Old 05-12-11, 17:53   #1
sergiu_e36
sergiu_e36's Avatar
Default ce se intampla daca pun volanta neechilibrata (luata in strung)
ce se poate intampla daca pun o volanta neechilibrata???? ce poate afecta la motor?? astept pareri sincere......sau daca a pus careva o volanta neechilibrata....
sergiu_e36 is offline   Reply With Quote
Old 05-12-11, 17:55   #2
cangri
cangri's Avatar
Default Re: ce se intampla daca pun volanta neechilibrata (luata in strung)
I-ti va sparge cutia de viteze.
Old 05-12-11, 20:26   #3
JustinCase
JustinCase's Avatar
Daca esti prea inalt si vrei sa-ti mai scurtezi 10cm din picioare atunci este o idee buna
https://www.youtube.com/watch?v=L2pz1PkhAo8
https://www.youtube.com/watch?v=QSFA0ufNS_k
sau o alta volanta explodata care taie conductele de frana:
https://www.youtube.com/watch?v=n5nfJ...eature=related
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
Old 06-12-11, 00:07   #4
cangri
cangri's Avatar
@ JustinCase nu fi si tu atat de macabru.
Astea sunt cazuri rare
Oricum in cel mai fericit caz doar se sparte cutia.
Old 06-12-11, 03:36   #5
the_rifle
Si eu si Justicase avem volante "neechilibrate"
"luate in strung "... De unde stii ca e neechilibrata ? Ce fel de volanta ? Masa dubla sau simpla ? Daca e masa simpla de ce nu o echilibrezi ?
Old 06-12-11, 03:43   #6
JustinCase
JustinCase's Avatar
the_rifle ce avem noi se numesc volante rectificate la strung si deci nu se poate spune ca sunt dezechilibrate.
Colegul se refera la o volanta usurata pe strung, alta mancare de peste
Old 06-12-11, 03:46   #7
the_rifle
Pai si daca e luata in strung egal, de ce ar fi mai dezechilibrata decat era inainte ????
Si care e diferenta daca noi am luat in strung o zecime iar el sa zicem ca ar fi luat un centimetru( de exemplu)... Diferenta e doar la greutate dar procesul de rectificare ramane acelasi ... A zis ca a luat-o in strung nu la pila... Ma gandesc ca tot o strunjire rotativa a fost ca altfel ar fi contra logicii...
Cat despre filmulete tind sa cred ca a fost o eroare de montaj...
S-au mai auzit cazuri in care altii se duc la curse cu un singur prezon pe roata din 5... Poate s-au gandit ca un surub pe volanta e suficient... sa fie mai usoara...
Stii si tu cum mi-au monatat altii cardanul si ce s-a intamplat...
Old 06-12-11, 08:48   #8
sergiu_e36
sergiu_e36's Avatar
este o volanta de m20b20 de 8,5kg care sa luat in strung pana la 6,5kg........si as pune-o pe un m43b16............
Old 06-12-11, 11:03   #9
JustinCase
JustinCase's Avatar
Nu era mai simplu sa cumperi de la inceput varianta de 6,4kg de M20?
The_rifle: Nu este acelas lucru daca rectifici 0,4mm fata de 10mm cum ai dat tu exemplu. In primul caz modificarea echilibrului este insesizabila, la urma urmei ce greutate crezi ca a pierdut volanta? 5 grame adunate pe toata suprafata? Prea putin sa faca o diferenta...
Daca volanta ar fi avut greutatea uniform distribuita (un caz ideal dar improbabil) puteai sa iei din ea oricat ca tot ar fi fost echilibrata. Dar in cazul de fata volanta nu este uniforma asa ca daca ai dat jos 2kg din ea sigur trebuie echilibrata.
