Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > HONDA - ACURA > Masina mea Honda - Acura
Old 17-03-13, 12:17   #1
Bara89
Bara89's Avatar
Default `93 Civic EG4 1.5- LSI (D15B2)
Saluti!
Fara alte introduceri vreau sa zic ca m-am indragostit de cand "i-am dat in guritza" prima data =))
Postez cu speranta ca voi cunoaste si alti posesori(poate chiar din Arad) la fel de incantati si care pot impartasi un sfat bun.
ID:	2721027   Click image for larger version
Bara89 is offline   Reply With Quote
Old 17-03-13, 12:23   #2
Bara89
Bara89's Avatar
Default re: `93 Civic EG4 1.5- LSI (D15B2)
De cand o am am retapitat panourile portierelor si cel de la portbagaj unde vin boxele.
ID:	2721046   Click image for larger version
ID:	2721047   Click image for larger version
Old 17-03-13, 12:32   #3
Bara89
Bara89's Avatar
Schimbat:
Ulei,filtre si alte cele
14400-PM3-004 BELT, TIMING(106RU24 A555) UNITTA)
14510-PM7-003 TENSIONER COMP.,TIMING BLET(KOYO SEICO)
14513-PE0-015 BOLT,TENSIONER (M6)
14516-PM3-010 SPRING COMP.,TIMING BELT ADJUSTER
14517-PG6-000 BOLT A, TENSIONER
17220-P07-000 ELEMENT ASSY., AIR CLEANER
19200-P01-003 PUMP., WATER (KEIHIN)
31110-P01-003 BELT,ALTERNATOR (BANDO)
44018-SR3-C03 BOOT SET, OUTBOARD
50841-SR3-030 RUBBER, R. FR. STOPPER INSULATOR (MT)
50842-SR3-030 RUBBER, L. FR. STOPPER INSULATOR (MT)
52370-SR3-A10 ARM COMP.,R.RR.TRAILING (DRUM)
52371-SR3-A11 ARM COMP.,L.RR.TRAILING (DRUM)
53010-SR3-010 END SET, RACK
53534-SR3-A52 DUST SEAL., TIE ROD
53534-SR3-N52 DUST SEAL., TIE ROD
53540-SR3-003 END COMP., R. TIE ROD
53560-SR3-003 END COMP., L. TIE ROD
56992-P02-003 BELT, POWER STEERING PUMP (BANDO)
90011-PG6-004 BOLT, TIMING BELT ADJUSTER SPRING
94301-08100 DOWEL PRIN, 8X10 (KEIHIN)
95701-06030-08 BOLT, FLANGE, 6X30
Am postat si "part numberul" intrucat poate va fi de ajutor cuiva pe viitor.
Mai jos o poza cu o parte din piese
Cius!
Old 17-03-13, 18:20   #4
carlitos
carlitos's Avatar
[Honda]
Originally Posted by Bara89 View Post
Schimbat:
Cius!
sa ai parte de ea!!!!
pentru sfaturi si diverse piese ma poti contacta oricand,,,
carlitos is offline   Reply With Quote
Old 18-03-13, 18:32   #5
SirG3G3
SirG3G3's Avatar
[Honda]
vad ca ai ganduri mari cu ea,multa bafta!
SirG3G3 is offline   Reply With Quote
Old 19-03-13, 18:19   #6
Bara89
Bara89's Avatar
Multumesc, carlitos! Daca nu voi gasi ceva in Arad sigur voi apela la tine
Mersi, SirG3G3!Sa stii ca chiar am planuri mari dar intai vreau sa o pun bine la punct.
Am un set de jante din aluminiu bunicele dar trebuiesc indrepate si voposite le-am luat aproape gratis.
Voi ce parere aveti merita investitia?
Old 19-03-13, 23:49   #7
BlackBC
BlackBC's Avatar
[Honda]
Cred ca ar fi mai bine sa le schimbi, eu unul nu cred ca vin bine pe eg.Pe la motor nu ii faci nimic?Multa bafta in continuare!
BlackBC is offline   Reply With Quote
Old 20-03-13, 19:00   #8
Bara89
Bara89's Avatar
Smile re: `93 Civic EG4 1.5- LSI (D15B2)
Si eu m-am gandit ca nu stau bine pe eg Sincer ma gandeam la niste jante de tabla vopsite cu un alb stralucitor.Cred ca s-ar imbina bine cu albastrul caroseriei.
Legat de motor am planuri mari dar mai in vara, pan auntci studiez.Nu stiu multe despre modificari la motor dar imi dau interesul.
Mersi voi avea mare nevoie la proiect
Old 20-03-13, 21:41   #9
BlackBC
BlackBC's Avatar
[Honda]
Niste table late ar da bine, iar despre motor sunt multe posibilitati, depinde cat de mare vrei tu herghelia de sub capota.Numai bine!
Old 05-04-13, 14:38   #10
Bara89
Bara89's Avatar
Sau schimbat si bujiile cu unele de la NGK!
Old 07-04-13, 00:01   #11
SirG3G3
SirG3G3's Avatar
[Honda]
Ce buji aveai inainte?vad ca au acelasi cod cu ale mele,dar ale mele aveau alt ambalaj,eu luase teapa cu bosch,care mergeau super naspa,asa am reusit sa pierd aproximativ 40 de lei,ca dupa 2 zile am fost nevoit sa iau tot ngk.
EX Cars:Opel Kadett c16nz,Volswagen Polo 6N 1.0 Sportline,Honda Civic Eg3 & Dacia Logan 1,5 DCI
Driving:BMW E46 320D
Old 07-04-13, 13:11   #12
Bara89
Bara89's Avatar
Masina a ajuns la mine cu Bosch Super Plus dar nu mergea bine motorul asa ca le-am schimbat cu astea si sunt foarte incantat de diferenta.Toarce mult mai frumos si suna mai sportiv )
Poate incarc deseara un scurt video.Asa, de show
Old 13-04-13, 22:41   #13
SirG3G3
SirG3G3's Avatar
[Honda]
Exact aceasi diferenta si la mine intre bosch si ngk
Old 14-04-13, 01:24   #14
Bara89
Bara89's Avatar
Cred ca si consumul e mai bun acuma inca o testez.Mai e un lucru care as vrea sa il fac si acela e sa strang cablul de la acceleratie ca m-i se pare ca sa lasat.Dar mie putin frica sa nu ii fac un rau.
Old 14-04-13, 01:27   #15
roli
roli's Avatar
[Honda]
Ma bucur ca a mai aparut inca o honda in arad si la cum vad si ti la ea fata de alti amici pe care i-am comvins sa isi cumpere un eg
Stai cumva in aradul nou?
roli is offline   Reply With Quote
