BBR MINI COOPER S PHASE 5 - THE ALL NEW BBR COOPER TURBO 300
Our new flagship turbo conversion, again a full package of engine, transmission, suspension, brake and tyre modifications, but
this time something's a bit different! The inefficient supercharger has been removed and replaced with our BBR cast manifold and hybrid turbo! The standard top mounted intercooler is ditched in favour of our unique BBR Ram-Air, air box. In addition there are 3 progressively higher boost settings automatically controlled via load and throttle position, this ensures progressive and smooth acceleration, under all conditions, even through town! Our Ram Air system spools the turbo quickly, giving lightning fast throttle response which all in all adds up to a truly electrifying drive. We believe this is the most powerful BMW mini world wide, with over 300BHP and aimed only at the serious driver!
Engine Specification
BBR Big valve, gas flowed and ported Cylinder head fitted with BBR camshaft
BBR Solid tappet and uprated valve spring assembly
BBR Cast manifold and hybrid turbo
BBR Ram-Air air box, pipe work and filter
BBR modified high flow fuel system and injectors
BBR 3 stage boost system
BBR auxiliary high flow water pump assy. and redesigned coolant system
BBR front mounted high flow intercooler
BBR S/S exhaust system
BBR Ram Induction Bonnet Air Inlet Venturi kit
and of course BBR custom mapped software
Transmission/Suspension/ Brake and Tyres
BBR Limited Slip differential
Optional BBR revised gear ratios
BBR PowerGrip suspension
BBR big brake conversion, AP 4 pot callipers with fast road pads with ventilated drilled discs, and replacement S/S braided hoses (fits std 17" wheels)
BBR fitted Goodyear F1 road tyres
