Old 27-02-06, 22:51   #1
RoSonic
4 Speed Squad Member
RoSonic's Avatar
[4 Speed Squad]
Default Ford FPV DRIF6 Concept (Australia)
Ford FPV DRIF6 Concept (Australia) - realizat de Ford Performance Vehicles si Prodrive si dedicat driftingului.
Dealii pe scurt:
- 4.0-litri,DOHC, 6 cilindri in linie, turbo
- putere: 380kW(510hp)
- cuplu: 700Nm
Fisa tehnica:
DRIF6 Specifications
Body:Lightweight F6 Typhoon, Four-door sedan
Engine:Turbo-charged and intercooled 4.0-litre DOHC in-line six cylinder
Turbo charger:Garrett GT 35/40
Induction system:Hand-made twin-plenum manifold with custom three-inch pipes from
turbo charger and intercooler. Ram air intake from lower front bumper into K & N pod filter
Engine Management System:Customised calibration
Exhaust:Stainless Steel three-inch straight-through with side outlet
Intercooler:Front mounted 600mm x 300mm x 75mm
Power: Aprox 380kW
Torque:Aprox 700Nm
Clutch:AP Racing twin-plate
Differential:Locked rear differential, 3.73:1 final drive
Brakes:Cross-drilled and pillar ventilated 355mm x 32mm front and 330mm x 28mm rear rotors with Brembo six-piston monoblock front and four-piston rear callipers. HIS braided hoses. Pull-operated hydraulic handbrake with Tilton brake proportioning valve.
Seats:MOMO
Steering wheel: MOMO
Harnesses:Four-point MOMO race harnesses
Battery:Optima; mounted in rear of cockpit with central-mounted kill switch
Gauges:VDO monster tacho, Autron tyre pressure monitoring system
Wheels:19x8 inch five-spoke alloy in Dark Argent
Tyres:245/35 ZR19 Dunlop SP Sport Maxx
Lubricant:Castrol Edge 0W-40
[Concept Cars...]
ID:	72387   Click image for larger version
Old 27-02-06, 23:30   #2
turbogrizzly
Default Re: Ford FPV DRIF6 Concept (Australia)
serrious shit.....
turbogrizzly is offline   Reply With Quote
Old 28-02-06, 07:13   #3
dexter_20
dexter_20's Avatar
no way man! out of control.restect Ford Performance Vehicles & Prodrive
dexter_20 is offline   Reply With Quote
Old 28-02-06, 10:57   #4
Cosmin255
Cosmin255's Avatar
WoW , de-a dreptul
Cosmin255 is offline   Reply With Quote
Old 28-02-06, 12:09   #5
Mustang
Mustang's Avatar
superb !
Old 28-02-06, 12:14   #6
Eugen_TL
Renault Driver
Eugen_TL's Avatar
n-as schimba nik la ea ! misto
Eugen_TL is offline   Reply With Quote
Old 28-02-06, 13:46   #7
Zerofast
Zerofast's Avatar
[Crazy Drivers]
marfa de nota 10
Zerofast is offline   Reply With Quote
Old 28-02-06, 13:58   #8
Spark
Suzuki Driver
Spark's Avatar
[Suzuki]
bestiala ... !
Spark is offline   Reply With Quote
Old 28-02-06, 15:01   #9
SUN
Presedinte SUN RACERS
SUN's Avatar
[Sun Racers]
M-as deda la nishte drifturi sinucigashe cu frumusetzea asta....ahhhh...ce pot sa zic...Drift Dreams boyz!!!!
SUN is offline   Reply With Quote
Old 28-02-06, 17:07   #10
Urban_Racing
Honda Driver
Urban_Racing's Avatar
[Honda]
wow! senzatzionala ....super! e imbucurator ca au inceput sa faca mashini special pt drift! yo unu sunt inebunit de drifting! i love it !!!!
Urban_Racing is offline   Reply With Quote
Old 28-02-06, 17:16   #11
SUN
SUN's Avatar
[Sun Racers]
....Drifting Dreams.....
Old 28-02-06, 17:44   #12
wlady
Design Team Member
wlady's Avatar
I LOVE DRIFTING => I LOVE THIS CAR .. arata si bine .. are si performante ... sa vedem ce poate la drifituri
wlady is offline   Reply With Quote
Old 28-02-06, 18:20   #13
SUN
SUN's Avatar
[Sun Racers]
wlady tu n-ai facut in viatza ta un drift....si zici k \"iubeshti\" drifturile...ai idee cu ce se mananca?
Old 01-03-06, 08:04   #14
wlady
Design Team Member
wlady's Avatar
sun ... tu ai facut ? acum pe bune .. eu am facut cu un logan .. insa nu pe drum public .. ca deh n-am carnet .. oricum am zis ca la 18 ani imi voi lua o silvia s15 .. cat o fi imi iau una
BMW 318i E90 /// Le-Mans Blau /// M Sport /// Conversie LCI /// Style 135
Plasti-DIP - DipYourCar
Old 01-03-06, 08:05   #15
wlady
Design Team Member
wlady's Avatar
ca sa definim drifturile : derapaje controlate , si chiar am facut nu chiar asa de spectaculoase ca doar era o tractiune fata dar detul de distractive
