View Poll Results: Ce paprere aveti despre RX400h
Cel mai tare LUV(luxury utility vehicle) 6 42.86%
merge 6 42.86%
o incercare nereusita 2 14.29%
Voters: 14. You may not vote on this poll
Old 08-10-05, 18:00   #1
BASU
BASU's Avatar
Default Hibridul Lexus RX400h
sa va prezint noul hibrid Lexus RX400h
Dimensions
Body type: Five-passenger luxury utility vehicle
Construction: Welded-steel unibody
Overall length: 187.2 in (4,755 mm)
Overall width: 72.6 in (1,845 mm)
Overall height: 68.5 in (1,740 mm) (unloaded)
Wheelbase: 106.9 in (2,715 mm)
Ground clearance: 7.1 in (180 mm)
Approach angle: 28.3 degrees
Departure angle: 24.3 degrees
Cargo capacity (max): 38.3 cubic feet [1] (rear seats forward)/84.7 cubic feet [1] (rear seats folded)
Curb weight: 4,365 lb (1,981 kg)
Tow capacity (max): 3,500 lb (1,588 kg) [2]
Fuel-tank capacity: 17.2 gallons (65 L)
Headroom (front/rear): TBD
Legroom (front/rear): 42.5/36.4 in
Shoulder room (front/rear): 57.9/57.1 in
Performance
- 3.3-liter, four cam, four valves per cylinder with continuously Variable Valve Timing with intelligence (VVT-i)
- Front and rear high-output, permanent-magnet electric-drive motors
- 268 total system horsepower
- Electronically-controlled Continuously Variable Transmission (ECVT)
- Independent MacPherson strut front suspension with coil springs, gas-pressurized shock absorbers and stabilizer bar
- Independent strut rear suspension with coil springs, gas-pressurized shock absorbers and stabilizer bar
- Part-time all-wheel drive (AWD)
- Electronic, engine-speed-sensing, progressive power-assisted rack-and-pinion steering
- Four-wheel power-assisted disc brakes with regenerative function
- 18-in alloy wheels with 235/55VR18 all-season tires
- Estimated fuel consumption: 31/27 mpg city/highway [3]
Luxury
- Brushed-aluminum interior trim
- Leather-trimmed interior
- Leather-trimmed steering wheel and shift knob
- Steering-wheel-mounted cruise control, audio and display controls
- Power tilt-and-telescopic steering column with automatic tilt away
- Lexus voice-activated DVD Navigation System [4] with backup camera [5] and Bluetooth® technology [6]
- Lexus eight-speaker 132-watt [7] Premium Sound System with in-dash, single-feed, six-disc CD auto-changer
- Available Mark Levinson® [8] 11-speaker 210-watt [9] Premium Audio System with in-dash, single-feed, six-disc CD auto-changer
- Available Lexus DVD Rear-Seat Entertainment System (RSES)
- Roof-mounted antenna with in-glass FM-diversity system
- 10-way driver's (including lumbar) and eight-way front passenger's power seats
- Height-adjustable headrests for all seats
- Lexus Memory System for power driver's seat (except lumbar), outside mirrors and steering wheel
- Available heated front seats
- Reclining, sliding rear seat (40/20/40 split)
- Dual-zone automatic climate control with interior air filter and automatic recirculation mode
- Power tilt-and-slide moonroof with one-touch open/close and sliding sunshade
- Power windows with one-touch auto open/close feature
- Remote-linked moonroof and window opening
- Retained accessory power for windows and moonroof
- Electrochromic (auto-dimming) inside mirror with compass [10] and outside mirrors
- Power door locks with driver's two-turn unlock feature
- Power rear door
- Multifunction, in-key remote entry system with rolling-code technology
- Sliding center console with cupholders and storage bin
- HomeLink® universal transceiver to operate compatible garage, gate, home lighting and home security systems
- Accessory power outlet in cargo area
- Towing Prep Package [2]
- Illuminated entry system
- Electroluminescent instrumentation
- Interior electronic fuel-filler door release
- Lexus Personalized Settings (LPS) [11] to personalize electronic functions
- Roof rack with rails
- Automatic on/off headlamps with 30-second auto-off delay
- Dual illuminated visor vanity mirrors
- Outside temperature gauge
- Sun visor extensions
- Carpeted floor mats
ID:	45255   Click image for larger version
ID:	45256   Click image for larger version
ID:	45258   Click image for larger version
'06 Skoda Octavia 2 vRS 2.0TFSI 250CP++ >ex '04 Renault Megane Sedan 1.9DCI Privilege >ex '04 Smart Fortwo 0.7 Turbo
'02 Renault Laguna 2 GrandTour 1.9dCi >ex '79 Dacia 1300 Old School
'99 Daewoo Nubira 1 1.6 16v Automata + GPL >ex '12 First Bike Curier >ex '10 Moto Bike 48cc
BASU is offline   Reply With Quote
Old 08-10-05, 18:02   #2
BASU
BASU's Avatar
Safety
- Driver's and front passenger's advanced airbag system (SRS) [12]
- Front seat-mounted side airbags (SRS) [12]
- Front and rear Roll-Sensing Curtain Airbags (RSCA) (SRS) [12]
- Driver's-knee airbag [12]
- Three-point seatbelts for all seating positions, pre-tensioners with force limiters for front seats
- Automatic Locking Retractor/Emergency Locking Retractor (ALR/ELR) seatbelts for all passenger seating positions. Emergency Locking Retractor (ELR) for driver's seat
- Height-adjustable front shoulder belt anchors
- Child Restraint Seat (CRS) tether anchor brackets for rear outboard seating positions
- Four-sensor, four-channel Anti-lock Braking System (ABS)
- Vehicle Dynamics Integrated Management (VDIM) [13]
- Traction Control (TRAC)
- Brake Assist [14]
- Electronic Brakeforce Distribution
- Highly rigid body structure with front and rear crumple zones
- Side-impact door beams
- Impact-dissipating upper interior trim
- Collapsible steering column
- Collapsible brake and driver's footrest pedals
- High-Intensity Discharge (HID) headlamps with dynamic auto leveling
- Adaptive Front Lighting System (AFS)
- Daytime running lights
- Integrated foglamps
- LED taillamps
- Water-repellent front-door glass
- Available rain-sensing variable-intermittent windshield wipers with mist cycle
- Rear intermittent wiper
- Rear-window defogger with auto-off timer
- Power-adjustable outside mirrors with defoggers
- Vehicle theft-deterrent and engine immobilizer system, with in-key transponder
- Auto-retracting tonneau cover
- First aid kit
- Tool kit
Warranty
Lexus Limited Warranty: 4 years/50,000 miles
Powertrain Warranty: 6 years/70,000 miles
Corrosion Perforation Warranty: 6 years/unlimited mileage
Hybrid Vehicle System Warranty: 8 years/100,000 miles
- Hybrid control module
- Battery control module
- Hybrid vehicle battery pack
- Inverter with converter
Pret
starting at 49.060$
Individual Factory Options
- Lexus DVD Rear-Seat Entertainment System (RSES) (includes two pairs of wireless headphones [2]) - $1,840 [3]
- Heated Front Seats with Rain-Sensing Wipers - $665 [3]
- Mark Levinson® [4] 11-speaker, 210-watt [5] Premium Audio System with in-dash, single-feed, six-disc CD changer - $980 [3]
ID:	45260   Click image for larger version
ID:	45261   Click image for larger version
ID:	45263   Click image for larger version
Old 09-10-05, 03:38   #3
pimp_lex
pimp_lex's Avatar
cel mai tare.....discutabil, e un SUv extraordinar asta e clar.
Dar cred ca ar trebui ceva intre \"cel mai tare\" si \"merge\".
Oricum e cam greu sa gasesti niste raspunsuri elocvente pe forum aici unde masina asta e absolut necunoscuta.
pimp_lex is offline   Reply With Quote
Old 09-10-05, 10:08   #4
Mustang
Mustang's Avatar
N-arata deloc rau...
Old 18-10-05, 15:26   #5
dshockevo
dshockevo's Avatar
hmmm... frumushica masina ! dar cu siguranta sunt SUV-uri si mai tari !!!
dshockevo is offline   Reply With Quote
Old 18-10-05, 16:40   #6
teddy
teddy's Avatar
nice car, tehnologia hibrid lasata 'libera' pe piata e inca prea putin semnificativa pentru a face din acest lexus dintr-un suv putin mai tare decat mediu in 'cel mai bun suv din lume' lol
teddy is offline   Reply With Quote
Old 18-10-05, 21:00   #7
Skma
Skma's Avatar
Un suv cu foarte mare potential
Skma is offline   Reply With Quote
Old 22-10-05, 21:15   #8
Bogdan_16v
Guest
Posts: n/a
Indiscutabil, cel mai inovativ SUV...in teste, consumul mediu n-a sarit de 8-9% in regim mixt, si asta la un V6 si o putere cumulata de aproape 300cp si o acceleratie de 7.5 sec! Hibridele isi vor spune cuvantul.
