectoarele ce intra in admisie. In partea spre bordul masinii in capatul rampei e regulatorul de presiune. Are un furtun de vacuum care iese din el. E un corp cilindric
oimz.e30 is offline   Reply With Quote
Old 24-11-12, 01:50   #3
oimz.e30
oimz.e30's Avatar
http://static.bmwfans.info/images/epc/MjA0MV9w.png
piesa 6
Old 24-11-12, 02:02   #4
adrian325i
Da la asta ma uitam. M-a dat peste cap terminologia...
Acum stiu care e chestia... Ma uitam la unu' pe youtube care cica avea un 328 cu 240 de cai si cica ar fi avut regulator de presiune de M5 si ma uitam pe autokarma iar aia aveau doar supapa presiune... Nu mai intelegeam nimic. Acum stiu despre ce piesa e vorba.
Merci
Da' vad ca e acelasi regulator de presiune de la 320 la X5... deci ala ori manca rahat ori l-a prostit unu' sa-i vanda regulator de presiune de " M5 frate "...
https://www.youtube.com/watch?v=qU4nP...eature=related
Part number: 13 53 1 436 110
Old part number: 13 53 1 726 385
Interchangeability: Exchangeable retrospectively
Supplement
Usage
3' E36
320i (M50)
320i (M52)
323i (M52)
323i 2.4 (M52)
323ti (M52)
325i (M50)
325is (M50)
328i (M52)
M3 (S50)
5' E34
525i (M50)
525ix (M50)
530i (M60)
540i (M60)
5' E39
520i (M52)
520i (M54)
523i (M52)
525i (M54)
528i (M52)
530i (M54)
535i (M62)
540i (M62)
540iP (M62)
7' E32
730i (M60)
730iL (M60)
740i (M60)
740iL (M60)
7' E38
728i (M52)
728iL (M52)
730i (M60)
730iL (M60)
735i (M62)
735iL (M62)
740i (M60)
740i (M62)
740iL (M60)
740iL (M62)
740iLP (M62)
8' E31
840Ci (M62)
840i (M60)
X5 E53
X5 3.0i (M54)
X5 4.4i (M62)
X5 4.6is (M62)
Z3 E36
Old 25-11-12, 21:29   #5
oimz.e30
oimz.e30's Avatar
Merci
Supplement
Usage
3' E36
320i (M50)
320i (M52)
323i (M52)
323i 2.4 (M52)
323ti (M52)
325i (M50)
325is (M50)
328i (M52)
M3 (S50)
5' E34
525i (M50)
525ix (M50)
530i (M60)
540i (M60)
5' E39
520i (M52)
520i (M54)
523i (M52)
525i (M54)
528i (M52)
530i (M54)
535i (M62)
540i (M62)
540iP (M62)
7' E32
730i (M60)
730iL (M60)
740i (M60)
740iL (M60)
7' E38
728i (M52)
728iL (M52)
730i (M60)
730iL (M60)
735i (M62)
735iL (M62)
740i (M60)
740i (M62)
740iL (M60)
740iL (M62)
740iLP (M62)
8' E31
840Ci (M62)
840i (M60)
X5 E53
X5 3.0i (M54)
X5 4.4i (M62)
X5 4.6is (M62)
Z3 E36
scrie regulator de presiune de m50 nu de m5 fiecare motor are un regulator care deschide la o anumita presiune pentru m50 m52 3.5 bari la m20 3 bari
Old 26-11-12, 00:24   #6
adrian325i
pe autokarma scrie ca si cel de M5 si cel de M50b25 deschid la aceeasi presiune. deci in concluzie as schimba-o degeaba...
07.1992 - Cod Motor S 38 B 38 hidraulic 3,5 bar 50,8 psi Nr. informatii tehnice SI 0015
Cod Motor M 50 B 25 hidraulic 3,5 bar 50,8 psi Nr. informatii tehnice SI 0015
