Go Back   Forum 4Tuning > Masini & Tuning > Discutii generale masini
Discutii generale masini Discutii generale despre masini : Colt Legislativ, Taxa Inmatriculare, Intrebari-Raspunsuri, Recomandari, Accidente
Old 22-04-06, 10:24   #1
avolocaru
avolocaru's Avatar
Default Cel mai preformant motor diesel ???
Salut
Ma rog... cel mai performant dati si voi o parere. As fi interesat de un v8 cu 2...2,5 L capacitate cilindrica.
avolocaru is offline   Reply With Quote
Old 22-04-06, 13:24   #2
turbojack
turbojack's Avatar
Cool Re: Cel mai preformant motor diesel ???
Originally Posted by avolocaru
Salut
V8 de 2-2.5 L , gasesti eventual pe motociclete,ca si capacitate.Insa diesel....
Eventual V6 de 2.5L
V 8 este un motor specific american,care se "jucau" in genere cu capacitati de la 5.o L in sus.
Old 22-04-06, 14:52   #3
turbojack
turbojack's Avatar
Default Re: Cel mai preformant motor diesel ???
Unul dintre motoarele diesel performante cunoscute:
Code
Manufacturer Alfa-Romeo
Type V-6
Wet sumped
DOHC
24 valves total
4 valves per cylinder
Main bearings
Construction
Bore × stroke 87.50mm × 88.00mm
3.44 in × 3.46 in
Bore/Stroke ratio 0.99
Displacement 3175 cc
(193.75 cu in)
Unitary capacity 529.17 cc/cylinder
Compression ratio 11.25:1
Fuel system MED 7.6.2 direct injection
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output 259.6 PS (256.0 bhp) (190.9 kW)
@6200 rpm
Max. torque 322.0 Nm (237 lbft) (32.8 kgm)
@4500 rpm
Maximum rpm 7200 rpm
Coolant Water
Specific output 80.6 bhp/litre
1.32 bhp/cu in
Specific torque 101.42 Nm/litre
sau un altul :
Code
Type S-5
Wet sumped
DOHC
20 valves total
Main bearings
Construction
Bore × stroke 82.00mm × 90.40mm
3.23 in × 3.56 in
Bore/Stroke ratio 0.91
Displacement 2387 cc
(145.664 cu in)
Unitary capacity 477.4 cc/cylinder
Compression ratio 17.00:1
Fuel system Bosch EDC 16C39 diesel injection
Aspiration Turbo D.
Compressor type
Intercooler Y
Max. output 199.7 PS (197.0 bhp) (146.9 kW)
@4000 rpm
Max. torque 400.0 Nm (295 lbft) (40.8 kgm)
@2000 rpm
Maximum rpm
Coolant Water
Specific output 82.5 bhp/litre
1.35 bhp/cu in
Specific torque 167.57 Nm/litre
Old 26-04-06, 20:47   #4
avolocaru
avolocaru's Avatar
Ma rog atunci sa zicem ca ca poate sa fi si de 3-4 L important e sa fie in 8 cilindri (avand in vedere ca si consumul de carburabt e o problema, am sa vad la un moment dat poate fac un compromis la 6 cilindri).
Pentru inceput ma uit la performante, adika vreau ceva puternic si un cuplu cat mai mare, apoi o sa mai vad cum sta treaba si d.p.d.v. al gabaritului.
Cel de la Alfa-Romeo in 6 cil e interesant. Mai astept si alte pareri.
Merci tuturor
Old 26-04-06, 22:51   #5
turbojack
turbojack's Avatar
o completare pt. un motor diesel :
The Duramax Diesel ConversionThe Duramax Diesel Conversion for the HUMMER H1 & H2 is here! We are proud to offer the only real alternative to HUMMER's own limited production Alpha. Existing H1 & H2 owners have the opportunity to upgrade to GM's legendary Duramax Diesel, saving you literally thousands of dollars over a new Alpha H1. What we offer, that you won't find at your local dealer, is a 650hp H1 or H2 with virtually any upgrade or option you can imagine. From custom performance accessories to a personalized interior we can create a HUMMER that truly is like nothing else on earth. This conversion offers all the strengths of GM's Duramax Diesel: **********, torque, efficiency and durability. Producing the kind of power & refinement usually associated with high-powered sports cars and luxury automobiles. With all this extra power comes the unexpected benefit of the Duramax engine providing up to 22 mpg, vastly increasing your HUMMER's practicality & touring range. Power & Precision by Design This Duramax Diesel Conversion is designed and built above factory standards while offering a totally integrated appearance that's second to none. What sets this Duramax conversion apart is the level of quality, integrity & attention to detail that goes into every aspect of the conversion process. From hand-crafted engine mounts to custom wiring & cooling systems every component is designed, tested & built to levels the competition can only aspire to. The Duramax Diesel 6.6 Conversion Package This Conversion Package produces the Duramax 6.6 Powerplant's 300 ********** and 520 lb. ft. of torque and can be modified to produce up to 650 ********** and 700 lb. ft. of torque. We also offer Custom Engine Build programs that can produce even greater power gains depending upon individual specifications.
The Standard Conversion Package Includes:●Duramax Diesel 6.6 Turbocharged & Intercooled Engine●Allison M1000 Transmission●NVG Selectable 2wd-4wd Transfer Case●Custom 4" Exhaust System●Custom Radiator & Cooling System●Custom Turbo Intercooler●Fuel Cooler A Range of Customized Allison Transmissions Featuring: ●Advanced controls for precise, more efficient, faster, smoother shifts.●Legendary Allison durability●Grade Braking- allowing for increased down hill braking power & control.●Adaptive Shift Control- allows gear selection to adapt to driver input and driving conditions●Fuel Economy Management- the Allison transmission adjusts shift patterns to maximize fuel economy, shifting at optimum points in power & torque curves.
Ordering Your Duramax Diesel Conversion We can convert your H1 or H2 to a Duramax Diesel, alternatively we can supply you with a completed Duramax Diesel H1 or H2 from our own sources or help supply the exact vehicle you're looking for to begin your own conversion. We can also ship these vehicles outside of the US directly to you.The whole process begins with a personal consultation to determine exactly what your needs are. Please call to make an appointment to speak with one of the Diesel Conversion Specialists for further information and to discuss your individual requirements at 800-449-6921 or 858-748-4044.
Customizing Your Duramax H1 or H2We provide our customers with the opportunity to customize virtually every aspect of their car. We offer an extensive list of individual performance options that can be added to the basic conversion. All components are evaluated & tested for efficiency, durability & performance. Available Options:
●Digital Power Chip Systems ●Larger injectors ●High-Pressure Turbo- up to 60 psi. ●Performance Fuel Management Computer ●Performance Transmission Computer ●Billet Triple Lock Torque Converter ●Allison M1000 Performance Transmission Upgrade ●Water Injection ●Propane Injection ●Nitrous Injection ●Exhaust Brake ●Custom Exhaust Systems ●Engine Dress Kit
Duramax, HUMMER, H1, H2 & Allison are registered trademarks of General Motors Corporation
Old 26-04-06, 22:52   #6
turbojack
turbojack's Avatar
sau direct :http://www.stallioncustoms.com/h1h2dudico.html
Old 28-04-06, 16:42   #7
lascarica
Super Moderator
lascarica's Avatar
Parerea mea este ca 2000cmc (T)diesel nu vei gasi nici V6,d-apai v8. Cel mai mic V6 diesel de care am io cunostintza este cel de la VAG, 2500cmc.
....DAR...am o intrebare...: Intrebi ca fapt divers,pentru cultura generala sau ai intentia de a achizitiona asa ceva? ca in cel de-al doilea caz, mult mai avantajos ar fi sa-l iei cu tot cu....ambalajul.Iar cele doua exemple date de turbojack, sunt impresionante ca si performantze,numai ca nu prea le-am vazut implementate in ceva...poate la jaguar sa fie unul din ele,dar nu-s sigur.
Io am mers cu doua "petroliere" V8 : Lancruiser si S-classe. Pe ceva mai "parcabil"(la dimensiuni ma ref., nu la manevrabilitate) nu am avut ocazia de a gusta cuplul de V8 diesel.
lascarica is offline   Reply With Quote
Old 29-04-06, 11:54   #8
einstein1984
einstein1984's Avatar
Code
Type V-6
Wet sumped
DOHC
24 valves total
Main bearings
Construction
3.44 in × 3.46 in
(193.75 cu in)
Aspiration Normal
Compressor type N/A
Intercooler None
@6200 rpm
@4500 rpm
Coolant Water
1.32 bhp/cu in
Aloooooooooo! Pamantul catre turbojack! Cu Pmax la 6200 rpm si 101.42 Nm/litru cuplu specific e motor Otto (benzinar, MAS) nu Diesel. Ai grija ca astia care nu se pricep pun botul si toarna motorina in masinuta!
einstein1984 is offline   Reply With Quote
Old 29-04-06, 20:31   #9
turbojack
turbojack's Avatar
Originally Posted by einstein1984
Aloooooooooo!........ Ai grija ca astia care nu se pricep pun botul si toarna motorina in masinuta!
ai dreeptate .Imi cer scuze,faceam doua lucruri deodata si am gresit la copy-paste.
cel dorit era JTDM de 2.4 de pe 159 ,care tunat ajunge la 300 HP:
Type S-5
Wet sumped
DOHC
20 valves total
Main bearings
Construction
3.23 in × 3.56 in
(145.664 cu in)
Aspiration Turbo D.
Compressor type
Intercooler Y
@4000 rpm
@2000 rpm
Maximum rpm
Coolant Water
1.35 bhp/cu in
Go to more manufacturers or other Alfa Romeo models
performance
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph
0-100km/h 8.40s
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile
0-Kilometre 29.20s
Top speed 228 km/h (142 mph)
Fuel Consumption 9.3/5.4/6.8 l/100km urban/extra-urban/combined
CO2 Emissions 179 g/km
Power-to-weight 120.86 bhp/ton
Old 29-04-06, 23:11   #10
einstein1984
Ajunge la 200 cp, ca si cel de 2 l de la BMW preparat de Alpina, insa e interesant (poate pentru ca ar fi singurul diesel performant pe o masina frumoasa). Motorul de 3 l, 6 cilindri in linie de la BMW ramane taticul lor. Urmat de 3l CDI de la AMG!
Old 02-05-06, 07:44   #11
200SX
4 Speed Squad Member
200SX's Avatar
[4 Speed Squad]
3.5 biturbo de la bmw cred ca e un motor destul de tare diesel
Old 02-05-06, 14:57   #12
einstein1984
Are doar 3l. Denumirea il face sa se deosebeasca de cel cu 1 turbina.
Old 04-05-06, 21:39   #13
avolocaru
avolocaru's Avatar
Salut!
In primul rand nu intreb doar ca sa ma aflu in treaba. Visez la o masina de teren... sa zicem... BETON. Pentru inceput ma intereseaza un motor diesel performant. Nu sunt foarte priceput la motoare dar am inclinatii tehnice suficient cat sa ma apuc "tuning" (asta e alta problema).
Prin urmare, daca ar fi sa va construiti o masina de teren accidentat, ce motor credeti ca ar fi cel mai potrivit?
Old 04-05-06, 21:52   #14
avolocaru
avolocaru's Avatar
Revin!
Eu chiar am intentii serioase, dar trebuie sa ma intelegeti ca inainte sa arunc cu banii trebuie sa ma interesez foarte clar, pentru ca nu-mi permit sa mai fac o incercare. Dupa ce ma voi hotara asupra a 1-2 motoare, ma intereseaza un diferential pentru spate (am inteles ca sunt unele blocabile pe roata fara aderenta), apoi asupra suspensiilor, etc.
In rest... le potrivesc eu, ce naiba sunt doar niste bucati de "fier" se taie se sudeaza... trebuie sa iasa ceva.
Old 04-05-06, 23:50   #15
turbojack
turbojack's Avatar
Revin!
Aha! deci asta era ideea.
In cea mai mare masura depinde de citi bani dispui pt. acesta investitie.degeaba iti dau date de Hummer la care doar motorul e 15 k $ daca ai bani doar de un ford in V 6.
Iar ceea ce vrei tu este ceva mai mult decit de a taia si suda niste "fiare".
deci cit vrei sa investesti in afacerera asta?Pt. ca de la bani pleaca totul .
