General specifications
Record last updated 12 / 05 / 2007
Country of origin Germany
Numbers built N/A
Year of introduction 2008
Introduced at 2007 Essen Motor Show
Engine
Engine B 6
Engine Location Rear , longitudinally mounted
Configuration light alloy block and head
Displacement 3.598 liter / 219.6 cu in
Bore / Stroke 100.0 mm (3.9 in) / 76.4 mm (3 in)
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Bosch MS 3.1 Fuel injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body unitary steel
Front suspension McPherson struts, coil springs, dampers, anti-roll bar
Rear suspension multi-link, dual coil springs, anti-roll bar
Steering rack-and-pinion, power assisted
Brakes vented carbon fibre discs, all-round
Gearbox 6 speed Sequential
Drive Rear wheel drive
Dimensions
Weight 1130 kilo / 2491.2 lbs
Performance figures
Power 420 bhp / 313 KW
Torque 420 Nm / 310 ft lbs
BHP/Liter 117 bhp / liter
Power to weight ratio 0.37 bhp / kg
