buna am o problema la un audi a4 2.0tdi
ultima suta de km am avut un consum de 13 litri in conditiile in care nu depasea 8 litri nicoodata. am fost la un mecanic crezand ca am atin ceva pe dedesubt sau este spart vre-un furtunas in totul pare ok.
Apoi am fost si am pus masina pe tester si mi-a dat 5 erori la motor.
am sa le postez aici si daca stie cineba sa le interpreteze il astept cu un sfat
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC 0000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 49221 123 66381
5 Faults Found
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 108.0 Nm
Speed: 0.0 km/h
Load: 2.7 %
Voltage: 12.92 V
Bin. Bits: 11000100
Temperature: 16.2°C
Bin. Bits: 10110000
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - -
Freeze Frame:
RPM: 2835 /min
Torque: 238.0 Nm
Speed: 88.0 km/h
Load: 57.3 %
Voltage: 13.98 V
Bin. Bits: 11000000
Absolute Pres.: 2121.6 mbar
Absolute Pres.: 2590.8 mbar
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 166.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00000100
Temperature: 1.8°C
Bin. Bits: 00110000
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame:
RPM: 441 /min
Torque: 152.0 Nm
Speed: 0.0 km/h
Load: 10.2 %
Voltage: 10.49 V
Bin. Bits: 00000100
Temperature: 3.6°C
Bin. Bits: 01110000
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 114.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00000100
Temperature: 8.1°C
Bin. Bits: 00110000
As vrea sa stiu daca din cauza la aceste erori a influentat consumul sau daca nu ce inseamana aceste erori
mersi
