Old 06-12-07, 08:40   #1
boom
boom's Avatar
Talking Brabus SLR McLaren Roadster
General specifications
Record last updated 12 / 05 / 2007
Country of origin Germany
Numbers built N/A
Year of introduction 2007
Introduced at 2007 Essen Motor Show
Engine
Engine AMG 90º V 8
Engine Location Front , longitudinally mounted
Displacement 5.439 liter / 331.9 cu in
Bore / Stroke 97.0 mm (3.8 in) / 92.0 mm (3.6 in)
Compression ratio 8.8:1
Valvetrain 3 valves / cylinder, SOHC
Fuel feed Fuel injection
Aspiration Supercharger
Drivetrain
Chassis/body carbon fibre monocoque
Front suspension double wishbones, coil springs over gas pressurised dampers, stabilizer
Rear suspension double wishbones, coil springs over gas pressurised dampers
Steering rack-and-pinion, power assisted
Brakes carbon fibre vented discs, all-round
Gearbox 5 speed Automatic
Drive Rear wheel drive
Dimensions
Length / Width / Height 4656 mm (183.3 in) / 1908 mm (75.1 in) / 1261 mm (49.6 in)
Wheelbase / Track (fr/r) 2700 mm (106.3 in) / 1638 mm (64.5 in) / 1569 mm (61.8 in)
Performance figures
Power 650 bhp / 485 KW @ 6500 rpm
Torque 780 Nm / 575 ft lbs @ 3250 rpm
BHP/Liter 120 bhp / liter
Top Speed 337 km/h / 209 mph
0-60 mph Acceleration 3.5 s
ID:	402220   Click image for larger version
ID:	402221   Click image for larger version
ID:	402223   Click image for larger version
ID:	402224   Click image for larger version
boom is offline   Reply With Quote
Old 08-12-07, 17:27   #2
boy_wonder
boy_wonder's Avatar
Default Re: Brabus SLR McLaren Roadster
ID:	403674   Click image for larger version
ID:	403675   Click image for larger version
ID:	403677   Click image for larger version
Old 17-12-07, 14:03   #3
royall24xxx
royall24xxx's Avatar
Cool Re: Brabus SLR McLaren Roadster
... e un M-B si nu mai trebuie spus nimic ... sigla-ti spune tot
royall24xxx is offline   Reply With Quote
Old 18-12-07, 22:33   #4
obsidianblack8
obsidianblack8's Avatar
Interiorul e ''criminal''.
obsidianblack8 is offline   Reply With Quote
Old 28-12-07, 09:06   #5
adisoruc
Seat Driver
adisoruc's Avatar
[SEAT]
putin rabdare, pariu ca la vara il vedem si pe drumurile noastre?
adisoruc is offline   Reply With Quote
Old 28-12-07, 21:43   #6
petreals
Mitsubishi Driver
petreals's Avatar
[Mitsubishi]
interiorul te lasa fara cuvinte...
petreals is offline   Reply With Quote
Old 30-12-07, 00:25   #7
redbull2007
redbull2007's Avatar
super tare Interioru .. si roshu` ala iti impune R3Sp3c4 .. !
redbull2007 is offline   Reply With Quote
