Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > BMW > BMW tuning
Old 01-03-06, 20:31   #1
SpeederMan
Default Bmw M3 GTR
Bmw M3 GTR.......un vis frumosssss, hai sa postam in sectiunea asta poze, filme cu bmw m3 gtr! Asta e tot ce am eu despre m3 gtr:
BMW will race with two sturdy, 500-horsepower-strong coupes in the 24 Hour Races at the Nürburgring and at Spa-Francorchamps. BMW Motorsport Director, Mario Theissen, has a high opinion of the car, “The BMW M3 GTR enables
us to compete for the title.”
The impressive race car, which was designed by Albert Biermann and his team, proved to be a winner more than
once in 2001. In that year, the BMW M3 GTR had its debut for Team Schnitzer Motorsport at the American Le Mans
Series (ALMS) and set new standards in the GT series.
The car won ten races and took ten pole positions with its powerful V8 engine. Already in their very first race, the
driver duo JJ Lehto/Jörg Müller came in third in their BMW M3 GTR, which had been built in less than six months in
Sebring, Florida. After this successful debut, a second BMW M3 GTR was released for Fredrik Ekblom and Dirk Müller.
At the end of the season, the BMW M3 GTRs were so advanced that both cars celebrated four one-two victories in
the last four races.
Consequently, the dominating car of the season secured the title: Jörg Müller won the Drivers’ Championship,
Schnitzer Motorsport won the Constructors’ Championship and BMW finished on position one in the Brand
Championship in the most important foreign market for the company, the United States.
If you take a closer look at the construction of the car, it is easy to see why the BMW M3 GTR has been so
successful. The V8 engine, which is 500 bhp strong, does 7,800 revolutions per minute. With its short strokes, high-
performance and compactness the engine is typical for the M series. The individually designed chassis with
components that are highly aerodynamic and the lightweight construction with body parts made of carbon fibre are
the reasons why the BMW M3 GTR is a racing machine with no match.
BMW M3 GTR Official statistics
Engine specifications
Cubic capacity: 4.0 litres, V8 cylinder
Bore/stroke: 94 mm X 72 mm
Power output: app. 500 bhp at 7,800 rpm
Maximum torque: 500 Nm at 6,500 rpm
Oil: Castrol TWS
Induction system: BMW ECU 12A-V8
Spark plugs: Champion
Chassis:
Two door coupe, self carrying chassis with FIA safety cage
Dimensions/weight:
Length: 4,617 mm
Width: 1,884 mm
Height: 1,300 mm
Wheelbase: 2,731 mm
Front track: 1,609 mm
Rear track: 1,602 mm
Weight: 1,250 kilos
Fuel tank:
FIA safety tank with a capacity of 120 litres
Steering:
M3 GTR standard steering wheel; electro-hydraulic power steering
Shock absorbers:
Four times adjustable Sachs shock absorbers
Suspension:
Front axle: McPherson suspension strut with spiral springs; adjustable anti-roll bar
Rear axle: Central pivot rear axle with spiral springs; adjustable anti-roll bar
Differential:
Limited slip differential
Transmission:
Hewland six gear gearbox; H-scheme shifting
Oil: Castrol
Brakes:
Brembo/Performance Friction
Front: Inner ventilated brake discs; diameter 380 mm; brake calliper with six brake plungers
Rear: inner ventilated brake discs; diameter 313 mm; brake calliper with four brake plungers
In the centre of the BMW M3 GTR is a powerful V8 engine with over 400 bhp. The engine is a short stroke, high
reving power unit following in the tradition of the M engines. The engine is compact which makes it suitable for the
GTR and is possible to install the engine in the M3 due to its back angle of 90 degrees and a flat oil pan.
Lengthwise, the 4-litre V8 is more compact than an in-line 6-cylinder engine, making a new cooling concept
possible. The powerful cooling devices are located directly behind the front apron with one unit cooling the radiator
and the other cooling the oil. The outlets for air, collected by the cooling device are visible on the bonnet.
Due to the late decision for the go ahead with the BMW M3 GTR project, the engine construction only began in mid-
February of the year 2001. The first V8 racing engine was run on the test bench on February 20 and was followed
by a functional test on the BMW circuit in Ismaning near Munich on March 3. The engines are highly efficient like all
M engines which make them suitable for long distance racing.
The GTR drives with the power of a V8 instead of a 6-cylinder engine. Since racing regulations do not permit
sequential gearshift, the GTR has a conventional 6-speed transmission. The racing and road versions of the GTR
differ in safety-related mods, including the cleared interior with welded safety cell, the fast filling system and racing
chassis and brakes.
BMW M3 GTR – a success model celebrates its comeback. BMW will race with two sturdy, 470-horsepower-strong
coupes in the 24 hour race at the Nurburgring.
BMW Motorsport Director, Mario Theissen, has a high opinion of the car: “The BMW M3 GTR enables us to compete
for the title”.
The racer, which was designed by Albert Biermann and his team, proved to be a winner’s car more than once in
2001. In that year, the BMW had its debut for Team Schnitzer Motorsport at the American Le Mans Series (ALMS)
driver duo JJ Lehto / Joerg Mueller came in third in their BMW M3 GTR, which had been built in less than six months
in Sebring, Florida. After this successful debut, a second BMW M3 GTR was released for Fredrik Ekblom and Dirk
Mueller. At the end of the season, the BMW M3 GTRs were so advanced that both cars celebrated four one-two
victories in the last four races.
Consequently, the dominating team of the season won the title: Joerg Mueller won the drivers’ championship,
Schnitzer Motorsport won the constructors’ championship and BMW won the brand championship in the most
successful. The V8 engine, which is 470 HP strong, does 7,800 revolutions per minute. With its short strokes, high-
performance and compactness the engine is typical for the M series. The individually designed chassis with components that are highly aerodynamic and the lightweight construction with body parts made of carbon fibre are
SpeederMan is offline   Reply With Quote
Old 01-03-06, 20:36   #2
SpeederMan
Si uite si versiunea de strada!
ID:	72847   Click image for larger version
ID:	72848   Click image for larger version
ID:	72850   Click image for larger version
ID:	72851   Click image for larger version
Old 03-03-06, 18:40   #3
shaid-kid
shaid-kid's Avatar
Ce pret are superbitatea asta?
shaid-kid is offline   Reply With Quote
Old 05-03-06, 18:33   #4
SpeederMan
Default Re: Bmw M3 GTR
La linku asta http://www.rsportscars.com/eng/cars/bmw_m3gtr.asp
cica ar fi 250000euro
Old 09-03-06, 10:18   #5
mertan
mertan's Avatar
[Crazy Drivers]
un pretz pe masura. cine stie. am vazut eu. un m3 e36 si era modificat. turbo. 1000 de cai. 1100 parca. si zicea aaha... ori vii cu un m3 e36 stock ori tio cumperi pe toata de la ei. dar era un pret cam misto. ceva de genu 20.000-40.000. chiar nu mai tin minte. ash vrea sa caut linku.
Proiectare civila-industriala-zootehnica-avize-design interior-lucrari de productie publicitara-0756.558.570
mertan is offline   Reply With Quote
Old 10-03-06, 15:01   #6
kitros
BMW M3 e cea mai reusita masina a celor de la BMW e prea criminala
kitros is offline   Reply With Quote
Old 12-03-06, 09:17   #7
shantzu
shantzu's Avatar
[Anonymous Motorsport ]
[FOTO]
Talking Re: Bmw M3 GTR
hehe superba masina mi se pare cea mai reusita masina sport !!! mai era un kit pt M3 e36 , 20.000 sau 30.000 (nu mai stiu sigur) si il ducea pana la 1000 cp
edit.
the kit price is 22 800usd incuding forged engine internals(J.E pistons,rods, rings, crankshaft etc.)therefore alowing the 8300rpm redline this also includes the TSI engine management already programed as well as all the turbo accessories(BOV,wastegate, intercooler all the pipes ,brackets and full exhaust)the fuel system is also provided by them and the intake manifold
*peak power at 7800rpm
*8300rpm redline
*1st gear 0-72km/h and top speed of 340km/h limited but they say can do 380km/h
They say the trany is over engineered and can handle 1050nm or 955lbft, because the bmw tranny is made by getrag which is similar to the tranny 1000hp+ toyota supras use with no problem.
They also have option that cost extra for the suspension, brakes, clutch and racing spark plugs
Now the maintenance
every 40 000km the engine rings need to be changed as well as the head gasket the engine rebuild will cost you about 2000usd. The rest of the maintenance is the same as the oem M3
They say the drivabilty is the same as the normal m3 and this kit works with 96 octane gas but in my opinion there has to be lots of lag since it is a 71 mm turbo they usebut there always nitrous
All of this sounds great to me but I would kill myself having a 1000hp daily driver ( I would race every muscle car on the road as long as it is highway)
check out the link and tell me what you think
shantzu is offline   Reply With Quote
Old 22-03-06, 02:15   #8
SpeederMan
Linku pt BMW M3 e36 de 1100cp http://www.da-motosport.com
Old 14-04-06, 08:28   #9
mihai88
mihai88's Avatar
io unu m-am indragostit de masina asta,o sa vb cu matusa tamara sa imi dea bani sa imi cumpar si io
cea mai reusita masina de la bmw
mihai88 is offline   Reply With Quote
Old 14-04-06, 14:36   #10
bobocel
e suuuuuuupeeeeer...... masina visurilor mele .................... vaaaaaai
bobocel is offline   Reply With Quote
Old 14-04-06, 15:02   #11
bano
bano's Avatar
1000 de cai da ai unde sai foloseti eu asvrea 200
bano is offline   Reply With Quote
Old 16-04-06, 10:20   #12
MOMOracer
omule nu are cum sa coste kitu doar 20000$ si iti mai da si 1000de cai cunosc un rx8 care are cam 675 de cai si a schimbat cutia si engine kitu si la dus cam la 60000$ si ceva tuning interior exterior cam 10000$ si avea doar 675
MOMOracer is offline   Reply With Quote
Old 21-04-06, 22:17   #13
BLinKY
- A better 0 to 100 km/h acceleration time than Ferrari F430: 0 to 100 km/h 3.2 seconds
- A better 0 to 200 km/h acceleration time than a Ford GT: 0 to 200 km/h in 8.8 seconds
- A better 0 to 240 km/h acceleration time than a Lamborghini Murcielago in 11.9 seconds
in 11.9 prinde masina mea suta ))
BLinKY is offline   Reply With Quote
Old 24-05-06, 20:04   #14
mihai88
mihai88's Avatar
io cre ca meseriasi aia nu mint in privinta puterii.....totusi sunt cunoscuti si arhicunoscuti
Old 25-05-06, 17:27   #15
BLinKY
Ati facut cateva greseli in legatura cu masina, nu costa 250k ci 400k si ceva CIP,
Iar kitul respectiv e 28k euro pt e36
Oricum nu sunt greseli, dar sincer nu cred ca e cineva nebun sa dea 500k $ pe un m3, care e aproape ca cel normal, de banii aia gasesti masini mult mai bune, nu la fel de performante, dar cu aspect mai tare
