Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > SEAT > Seat tuning
Old 25-04-09, 16:47   #1
letsplay
Default 2001 seat leon 1.6 stella 105 CP - ce imbunatatiri ii pot aduce pt a-i mari puterea ?
am un seat leon 1.6 stella 105 CP din 2001, nemodificat - ce imbunatatiri ii pot aduce pt a-i mari puterea ?
letsplay is offline   Reply With Quote
Old 25-04-09, 17:22   #2
Dany.bilan628
Dany.bilan628's Avatar
[Toyota]
Default Re: 2001 seat leon 1.6 stella 105 CP - ce imbunatatiri ii pot aduce pt a-i mari puter
basic: filtru+toba+cip cu asta se poate incepe...cum s-ar zice
Dany.bilan628 is offline   Reply With Quote
Old 24-08-09, 22:47   #3
letsplay
as vrea sa stiu cat m-ar costa un filtru sport, toba si cip (aproximativ, daca aveti idee), si cata putere va castiga masina
am citit un articol despre cum sa iti "intineresti" motorul, dar in limba engleza si nu stiu cum se traduc anumite chestii. as fi recunoscator daca mi-ar spune cineva ce inseamna fiecare chestie in parte.
asta e articolul:
Tune-ups may include the following:
-Re-fastening of cylinder head bolts
-Adjustment of the carburetor idle speed and the air-fuel mixture
-Inspection and possible replacement of ignition system components like
-contact breaker, distributor cap and rotor button
-Replacement of the air filter and other filters
-Inspection of emission controls
-Valve adjustment
-Replacement of the fuel filter.
-Replacement of all spark plugs and wires.
-Adjustment of the distributor cap angle on vehicles without electronic, or 'distributorless', secondary ignition, usually with the aid of a timing light.
-Inspection of serpentine belts and replacement as needed.
-Adjustment of the clutch on cars equipped with a manual transmission.
-Battery service as needed, including cleaning any corrosion on the terminals.
-Replacement of the PCV valve.
stiu ca v-am dat ceva de lucru as fi recunoscator daca m-ati ajuta
mersi mult
Old 26-08-09, 11:16   #4
letsplay
se pare ca v-am supraestimat ^^
Old 28-08-09, 16:40   #5
letsplay
varza
Old 28-08-09, 17:21   #6
cRbL
cRbL's Avatar
[FOTO]
noroc cu tine.
ia un dictionar sau foloseste google translate.
in fine
ce iti zice ala acolo in mare e ca tre sa faci o revizie cap coada a motorului cu tot ce tine de el.
si din treaba cip, filtru toba daca iei 10 15 esti zeu.
cel mult, urca mai frumusel in ture...
zic eu...
SF-urile si filmele porno au stricat mintile copiilor.
De ce?
Ca toti asteapta sa devina realitate ...
cRbL is offline   Reply With Quote
Old 29-08-09, 10:54   #7
letsplay
am tradus tot in afara de asta:
daca stiti ce presupune asta
Old 04-12-09, 23:31   #8
aureldd
aureldd's Avatar
[Mitsubishi]
Hai mey cRbL...lasa omu' sa fie optimist...din filtru, toba (eventual doar finala) si cip aduce un motor aspirat de 105 cp in 150 - 200 cp aseaaaa....la prima strigare...ca doar e super oferta
Mitsubishi Lancer
aureldd is offline   Reply With Quote
