Old 11-02-08, 13:14   #1
RoSonic
4 Speed Squad Member
RoSonic's Avatar
[4 Speed Squad]
Default Subaru Impreza by Brainchild Customs
Masina: Subaru Impreza WRX (2002)
Proprietar: Alex Witkin de la Brainchild Customs.
Lista de modificari:
Motor:
o JDM Forester Turbo Motor EJ257 2.5L (Forged Rods, Forged Crank, HyperCast Pistons)
o Brainchild Customs Custom One-off Prototype Intake Manifold (1 of 1)
o Brainchild Customs Custom One-off 3” exhaust system with modified TurboXS RFL Ti Canister
o NX Direct Port Nitrous Kit w/ Gen-X2 upgrade
o TurboXS Prototype T04R Turbo Kit (w/ 38mm Tial Wastegate, Flanges, Piping) 1 of 2
o TurboXS UTEC Engine Management System
o TurboXS Remote map selector
o TurboXS Hyperflow Front Mount Intercooler
o TurboXS Downpipe
o TurboXS Test Pipe
o TurboXS v2 Up-pipe
o TurboXS Modified Intake
o TurboXS Racing Bypass Valve RFL
o TurboXS High Performance Boost Controller
o TurboXS High Flow Fuel Rails(modified to fit 2.5L motor)
o JDM ARC Radiator
o JDM Beatrush Alternator Cover
o JDM Beatrush Oil Filler Cap
o JDM Beatrush Pitch Stopper
o JDM Beatrush Radiator Air Cooling Panel
o JDM Blitz Radiator Cap
o JDM Cusco Heavy-Duty Engine Mounts
o JDM GReddy Oil Catch Can
o JDM Ku Engineering 70mm billet Throttle Body
o JDM Power Enterprises 800cc Injectors
o JDM Prova Brake Fluid Cap
o JDM Prova Clutch Fluid Cap
o JDM SARD Fuel Pressure Regulator
o JDM Zero/Sports Unequal Length Exhaust Manifold
o JDM Zero/Sports Polished Intake pipe
o DEI Turbo “Blanket” heat wrap
o NASA gold heat reflective foil
o Kartboy exhaust hangers
o Optima Red Top Battery relocated to trunk w. custom mount
o Process West Oil Cooler
o Relocated and powder coated Coolant Overflow tank
o Samco 9 piece blue coolant hose kit
o Samco Blue Radiator Hoses
o TGV Delete
o Walbro 255 High Flow In Tank Fuel Pump
Transmisie:
o Custom geared PPG Dogbox Gearset Straight cut 1-4, stock 5(first one in US)
o Driveshaftshop.com 800hp axles
o Driveshaftshop.com Lightweight Aluminum Driveshaft
o PPG Interlocker
o PPG Billet Shift Forks
o Energy Suspension Shifter Bushings
o B&M Short Throw Shifter
o JDM Cusco Transmission Mount
o JDM Exedy 3-Puck racing clutch kit
Suspensie/Frane:
o Custom StopTech Front Big Brake Kit(4-piston ST-40 Caliper, 355mm 2 piece rotor)
o StopTech Rear Big Brake Kit(2-piston ST-20 Caliper, 328mm 2 piece rotor)
o JDM Beatrush 12 point under brace
o JDM Beatrush Front Compliance Brackets
o JDM Beatrush Front Strut Tower Bar
o JDM Cusco Front Sway Bar
o JDM Cusco Rear Sway Bar
o JDM Cusco Front Sway Endlinks
o JDM Cusco Rear Lateral Links
o JDM Cusco Front Lateral Links
o JDM Cusco Trailing Arms
o JDM Project Kics 5mm wheel spacers
o JDM TEIN Type FLEX Coilovers
o JDM TEIN EDFC
o ARP Extended Wheel Studs
o Energy Suspension Master Bushing Kit
o GTSpec Cowl Stay “fender” Braces
o Perrin Rear Sway Links
o ATE Super Blue Racing Brake Fluid
o Hawk HP Pads
o StopTech Stainless Steel Brake Lines (Front and Rear)
Interior/Electronica/Siguranta:
o AP Racing Air Jacks(Only known enclosed system in the world)
Custom install by Piper Motorsport
o Custom 9-Point JGTC/WRC Style Roll Cage with full gusseting, and WRC boxes (Piper Motorsport)
o STACK ST81101sr Digital Dash Display
o WRC Rally-Spec Carbon Fiber Molded Front Door Cards
o WRC Rally-Spec Carbon Fiber Molded Rear Door Card
o WRC Rally-Spec Carbon Fiber Rear Bulkhead/Firewall
o WRC Rally-Spec Carbon Fiber Rear Seat Trim Panel
o WRC Rally-Spec Carbon Fiber Rear Parcel Shelf
o JDM Blitz FATT 2 Dual Turbo Timer
o JDM BRIDE Zeta III Driver Seat
o JDM BRIDE Brix II Passenger Seat
o JDM Defi Link EGT Gauge
o JDM Defi Link Fuel Pressure Gauge
o JDM Defi Link Boost Gauge
o JDM Defi Link Gauge Controller
o JDM Takata 340mph Harnesses
o Carbon Concepts Center gauge pod
o Custom ATL dual dry break race fueling system (Custom “Race Gas On the Fly” system, auxiliary tank)
o Custom ATL Fuel Cell
o Weldon 1000hp Fuel Pump and Dual Weldon Filters(for alternate fuel system)
o Piper Motorsport Custom Aluminum Center Console, floor pans, and trunk trim
o Electronic Fire Supression System
o Sparco 383 Suede Steering Wheel
o Sparco Hub Adaptor
o Sparco Quick Release Wheel Hub
o Battery Master Kill Switch
Exterior:
o Full Exterior and Interior Paint by GARY BEST KUSTUMZ
Exterior: “HID Silver” Silver Base with 15 coats of Red->Blue Pearl
Interior: Gold roof, pillars, and cage. Black Floors and trunk. Two-Tone Door Jambs.
o JDM CWEST side skirts
o JDM CWEST front Bumper v2
o JDM CWEST Rear lip v1
o JDM CWEST side marker covers
o JDM Liberal replica Front grill
o JDM 5Zigen Blue Extended Lug Nuts
o JDM OEM STi Projector Headlights
o JDM TEIN Hood Dampers(painted)
o APR Racing GT200 Carbon Fiber Wing
o Kaminari Carbon Fiber Reverse Cowl Hood
o 3M 20% SolarGard Tint
o Carbon Concepts Carbon Fiber Fuse Box Cover
o Shaved Corner Markers
o Shaved Antenna
o Shaved and smoothed door sills
o LNR Carbon Boost Solenoid Cover
o MOMO Shift knob
o WRC Rally-Spec Carbon Fiber Mirrors
ICE:
o Pioneer AVIC-D1 In-Dash Touch-Panel DVD Multimedia AV Navigation Receiver
o Custom paint matched Fiberglass Enclosure in glovebox
- 2 4” Polk Audio speakers
Roti:
o JDM Advan RGII wheels 18x8.5 (Gold)
o JDM Advan A048 265/35/18
o Dunlop FM901 235/45/18
O parte dintre premiile castigate:
Best Wild Subaru
With Team EMOTION
December 15, 2007
Hot Import Nights Miami
Miami, FL
Best in Show Performance
With Team EMOTION
December 15, 2007
Miami, FL
2nd Place Race Car/Pro Street Class
October 6, 2007
Back to Bethesda Car Show
Bethesda, MD
Best in Show
With Team EMOTION/Brainchild Customs Show Team
September 23, 2007
AVFD Charity Car Show
Arbutus, MD
Best Import
September 23, 2007
Arbutus, MD
Best Wild Subaru
With Team EMOTION/East Coast Elite
August 25, 2007
Hot Import Nights Los Angeles
Los Angeles, CA
dar lista e mult mai lunga...
ID:	450183   Click image for larger version
ID:	450184   Click image for larger version
ID:	450186   Click image for larger version
ID:	450187   Click image for larger version
ID:	450189   Click image for larger version
ID:	450190   Click image for larger version
ID:	450192   Click image for larger version
ID:	450193   Click image for larger version
ID:	450195   Click image for larger version
ID:	450196   Click image for larger version
ID:	450198   Click image for larger version
ID:	450199   Click image for larger version
ID:	450201   Click image for larger version
ID:	450202   Click image for larger version
Old 11-02-08, 13:30   #2
Default Re: Subaru Impreza by Brainchild Customs
e super tare titiu.....fuge da si consuma
Old 11-02-08, 13:43   #3
xtrim
xtrim's Avatar
NFS stile ! B-)
Old 11-02-08, 14:03   #4
spiri14
e da... un exemplu de urmat pt cei ce modifica... nu doar resoftare, un kit si toba..
Old 11-02-08, 14:04   #5
Gabytzu`
Gabytzu`'s Avatar
mama :O:O...nu se mai termina lista cate modificari au facut...dar rezultatul e cool
Gabytzu` is offline   Reply With Quote
Old 11-02-08, 14:07   #6
impunatoare masina... multa munca depusa la ea
Old 11-02-08, 14:11   #7
intru-un cuvant... !!! SUBARU !!!
Old 11-02-08, 14:12   #8
NT33EXE
NT33EXE's Avatar
o masina la un asemenea nivel nu vom vedea la noi prea curand...
NT33EXE is offline   Reply With Quote
Old 11-02-08, 14:29   #9
in nici un caz nu o sa vezi pe la noi asha ceva curand...foarte frumos
Old 11-02-08, 15:08   #10
golidix
golidix's Avatar
eu nu inteleg ceva ce pnm sunt alea din porbagaj ca nu am mai avzut asa ceva pana acum masina arata bine e subaru dar mie unu nu imi plac farurile
Old 11-02-08, 17:11   #11
Bass-Evolution
Honda Driver
Bass-Evolution's Avatar
[Honda]
"alea" din portbagaj sunt gurile de umplere pentru rezervor si daca vad eu bine compensatoarele pentru amortizoare, pompa sau pompele de benzina, daca gresesc plz corectati-ma, iar in ceea ce priveste farurile, tine de gusturi, dar desi una dintre cele mai controversate variante de Impreza, e una de care ne vom aminti.
'95 Subaru Impreza WRX GC8
'96 Renault Megane Coach
'95 Honda Civic EG9
www.EvolutionDetailing.ro - polish, reconditionari faruri, tratamente interioare si multe altele.
Bass-Evolution is offline   Reply With Quote
Old 11-02-08, 17:46   #12
mareo
mareo's Avatar
ce lista de modificari....asa mai merge tunareala
Old 11-02-08, 17:52   #13
crdi
crdi's Avatar
daca nici asta nu e modificata nimica nu e . ori cum sa ati trimita cineva lincu lu Sebastian ,
foarte tare mashina din toate punctele
crdi is offline   Reply With Quote
Old 11-02-08, 18:06   #14
Foarte frumos.. foarte multi bani bagati si munca .. foarte multa.. ,dar nu avem si noi niste date .. pana la cati cp .. a ajuns.. km/h .. stiu oricum sa cifrele trebuie sa fie destul de mari ! Super masina
Old 11-02-08, 18:45   #15
Foarte tare frate!
Oricum, asta e generatia cea mai tare de Impreze, nu astea care au aparut si sunt hatch, desi in SUA se vinde si un model sedan!
