Old 12-01-06, 22:04   #1
RoSonic
4 Speed Squad Member
RoSonic's Avatar
[4 Speed Squad]
Default Lincoln MKX
Lincoln MKX - crossover utility vehicle (CUV) din clasa de lux
Motorizare: 3.5L DOHC 24-valve V6, 250hp @ 6250rpm
Transmisie: cutie automata cu 6 trepte
ID:	61870   Click image for larger version
ID:	61871   Click image for larger version
ID:	61873   Click image for larger version
Old 12-01-06, 22:06   #2
RoSonic
RoSonic's Avatar
[4 Speed Squad]
Pentru cei interesati de detalii, iata fisa de specificatii
ENGINE
Type
Manufacturing Location
Lima Engine Plant, Ohio
Configuration
60 degree V6, aluminum block and heads
Intake Manifold
Composite, split plenum
Exhaust Manifold
Cast iron
Crankshaft
Forged steel
Redline
6700 RPM
Idle Speed in Drive/Neutral
620 RPM (640 with trailer tow package)
Throttle Body
65mm, electronic
Valvetrain
DAMB, 4 valves per cylinder, intake variable camshaft timing
Valve Diameter
Intake: 37mm; Exhaust: 31mm
Pistons
High temperature cast aluminum alloy with low-friction coated skirts, low tension rings
Connecting Rods
Cracked powder metal
Ignition
Pencil coil
Bore x stroke
3.6 x 3.4 in/ 92.5 x 86.7 mm
Displacement
213 cu in/ 3.496 cc
Compression ratio
10.3:1
Horsepower
250 @ 6250
Horsepower per liter
71.5
Torque
240 lb-ft @ 4500
Recommended fuel
87 Octane
Fuel capacity
19 gallons (FWD) 20 gallons (AWD)
Fuel Injection
Sequential multi-port fuel injection
Emission Control
Closed loop with catalyst
Emissions (tailpipe/evaporation)
Federal standards
Fed: Tier 2/Bin5, LEVII
California standards
Calif: ULEVII
Oil Capacity
5.5 quarts, with filter
Recommended Oil
GF4, 5W-20
DRIVETRAIN
Layout
FWD (optional AWD)
TRANSMISSION
Standard
6-speed automatic
Gear Ratios
1st
4.484
2nd
2.872
3rd
1.842
4th
1.414
5th
1.000
6th
0.742
REV
-2.882
Final Drive
FWD: 2.77; AWD: 3.39
SUSPENSION
Front
Macpherson strut and L-shaped lower control arm with isolated subframe and stabilizer bar
Rear
Independent suspension with trailing blade, integrated knuckle and lateral links, isolated subframe and stabilizer bar
STEERING
Type
Power rack & pinion
Steering column
Manual Tilt-Telescope
Ratio
17.5:1
Turns lock-to-lock
2.89
Turning circle curb-to-curb
12.5 m (41.0 ft)
BRAKES
Type
4-wheel ABS (4 channel); Optional AdvanceTrac® w/RSC®
Front
Disc
Swept area
FWD/AWD (66.8 in2)
Rear
Disc
Swept area
51.3 in2
Power assist
Yes
TIRES AND WHEELS
P245/60R18 BSW A/S H-rated on 18\" Machined Aluminum wheels w/Euroflange (Std)
P245/60R18 BSW A/S H-rated on 18\" Duraclad Chromed wheels w/Euroflange (Optional)
Recommended tire pressure (front/rear)
35 psi
DIMENSIONS (inches unless otherwise noted) (All dimensions are Preliminary)
EXTERIOR
Wheelbase
111.2
Overall length
186.5
Overall width
75.8
Overall height
67.2 (w/o roof rack); 69.0 (w/roof rack)
Track width, front/rear
65.2/64.9
Ground clearance
8.0
Approach angle
16 deg
Departure angle
22 deg
Ramp breakover angle
14 deg
Cargo Volume behind front row
68.7 cu ft
Cargo Volume behind second row
32.0 cu ft
INTERIOR
Seating capacity
5 passenger
Headroom
Front row
40.0 (w/o moon roof); 37.8 (w/moon roof)
Second row
39.3 (w/o moon roof); 38.6 (w/moon roof)
Legroom
Front row
40.7
Second row
39.3
Shoulder room
Front row
58.9
Second row
58.8
Hip room
Front row
54.8
Second row
56.1
WEIGHTS AND CAPACITIES (pounds unless otherwise noted)
Maximum towing capacity
(when properly equipped)
Class II (3500 lbs)
Maximum payload* (when properly equipped)
FWD
958
AWD
977
*Properly equipped vehicle w/required equipment and 150lb driver
Base curb weight
FWD
4220
AWD
4419
Weight distribution (f/r)
60/40
MAJOR STANDARD EQUIPMENT
Anti-Lock Brakes, Traction Assist (Engine Controlled, FWD non-AdvanceTrac® only), Tire Pressure Monitoring System
Dual-stage Airbags, Side Airbags, Safety Canopy™, 3-point Safety Belts (all positions), Front row Height Adjustable D-rings, BeltMinder® (front row), Perimeter Theft Alarm
Dual Chrome Exhaust Tips, Spoiler
Auto-Headlamps, Fog Lamps, Dual Power Heated Mirrors w/Chrome caps and Puddle Lamps, Auto-dimming Rearview Mirror, Power Windows w/1-touch up/down and Global Open, Power Locks, Child Safety Locks, Remote Keyless Entry w/keypad, Illuminated Entry, Theatre Dimming, Battery Saver, Cool White Lighting on switches/controls
Leather-wrapped Steering Wheel w/Speed Controls & redundant Audio/CCD Controls, DEATC Air Conditioning w/Particulate Air Filter, Message Center w/Compass, Floor Console, Overhead Console, Illuminated Visors, 1st & 2nd row Floormats
Leather Seating surfaces, 8-way Power Driver/Passenger seats, Manual Driver Lumbar, 2-way Manual Head Restraints (front/rear outboard), Integrated Head Restraint (rear center), 2nd row 60/40 fold-flat split bench w/manual recline and kneeling, LATCH, Map Pockets (front seatbacks, doors)
Cargo floor tie-downs (2), AM/FM Stereo/CDx6/MP3 capable/Clock w/6 speakers
Old 12-01-06, 22:08   #3
RoSonic
RoSonic's Avatar
[4 Speed Squad]
Old 13-01-06, 07:55   #4
wlady
Design Team Member
wlady's Avatar
price??
wlady is offline   Reply With Quote
Old 13-01-06, 16:29   #5
Eugen_TL
Renault Driver
Eugen_TL's Avatar
spre deosebire de navigator e misto, dar botul tot patratos a ramas ca la americani na-i ce le face ! ))
Eugen_TL is offline   Reply With Quote
Old 13-01-06, 16:29   #6
sil4tuning
Purtator cuvant SUN RACERS
sil4tuning's Avatar
[Sun Racers]
nu exista vreun pret specificat pt acest lincoln
sil4tuning is offline   Reply With Quote
Old 16-01-06, 11:15   #7
Venom
Venom's Avatar
american style! 4 americans!
Venom is offline   Reply With Quote
Old 26-01-06, 10:41   #8
dexter_20
dexter_20's Avatar
la spate seamana cu volvo xc90 si la fata cu nissan murano
nu-mi place,prea patratos
dexter_20 is offline   Reply With Quote
