Old 30-09-05, 13:24   #1
markizu
markizu's Avatar
[Honda]
Default Noul benzinar 1,4 TSI - 170cp - 240nm - de la VW
Benziner and Diesel with 170 HP/new GT variant with the gulf VOLKSWAGEN
Two new engines for gulf and Touran New TSI- and TDI- Volkswagen engines to the IAA: VOLKSWAGEN Touran, gulf finite times again good messages from wolf castle: To the IAA VOLKSWAGEN equips the series gulf and Touran with two high performance new engines.
The new Topdiesel brings it on 170 HP - and even a soot filter is for the first time on board. \"nothing is not over capacity - except still more capacity\", says the Autofreak, and certainly this saying is true. But large volume engines have also a disadvantage, i.e. the Spritverbrauch, which gains more in times of finite reserves, new environmental guidelines and continuously rising prices ever significance. The alternative is called with the Benziner \"downsizing\" - thus smaller engines with less capacity, which are nevertheless high performance.
The principle is for instance well-known from the compressor-loaded four-cylinders of Mercedes - who would have still before a few years thought that a e-class can be brought once of straight 1.8 litres large four-cylinder (163 HP) properly on trab? Back to VOLKSWAGEN, where one pursues a similar, perhaps still more strongly minted beginning now: The new machine had only 1,4 litres capacity, develops however 170 HP. The torque of 240 Newtonmeters full for a Benziner lies close within a broad range between 1.750 and 4.500 routes. For the force yield the combination of a mechanical loader with a conventional turbo is responsible. While road performance values are not present yet, VOLKSWAGEN numbers the normal consumption on 7,2 litres, hardly more than the 75 HP engine (1.4 litres capacity) and even less than the 102 HP machine (1,6) and the 150 HP-FSI (2,0), but slight more than the 115 HP-FSI (1,6).
The engine is marketed as \"TSI\" - with which the demarcation of the aspired FSI and the turbo- FSI (TFSI) is to be clarified. The machine is to be had first only in a new variant named gulf GT, which is settled optically not too far far away from the GTI: Sport chassis, 17 tariff aluminum wheels of BBS with 225er-Reifen, sport seats and steering wheel, load pressure indication, double final pipe and its own bumper and radiator grille interpretation are to be provided inside as outside for attention - in addition, some customers will deter. The GT - the model designation already gave it with gulf to II and III - comes end of the yearly on the market. Only in the 1.
Quarter 2006 and in a abgespeckten variant with 140 HP gives it the same machine also in the Touran, whereby may be accepted that also the gulf than 140 HP-TSI and the Touran will be later to have in the 170 HP variant, apart from gulf plus, Jetta and trade wind.
At the same time with the Benziner also the new Top version of the Zweiliter TDI in the gulf, which carries likewise 170 HP out, debuetiert. Also it is anyhow offered provisionally only as \"GT\" (and against different phrased rumors not like in former times than \"GTD\"). The torque amounts to 350 Nm with 1.900 routes, further data may VOLKSWAGEN yet abandon. Absolutely worth mentioning it is however that the variant will come in series with soot filter on the market - one hardly believes it. Into the benefit of the zusatzleistung comes also into punkto Diesels of the Touran, likewise with 170 HP and particle filters. Here the distribution are to begin in December.
l-am luat de pe un site asa ca nu stiu exact date ....oricum interesant
Fiat tempra 1.6 ien aprox 110 cai (gone)
Lancia Delta II 1.8 132 hp ..(gone)
Alfa 156 1.8 ts 150 hp (great feeling, gone)
Golf III Rabbit 1.4 mic si rau..(gone )
Honda del Sol 1,6 soch vtec turbo on !!
markizu is offline   Reply With Quote
Old 30-09-05, 14:40   #2
BASU
BASU's Avatar
da e adevarat
At the International Motor Show (Cars) in Frankfurt, Volkswagen is presenting to the general public a ground-breaking innovation in the drive sector: The world’s first twin-turbocharged FSI engine – the “Twincharger”. The compact 1.4 litre direct-injection engine develops up to 125 kW / 170 PS and has a maximum torque of 240 newton metres in the range from 1750 to 4500 rpm thanks to the combination of an exhaust turbocharger with a mechanically driven compressor.
The 1.4 litre engine delivers a power output of 90 kW / 121 PS per litre, representing a peak value for a series production four-cylinder engine. Furthermore, the “Twincharger” delivers a torque corresponding to a naturally aspirated engine with a swept volume of approx. 2.3 litres. And its fuel consumption is around 20 percent lower.
Another performance variant of this innovative TSI engine with 103 kW / 140 PS (maximum torque 220 newton metres) will be available from early 2006, initially in the Touran compact MPV, and after that the Golf will also be available with this engine.
mai multe detali la http://www.germancarfans.com/news.cf...kswagen/1.html
'06 Skoda Octavia 2 vRS 2.0TFSI 250CP++ >ex '04 Renault Megane Sedan 1.9DCI Privilege >ex '04 Smart Fortwo 0.7 Turbo
'02 Renault Laguna 2 GrandTour 1.9dCi >ex '79 Dacia 1300 Old School
'99 Daewoo Nubira 1 1.6 16v Automata + GPL >ex '12 First Bike Curier >ex '10 Moto Bike 48cc
BASU is offline   Reply With Quote
Old 30-09-05, 14:45   #3
BASU
BASU's Avatar
uite ceva interesant... motorul asta bate un 2.0 FSI
Comparison of performance and consumption values
Golf GT 1.4 Twincharger | Golf 2.0 FSI
Swept volume 1390 cc 1984 cc
Bore / stroke 76.5/75.6 mm 82.5/92.8 mm
Valves per cylinder 4 4
Compression 10.0 : 1 11.5 : 1
Supercharging Compressor -
Turbocharger
Boost pressure 2.5 bar -
Power 125 kW / 170 PS at 6000 rpm 110 kW / 150 PS at 6000 rpm
Torque 240 Nm at 1750 – 4500 rpm 200 Nm at 3500 rpm
0 – 100 km/h (0 – 62 mph) 7.9 s 8.8 s
In-gear 80 – 120 km/h (50 to 74.5 mph) 5th gear 8,0 s 9.0 s
Maximum speed 220 km/h 2 09 km/h
Consumption
Urban 9.6 l 10.6 l
Interurban 5.9 l 5.9 l
Overall (l/100 km / mpg) 7.2 l 7.6 l
CO2 emissions combined 173 g/km 182 g/km
este mai mic / consuma mai putin / cuplu mai puternic / cp mai multi... motorul perfect
Old 02-10-05, 09:42   #4
RA_2fast4u
Ford Driver
RA_2fast4u's Avatar
[FOTO]
can it be true?
RA_2fast4u is offline   Reply With Quote
Old 05-10-05, 19:41   #5
Pacatosu
Pacatosu's Avatar
[PORSCHE]
o sa aiba mare priza la public daca cifrele sint reale si nu numai de reclama. ar un motor de mare succes. ramane de vazut ce se intampla in continuare.
Pacatosu is offline   Reply With Quote
Old 23-05-07, 18:37   #6
mikinina
Default Re: Noul benzinar 1,4 TSI - 170cp - 240nm - de la VW
Nu spune nimeni nimic de pret?
Cu toate ca passatul ecu o clasa mai mare,performantele sint cele care dicteaza pretul.Cei care au la dispozitie o suma de bani au de ales intre un passat sau gt.
De ce unii se mira de performante?Ce ma mira e puterea la care se obtin cei 170 cp...cca 6000 rpm ori se stie ca in general motoarele turbo benzina au puterea maxima pe la 5000 rpm cu o plaja de cuplu de la 2000-4500rpm.
mikinina is offline   Reply With Quote
Old 23-05-07, 19:47   #7
Korne
Korne's Avatar
Mi se pare perfect normal ca 1,4TSI sa fie mai rapid decat un 2,0 FSI...cu toate ca sigur motorul de 2 litri este mai cultivat, si are un cuplu mai mare...la shpan conteaza puterea maxima...care la TSI este mai mare ca la FSI...in plus, nu cred ca exista diferenta de greutate...
Korne is offline   Reply With Quote
Old 23-05-07, 20:27   #8
banq
banq's Avatar
si ca pret e mai eftin cu 3000 dect gti vreau si eu 1,4 170Hp
banq is offline   Reply With Quote
Old 23-05-07, 22:11   #9
BYG'u
BYG'u's Avatar
[Anonymous Motorsport ]
2.0 FSI sau 2.0 TFSI ?????
BYG'u is offline   Reply With Quote
Old 23-05-07, 22:36   #10
Korne
Korne's Avatar
TSI e mai rapid decat FSI, nu decat TFSI...atentie...ma refer la cel aspirat cu 150 de cai, nu la cel turbo cu 200, si chiar mai mult(250 cai la GTI, 265 la S3...)
Old 23-05-07, 22:45   #11
BYG'u
BYG'u's Avatar
asa ma gandeam si eu , dar "banq" credk nu a inteles .)
Old 24-05-07, 01:00   #12
sco211
FullSpeed Racing Member
sco211's Avatar
[FullSpeed Racing]
masina e p strazi...
si desi ar avea ceva performante...sincer nu cred ca se compara cu GTI.
intr-adevar...are un motor d invidiat...un sunet excelent (totusi...un compresor si un turbo p acelasi motor...aproape masochist...)...
dar parca nu are genul ala de sportivitate ca GTI...nu are agresivitatea aia...
bine ca macar consuma putin si e BENZINA.
m-am saturat d atata diesel.
:P
sco211 is offline   Reply With Quote
Old 24-05-07, 08:20   #13
DnI
DnI's Avatar
Boost pressure 2.5 bar - din ce draq au facut motorul asta nu inteleg. f tare.
DnI is offline   Reply With Quote
Old 24-05-07, 10:37   #14
Sindrom
Sindrom's Avatar
pai da sunt nemti...astia sunt in stare sa faca cam ce isi pun in cap!!!
Sindrom is offline   Reply With Quote
Old 24-05-07, 10:46   #15
SUPAPA_Jr
SUPAPA_Jr's Avatar
E motorul perfect...platim impozit mic ) are putere pe care te poti baza inca din ture mici
SUPAPA_Jr is offline   Reply With Quote
