sal...
am o lista cu erori ... si am cautat de curand pe net dar nu gasesc nimic concret nici o interpretare sigura...
6 Faults Found:
01262 - Solenoid Valve for Boost Pressure Control (N75)
26-00 - Output Open
17972 - Throttle Actuator (J33
: Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17967 - Throttle Body (J33
: Fault in basic settings
P1559 - 35-10 - - - Intermittent
00575 - Intake Manifold Pressure
11-10 - Control Limit Not Reached - Intermittent
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
26-10 - Output Open - Intermittent
00561 - Mixture Adaptation
14-10 - Adaptation Limit (Add) Exceeded - Intermittent
Readiness: N/A
am dat de cap doar la n75 pe care l-am si comandat ... defapt nu original de 1,8t de 150 , dar acela de s3 de 225cp...am probat unul si masina si-a schimbat mersul...
daca aveti idee cu celelate erori va rog sa mi spuneti si mie
multumesc
