Old 22-02-08, 12:45   #1
RoSonic
4 Speed Squad Member
RoSonic's Avatar
[4 Speed Squad]
Default Honda Integra Type-R Sedan by RedZone Performance
ID:	460569Click image for larger version
ID:	460564Click image for larger version
Masina: Honda Integra Type-R Sedan din 1997 (motor 1.8l cu cilindree marita la 2l)
Putere obtinuta: 525hp
Tuner: RedZone Performance, California
Modificari:
Motor
B18 by RedZone Performance
Polished and balanced rotating assembly
RS Machines sleeves, bored to 84mm
Wiseco 9.5:1-compression pistons w/rings
IB Spec rods
Type-R oil pump
Moroso oil pan
ATI Super Damper harmonic damper
BLOX Racing Type B camshafts
BLOX Racing adjustable cam gears
SuperTech Performance valve springs and retainers
SuperTech black nitride coated valves
3-angle valve job with new seals
GT35R ball bearing turbocharger
Spoolin Performance top-mount turbo manifold
Tial 44mm wastegate
Tial blow-off valve
Custom aluminum 2.5" turbine-to-intercooler piping
Custom aluminum 3.0" intercooler-to-compressor piping
18in x 24in intercooler with custom end tanks
Edelbrock Victor X intake manifold
BLOX Racing 70mm throttle body
1000cc injectors
FJO Racing Products injector driver
Trick Flow fuel filter and regulator
Custom 3" down pipe, 4" exhaust by RedZone
RedZone custom breather/catch can
Koyo radiator with Gaza overflow can
Spearco radiator hoses with t-bolt clamps
BLOX Racing radiator bracket
BLOX Racing oil cap
RedZone stage-3 clutch
1999 Honda Civic Si gearbox
Kaaz limited-slip differential
Gator axles
Suspensie
Function and Form Type-II coilover kit
Spoolin' Performance front traction bar
BLOX Racing rear lower control arms
Benen Industries B-pillar bar
Roti/Frane
Power Slot rotors
Type R master cylinder
Custom brake lines and tuck
Dunlop-edition CP-R 16x8" +42 offset
Neo-Cron lug nuts
Falken Azenis RT-615 250/45 16
Exterior
Top Fuel front lip
Honda door window visors
Benen Industries rear tow hook
Interior
Mugen gauge cluster
F1 Spec front seats
Garrett boost gauge
Pioneer head unit
ID:	460545   Click image for larger version
ID:	460546   Click image for larger version
ID:	460548   Click image for larger version
ID:	460549   Click image for larger version
ID:	460551   Click image for larger version
ID:	460552   Click image for larger version
ID:	460554   Click image for larger version
ID:	460555   Click image for larger version
ID:	460557   Click image for larger version
ID:	460558   Click image for larger version
ID:	460560   Click image for larger version
ID:	460561   Click image for larger version
ID:	460563   Click image for larger version
ID:	460565   Click image for larger version
ID:	460567   Click image for larger version
ID:	460568   Click image for larger version
ID:	460571   Click image for larger version
ID:	460572   Click image for larger version
ID:	460574   Click image for larger version
ID:	460575   Click image for larger version
Old 22-02-08, 13:05   #2
cosmin-tuning
cosmin-tuning's Avatar
Default Re: Honda Integra Type-R Sedan by RedZone Performance
525cp :-O nici nu vreau sa ma gandesc cum trage
cosmin-tuning is offline   Reply With Quote
Old 22-02-08, 13:09   #3
Mishto, mishto! Si e o Honda orignala, cu volan pe dreapta!
Nu stiam ca Integra e si in varianta sedan, aduce la fata cu Accord mai vechi!
Old 22-02-08, 13:23   #4
simpla, frumoasa si foarte furioasa
Old 22-02-08, 13:38   #5
mad_aurel
real honda, 525cp merita............
Old 22-02-08, 13:55   #6
UNLORD
UNLORD's Avatar
Imi place! Sunt curios cum pune puterea pe rotile din fatza.
Old 22-02-08, 16:53   #7
Danutz_crx
Danutz_crx's Avatar
frumoasa masinutza...dar totusi 525 de cai sunt prea multi pt tractiune pe fatza
Danutz_crx is offline   Reply With Quote
Old 22-02-08, 19:36   #8
jacksoon
cu gust..simpla dar totusi complexa......
Old 22-02-08, 20:31   #9
gunball
gunball's Avatar
tot respectul pentru cine a facut-o...525CP
Old 22-02-08, 20:44   #10
carutasu
carutasu's Avatar
frumos...respecte.
carutasu is offline   Reply With Quote
Old 22-02-08, 22:31   #11
simplu si cu gust....foarte frumoasa
Old 22-02-08, 22:49   #12
e crima masina :>
Old 22-02-08, 23:39   #13
DaNy>DmN
Foarte tare masina
Old 22-02-08, 23:48   #14
maryo86
maryo86's Avatar
Mama !!! E o bestie!! Dar inca odata spun.Hai sa vedem pe site cate o masina din tara.Sa-si arate fiecare "copilasul"
maryo86 is offline   Reply With Quote
Old 23-02-08, 01:23   #15
iulian_rs
tare masina da atatea martoage pe puntea fata nu stiu cum sar descurca si in viraje in rest masina e super k mai ales ca e honda si dupa cum bine stim face cela mai bune motoare aspirate (parerea mea)
iulian_rs is offline   Reply With Quote
