Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > SUBARU > Masina mea Subaru
Old 29-12-05, 16:45   #1
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Default FORESTER XT 2.5 TURBO
Un model destul de simplu, arata spartan dar merge tun.
5.9 secunde pana la 100km/h
221km/h viteza de top declarata
un 400m destul de rapid pentru asa o masina
Care e parerea voastra, ce stiti despre ea.
Are ceva special pe undeva?
Professional DynoTuning
[email protected]
0723691731
Old 29-12-05, 19:57   #2
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Old 29-12-05, 20:15   #3
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Atentie pachetul de sus este pentru modelul de 211cp la baza.
uite ce spune lumea de cel de 230cp: 'First introduced for the '05 Model Year, the 2.5 litre turbo (XT) gains an extra 19 PS, raising power to 230 PS and reducing the 0-60 mph time to 5.7 seconds for the manual'
Old 29-12-05, 20:24   #4
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
ID:	59340   Click image for larger version
ID:	59341   Click image for larger version
Old 29-12-05, 20:28   #5
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Vehicle Dynamics Control - New for ’06 is an automatic version of the turbocharged Forester 2.5. Standard on this model is Subaru’s Vehicle Dynamics Control (SVDC) which combines active safety with enhanced cornering control. It sensors on all four wheels to detect slip, with other sensors registering front to rear G-forces and side-to-side G-forces.
Symmetrical AWD Transmission – Subaru’s rally-honed symmetrical all-wheel drive transmission reduces drive friction, fuel consumption and power loss for several reasons.
First, the short ‘boxer’ engine is in-line with the transmission. Then, its low height allows the front drive-shafts to be almost horizontal, while power is sent to the rear wheels is in a straight line via a prop shaft rather than via an awkward transfer box.
Manual non-turbo versions have a dual-range gearbox with 10 speeds.
The light and compact AWD system can be installed in the transmission case, and the symmetrical AWD system allows chassis engineers to tune the suspension for excellent handling and road holding.
The Forester’s full-time AWD system on manual models splits power 50/50 front to rear which gives enhanced straight-line tracking and extra agility through corners.
As soon as slip is detected, the centre differential with its viscous-coupling distributes torque to the axle with the most grip. This happens in milliseconds, and all the driver is aware of is less understeer/oversteer than expected and reassuring grip where a 2WD car would be sliding.
Old 29-12-05, 20:42   #6
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
ID:	59352   Click image for larger version
ID:	59353   Click image for larger version
ID:	59355   Click image for larger version
ID:	59356   Click image for larger version
ID:	59358   Click image for larger version
Old 29-12-05, 21:27   #7
orlando
orlando's Avatar
[Hyundai]
wow ce te-ai documentat...
te bate gandu sa iti iei si tu unul?
orlando is offline   Reply With Quote
Old 29-12-05, 21:39   #8
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Default Re:
Crezi ca ar fi rau unul la vreo 300cp cu o platforma misto si Subaru de curse pe ea?
Old 29-12-05, 21:45   #9
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
If you’re a speed demon, the XT model gets a boost from 210 to 230-hp, due to a higher compression ratio and revised intake and exhaust. More power brings better fuel efficiency as well, with improved EPA mileage numbers, now 19/25 with the manual and an impressive 21/26 with the automatic. Not bad, given that the ’06 Forster XT can reach 60 mph in less than 6 seconds.
ID:	59386   Click image for larger version
ID:	59387   Click image for larger version
Old 29-12-05, 21:47   #10
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Model SUBARU FORESTER 2.5XT
Engine Type 2,457cc 16V horizontally-opposed turbocharged 4
Max Power 230bhp at 5,600rpm
Max Torque 320Nm at 3,600rpm
Gearbox 4-speed automatic
Top Speed 214km/h
0-100 KM/H 7.6 seconds
Old 29-12-05, 21:53   #11
bodyspeed
bodyspeed's Avatar
[Oltcit]
[FOTO]
super masina asta uite sebastian ce am gasit despre ea
2005 JDM Subaru Forester STi
Engine
Type: Flat-4, Turbocharged
Displacement cu in (cc): 150 (2457)
Power bhp (kW) at RPM: 265(195) / 5600
Torque lb-ft (Nm) at RPM: 279(37 / 3600
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: n.a.
Driveline: All Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 173.7 × 67.7 × 60.5
Weight lb (kg): 3306 (1500)
Performance
Acceleration 0-62 mph s: n.a.
Top Speed mph (km/h): n.a.
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
Base Price: 2005 JDM Subaru Forester STi - n.a. (last update: 4/27/2005)
ID:	59389   Click image for larger version
ID:	59390   Click image for larger version
carDesign
Magazin CarDesign 4Tuning
Old 29-12-05, 21:55   #12
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Default Re:
Engine
Brakes & Tires
Tires F-R: n.a.
Performance
il stiu e vechi dar nu e modelul descris de mine si nu se importa.
Ai uitat poza cu scaunele.
Old 29-12-05, 22:05   #13
bodyspeed
bodyspeed's Avatar
[Oltcit]
[FOTO]
Default Re:
Engine
Brakes & Tires
Tires F-R: n.a.
Performance
daca te deranjeaza sterg mesajele(sau le stregi tu ) nu este nici o problema
scuze n-am fost atent la detalii
Old 30-12-05, 06:28   #14
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Default Re:
Engine
Brakes & Tires
Tires F-R: n.a.
Performance
Nu ma deranjeaza, dar hai sa vorbim de cel din titlul topicului.
Old 30-12-05, 11:25   #15
tase_astra
tase_astra's Avatar
Forester 2.5T e prea tare! De abia astept sa merg cu motorul asta nou! Cel vechi de 210cp era super, asa ca asta trebuie sa fie racheta.
tase_astra is offline   Reply With Quote
