Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > ALFA ROMEO > Alte discutii Alfa Romeo
Old 25-06-10, 16:56   #1
floryano_zmp
floryano_zmp's Avatar
Default Motor 20.ts an 88' pe 145 1.4 ts an'01
Am gasit gasit o alfa 164 cu motor 2.0 ts din din '88 si as vrea sa stiu daca o sa se potriveasca cumva motorul pe alfa mea 145,1.4 ts.Daca am mai facut cineva aceasta modificare ,cateva sfaturi.Ma intereseaza in special daca se potriveste cutia.Mersi
floryano_zmp is offline   Reply With Quote
Old 27-07-10, 18:40   #2
rizea.vlad
rizea.vlad's Avatar
Default Re: Motor 20.ts an 88' pe 145 1.4 ts an'01
Nu se merita, deoarece 2.0T.S. a fost pe 145 si mai rentabil e sa iei un 145 2.0 decat sa faci engine swap. Engine swap se face tunci cand vrei sa pui pe a ta un motor care nu s-a mai pus, altfel nu se merita!
"These things bring you to reality as to how fragile you are; at the same moment you are doing something that nobody else is able to do. The same moment that you are seen as the best, the fastest and somebody that cannot be touched, you are enormously fragile."
"Being second is to be the first of the ones who lose." -Ayrton Senna
rizea.vlad is offline   Reply With Quote
