Old 14-12-12, 18:24   #1441
Bolt
Bolt's Avatar
Default Re: Daewoo Cielo Low-Low Matte Green (Cult)
vai taba ei ce o sa pateasca presupun ca o si insonorizezi o idee..
Bolt is offline   Reply With Quote
Old 15-12-12, 22:00   #1442
CT-13-TGR
CT-13-TGR's Avatar
Exclamation Re: Daewoo Cielo Low-Low Matte Green (Cult)
salut, intrebare retorica, a venit iarna la moldova cum te descurci cu barile?
CT-13-TGR is offline   Reply With Quote
Old 15-12-12, 22:57   #1443
iviTe
iviTe's Avatar
pai adun tot dupa mine.. cam da a venit rau de tot .. drumuri inchise etc ... dar verzica sta parcata la garaj ) ca am alta cu care circul zilnic ... adica mai exact sunt la munca de la 9 pana la 6 asa ca ...
iviTe is offline   Reply With Quote
Old 16-12-12, 16:18   #1444
byJoKeR
byJoKeR's Avatar
Iti aprieciez munca depusa.bafta
byJoKeR is offline   Reply With Quote
Old 25-12-12, 17:19   #1445
iviTe
iviTe's Avatar
1,2 poze de azi ... si a primit si ea un voltmetru ... sa ne pregatim ptr muzica
p.s. neaparat trebuie un alternator de 100A ..
ID:	2643803   Click image for larger version
ID:	2643804   Click image for larger version
ID:	2643806   Click image for larger version
Old 25-12-12, 17:23   #1446
IulySilviu
IulySilviu's Avatar
Craciun Fericit , imi place grav DVD-u , cat te-a costat ?
Langa schimbator ai un ceas electric , ce indica ?
IulySilviu is offline   Reply With Quote
Old 25-12-12, 17:57   #1447
Bolt
Bolt's Avatar
super bun dvd-ul am avut si eu unu, vezi ca am eu pe cineva care vinde un alternator...de bmw este aproape nou, cauta in anunturile mele.
Old 26-12-12, 00:08   #1448
iviTe
iviTe's Avatar
pai .. alternator voi pune de opel ..cu tot cu suport ca merge fara modificari
Old 26-12-12, 10:53   #1449
valitataye
valitataye's Avatar
[SEAT]
Cel de pe opel tigra e mai mare parca 90-100A din ce stiam..
valitataye is offline   Reply With Quote
Old 26-12-12, 23:11   #1450
pustiu_FUG
pustiu_FUG's Avatar
Cauta de Opel care are A.C, daca are A.C. are si alternator de 100%
Bafta!
pustiu_FUG is offline   Reply With Quote
Old 28-12-12, 15:30   #1451
GabrielMotorsport
GabrielMotorsport's Avatar
DVD vine prea grav pe ea Ce dimensiuni are ?
GabrielMotorsport is offline   Reply With Quote
Old 28-12-12, 16:51   #1452
iviTe
iviTe's Avatar
dvd`ul este 2DIN .. nustiu dimensiunile ... dar ce`i drept se incadreaza perfect in peisaj .. cat despre alternator, da trebuie neaparat ceva mai mareeee am inteles ca de la motoarele c20xe .. au de 100A si de la inca un model ,,,
Old 04-01-13, 15:37   #1453
tiolik
tiolik's Avatar
salut, si la multi ani, foarte frumoasa masina, nu stiu de ce vrei tu neaparat sa schimbi alternatorul, eu il am pe cel original si nu pot sa zic ca nu face fata, e adevarat ca in sarcina imi scade cam in 12 minim 11,5 dar asta nu e din cauza alternatorului ci de la cabluri, inainte sa dublez cablajul alternatorului si sa pun niste cabluri potente pt alimentarea sub intradevar imi scadea si la 9-9,5 dat acum nu mai am probleme;
muzica o ai deja sau ai proiect pentru viitor? daca esti interesat a mea este de vanzare (tot chitul calbluri, amplificator, difuzor cu 2 cutii una de muzica si una de scor si condensator 1400w rms scoate, 140db am reusit sa dau cu ea)
YM! tiolik_the_only_1
Tel: 0747 031 566
tiolik is offline   Reply With Quote
Old 04-01-13, 23:49   #1454
iviTe
iviTe's Avatar
Salut, la multi ani cu intarziere ... si da muzica o am deja, mai urmeaza 1 singur sub cel care nu il avusera pe stock il astept luna aceasta... si da am sa vad sa fac BIG 3! sper sa fie bine ..
p.s masina a primit astazi un set nou de fise TESLA! foarte bune nu mai am probleme la furatul curentului .. cele vechi ma cam curentau cand le atingeam
Old 13-01-13, 18:29   #1455
tng
Observator 4tuning
tng's Avatar
ce putiinnnnn
revenind ontopic, probabil stii si tu ivi ca la putere mai mare, cablurile conteaza foarte mult, desigur cele de +/-(minim 25mm la ce vrei tu acolo), fara bucle, cat mai intinse. sa ne zici cu big3 daca se schimba ceva, sunt tentat si eu sa-l fac. abia apoi de umblat la alternator si baterie
Toata lumea e "illest" acum, insa doar pe stickere
"low&slow" dar mai mult slow decat low
Euro Corsa C
tng is offline   Reply With Quote
